Bluez-utils won't compile: Kommando nicht gefunden (for Fritzbox 7340 on Ubuntu 12.04
Melchior
14 Okt 2011
Under Freetz 1.2 this works, with trunk it doesn't:
Under fully updated Ubuntu 12.04 in virtualbox chosen Bluez-utils to install in Freetz trunk, completely up to date. Also with 'Replace kernel', but without 'replace kernel' also this problem. First I tried to move dl to dl.bak, make dirclean en distclean gedaan, renamed dl.bak to dl again, but problem stays.
After 'make' it ends with:
/bin/bash: bluez-utils_header_usb_h=no: Kommando nicht gefunden.
make: *** [source/target-mips_uClibc-0.9.32.1/bluez-utils-2.25/.configured] Fehler 127
Anyone any clue as to what is the solution? Maybe a problem with a file in folder 'dl'?
It's not a problem with the dl directory, it's a problem with the implementation of PKG_MAKE_AC_VARIABLES_PACKAGE_SPECIFIC and package names with hyphens.
But is it something I am supposed to be able to solve, or should I just wait until this has been fixed by the programmer of bluez-utils?
I mean, if I don't check bluez-utils, the rest compiles just fine, so the problem lies in the combination bluez-utils -- trunk, as it does compile fine in freetz-1.2.
Actually I just tried it, and configure is started without problems.
Maybe you should report a little more then just the last line. Especially the exact revision number and the output from
make -n bluez-utils-configured
I used this: http://sourceforge.net/projects/freetz-linux/ version 1.3.1
Log Ralffriedl:
mkdir -p source/target-mips_uClibc-0.9.32.1
if [ ! -e source/.echo_item_start ]; then echo -n "---> "; case "BIN" in BIN) echo -n "package/bluez-utils: " ;; LIB) echo -n "library/bluez-utils: " ;; