Cisco 7960G configurieren --- Gelöst
hab ich gemacht aber es kommt die meldung:
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:0F:B5:05:6E:E9 [09/05 22:20:57.359]
Client requested address 192.168.0.104 [09/05 22:20:57.359]
DHCP: proposed address 192.168.0.104 [09/05 22:20:58.359]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:0F:B5:05:6E:E9 [09/05 22:20:58.359]
Previously allocated address acked [09/05 22:20:58.375]
Rcvd DHCP inform Msg for IP 192.168.0.104, Mac 00:0F:B5:05:6E:E9 [09/05 22:21:01.500]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:16:C7:B7:58:13 [09/05 22:21:04.062]
Client requested address 192.168.0.106 [09/05 22:21:04.062]
DHCP: proposed address 192.168.0.106 [09/05 22:21:05.062]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:16:C7:B7:58:13 [09/05 22:21:05.093]
Previously allocated address acked [09/05 22:21:05.500]
Read request for file <SIPDefault.cnf>. Mode octet [09/05 22:21:05.546]
Using local port 1232 [09/05 22:21:05.562]
<SIPDefault.cnf>: sent 8 blks, 3980 bytes in 0 s. 0 blk resent [09/05 22:21:05.578]
Rcvd DHCP inform Msg for IP 192.168.0.104, Mac 00:0F:B5:05:6E:E9 [09/05 22:21:05.609]
Read request for file <./SIP0016C7B75813.cnf>. Mode octet [09/05 22:21:05.765]
Using local port 1233 [09/05 22:21:05.765]
<./SIP0016C7B75813.cnf>: sent 4 blks, 1646 bytes in 0 s. 0 blk resent [09/05 22:21:05.765]
Read request for file <SIP0016C7B75813.cnf>. Mode octet [09/05 22:21:37.750]
Using local port 1234 [09/05 22:21:37.750]
<SIP0016C7B75813.cnf>: sent 4 blks, 1646 bytes in 0 s. 0 blk resent [09/05 22:21:37.765]
Read request for file <SIP0016C7B75813.cnf>. Mode octet [09/05 22:22:08.875]
Using local port 1235 [09/05 22:22:08.875]
<SIP0016C7B75813.cnf>: sent 4 blks, 1646 bytes in 0 s. 0 blk resent [09/05 22:22:08.890]
Read request for file <SIP0016C7B75813.cnf>. Mode octet [09/05 22:22:40.046]
Using local port 1236 [09/05 22:22:40.046]
<SIP0016C7B75813.cnf>: sent 4 blks, 1646 bytes in 0 s. 0 blk resent [09/05 22:22:40.062]
Read request for file <SIP0016C7B75813.cnf>. Mode octet [09/05 22:23:11.265]
Using local port 1237 [09/05 22:23:11.265]
<SIP0016C7B75813.cnf>: sent 4 blks, 1646 bytes in 0 s. 0 blk resent [09/05 22:23:11.265]
steht noch etwas auf dem display?
ich schau mal, ob sich die konfiguration geändert hat
EDIT: keine Änderung gefunden; du kannst ja noch mal versuchen alles in die SIPDefault.cnf zu schreiben und die SIP0016C7B75813.cnf zu löschen
oder du ändert in der SIPDefault.cnf die Zeile
tftp_cfg_dir: "./"
in
#tftp_cfg_dir: ""
auf dem display ist nur das cisco zeichen zu sehen.
oben rechts steht SIP
und alle 2 min kommt dies : phone unprovisioned und die uhr dreht sich
woran erkenne ich denn überhaupt das es fertig ist?
das ich uhrzeit und datum etc eingeben kann?
und wie gehts dann weiter? würde es gerne mit sipgate betreiben.
so gut wie fertig hört sich so an als würde da noch was fehlen oder?
was heißt denn dieses "Phone Unprovisioned"?
muss ich da etwas über den tftp hochladen oder muss ich den rest am
telefon selbst konfigurieren?
nein, den rest machst du mit den Konfigurationsdateien
soweit so gut....
bekomme mittlerweile sogar einen Freizeichen
Allerdings steht auf dem Telefon: unable to locate Http Server.
Port 80 habe bei mir geöffnet.
Irgendeine Idee ??
das wird die serviceurl oder directory sein
so problem gelöst.
hatte vergessen die http proxy adress einzugeben.
freizeichen habe ich immernoch aber wenn ich eine nr wähle
kommt sofort das besetztzeichen und auf dem telefon steht "Reorder"
dann ist entweder Deine Anmeldung nicht korrekt (schau mal bei Sipgate im Webinterface) oder die fehlt die dialplan.xml
sipgate anmeldung sollte richtig sein...
in der dialplan steht:
<DIALTEMPLATE>
<TEMPLATE MATCH="*" Timeout="5"/> <!-- Anything else -->
</DIALTEMPLATE>
ist das richtig?
auch richtig;
kanst du via sipgate angerufen werden?
no...geht auch nicht. zumindest was das 7960 angeht
mit x-lite ist kein problem... anrufen sowie angerufen werden.
Hallo Visualking,
koenntest Du bitte Deine .cnf-Files posten, so wie sie jetzt sind? Username/-Password natuerlich unkenntlich gemacht.
# SIP Configuration Generic File
# Image Version
image_version: P0S3-08-2-00
phone_label: " "
# Line 1 appearance
line1_displayname: "xxxx"
line1_shortname:"SIP"
line1_name: 100
line1_authname: "xxxxxx"
line1_password: "xxxxxx"
# Phone Prompt (The prompt that will be displayed on console and telnet)
phone_prompt: "SIP Phone" ; Limited to 15 characters (Default - SIP Phone)
# Phone Password (Password to be used for console or telnet login)
phone_password: "cisco" ; Limited to 31 characters (Default - cisco)
# User classifcation used when Registering [ none(default), phone, ip ]
user_info: none
language: english			; Sprache (Zur Zeit ist nur 'english' möglich)
dyn_dns_addr_1: ""			; Das Telefon kann sich an dyn. DNS Servern registrieren. Hat nichts mit den eigentlichen DNS Servern zu tun
dyn_dns_addr_2: ""			; Siehe dyn_dns_addr_1
http_proxy_addr: "192.168.0.1"			; Adresse des HTTP Proxy Servers
http_proxy_port: 80			; Port des HTTP Proxy Servers (STANDARD=80)
proxy_register: 1			; Proxy Registrierung (0= Aus (STANDARD), 1= Ein)
proxy_backup: "192.168.0.1"			; Backup Proxy Adresse (Hier muss ein Eintrag sein sonst kann sich das Telefon nicht registrieren)
proxy_backup_port: 5060			; Backup Proxy Port (STANDARD=5060)
proxy_emergency: ""			; Notfall Proxy Adresse
proxy_emergency_port: 5060		; Notfall Proxy Port (STANDARD=5060)
outbound_proxy:	"217.10.79.9"			; Ausgehende Proxyadresse
outbound_proxy_port: 5060		; Ausgehender Proxyport (STANDARD=5060)
network_media_type: auto		; Port Geschwindigkeit (Auto (STANDARD), Full100, Half100, Full10, Half10)
network_port2_type: PC			; Patch- oder Crossovermode des 2 Ethernetports (Hub/Switch (STANDARD), PC)
local_cfwd_enable: 1			; Local Call Forwarding (0= Aus, 1= Ein (STANDARD))
user_info: none				; 'user='-Information (none= Kein Eintrag (STANDARD), phone= user=phone, ip= user=ip)
dyn_tftp_addr: ""			; Nach dem Laden aus dem festen TFTP Servers kann hier über einen anderen TFTP geladen werden
tftp_cfg_dir: "d:\root"			; Wenn sich die Konfigdaten des Telefons in einem Subverzeichnis befinden, Verzeichnispfad angeben
dial_template: dialplan			; Datei für die Wählplanvorlage
directory_url: ""			; HTTP Pfad zur Nutzung des External Directory
services_url: "http://www.fo-pa.de/cgi-bin/rss2cisco.pl"	; HTTP Pfad zur Nutzung des Services Button
nat_enable: 0				; Telefon an NAT angeschlossen (0=Aus (STANDARD), 1= Ein)
nat_address: "xxxxx.dyndns.org"		;
nat_received_processing: 1			;
preferred_codec: g711ulaw		; Sprachcodec (g711alaw, g711ulaw (STANDARD), g729a, none)
remote_party_id: 0				;
semi_attended_transfer: 1			;
sip_invite_retx: 6				;
sip_retx: 10					;
sync: 1						;
stutter_msg_waiting: 0			; Stutter Wählton, wenn eine Nachricht wartet (0= Aus (STANDARD), 1= Ein)
call_stats: 0				; RTP Statistik (0=Aus (STANDARD), 1=Ein)
telnet_level: 1				; Telnetzugang (0= Aus (STANDARD), 1= Lesezugriff, 2= Vollzugriff)
timer_invite_expires: 180			;
timer_register_expires: 300			;
timer_t1: 500					;
timer_t2: 4000					;
timer_register_delta:				;
tos_media: 5					; Type of Service ToS (0= routine, 1= priority, 2= immediate, 3= flash, 4= override, 5= critic (STANDARD))
sntp_mode: unicast		; SNTP Modus (unicast, multicast, anycast (STANDARD), directedbroadcast)
sntp_server: "ntp.sipgate.net"		; SNTP Server Adresse
anonymous_call_block: 0			; Blocken anonymer Anrufer (0=Aus (STANDARD), 1=Ein, 2=Aus, Zuschalten im Menü nicht möglich 3=Ein, Zuschalten im Menü nicht möglich)
autocomplete: 1				; Automatische Rufnummernvervollständigung (0=Aus, 1=Ein (STANDARD))
call_hold_ringback: 0			; Rufton bei Aufhängen aber wartendem Partner (0=Aus (STANDARD), 1=Ein, 2=Aus,  Zuschalten im Menü nicht möglich 3=Ein, Zuschalten im Menü nicht möglich)
call_waiting: 1				; Haltefunktion (0=Aus, 1=Ein (STANDARD), 2=Aus,  Zuschalten im Menü nicht möglich 3=Ein, Zuschalten im Menü nicht möglich)
callerid_blocking: 0			; Rufnummernunterdrückung (0=Aus (STANDARD), 1=Ein, 2=Aus, Zuschalten im Menü nicht möglich 3=Ein, Zuschalten im Menü nicht möglich)
cnf_join_enable: 1			; Auflegen bei Konferenz (0=Trennt auch die Anderen, 1=Belässt die Verbindung der Anderen (STANDARD))
dnd_control: 0				; Do not Disturb (0=Aus (STANDARD), 1=Ein, 2=Aus, Zuschalten im Menü nicht möglich 3=Ein, Zuschalten im Menü nicht möglich)
enable_vad: 0				; Spracherkennung (0= Aus (STANDARD), 1= Ein)
date_format: D/M/Y			; Datumsdarstellung (M/D/Y (STANDARD), D/M/Y, Y/M/D, Y/D/M)
time_format_24hr: 1			; Zeitformat im Display (0= 12h, 1= 24h (STANDARD), 2= 12h, nicht veränderbar, 3= 24h, nicht veränderbar)
time_zone: CET				; Zeitzone
dst_auto_adjust: 1			; Automatische Sommer-/Winterzeitumstellung (0=Aus, 1= Ein (STANDARD))
dst_offset: 1				; Einstellung für den Sprung der aut. Zeitumstellung (hour/minute, -hour/minute, +hour/minute, hour, -hour, +hour)
dst_start_day: 0			; Tag des Monats des Zeitumstellungsstart (1-31, 0= Ignorieren und dst_start_day_of_week (STANDARD))
dst_start_day_of_week: 1		; Tag der Woche des Zeitumstellungsstart (1=Sonntag - 7=Samstag)
dst_start_month: 4			; Monat des Zeitumstellungsstart (1-12)
dst_start_time: 02			; Uhrzeit des Zeitumstellungsstart (hh:mm)
dst_start_week_of_month: 1		; Woche des Monats des Zeitumstellungsstart (1-6, 8= letzte Woche des Monats)
dst_stop_day: 0				; Tag des Monats des Zeitumstellungsende (1-31, 0= Ignorieren und dst_stop_day_of_week (STANDARD))
dst_stop_day_of_week: 1			; Tag der Woche des Zeitumstellungsende (1=Sonntag - 7=Samstag)
dst_stop_month: 10			; Monat des Zeitumstellungsende (1-12)
dst_stop_time: 2			; Uhrzeit des Zeitumstellungsende (hh:mm)
dst_stop_week_of_month: 8		; Woche des Monats des Zeitumstellungsende (1-6, 8= letzte Woche des Monats)
line1_name: 100
line1_name & line1_authname muessen beim Cisco gleich sein, naemlich der Username. Teste das mal bitte...
PS:
nat_enable: steht meistens auf '1'
hab ich gemacht.... leider ohne Erfolg!
Sobald ich wähle kommt " Reorder "
Das Ding macht noch wahnsinnig...
Mittlerweile bin ich soweit, dass die "Reorder" Meldung weg ist...
Aber mit dem Telefonieren klappts trotzdem nicht.
Bei Sipgate werde ich als online angezeigt und Sipgate erkennt auch die Nummern die ich wähle. Allerdings höre ich nichts... den Freiton ja aber
dann nichts mehr und auf dem Telefon steht: "Calling ( out INV )
dabei bleibt es dann aber auch hängen....
Jemand noch ne Idee ??
die ports hast du auf das cisco geleitet?
ja... UDP 5060 und
UDP 16384 - 32744 ( zum testen )
ChTh
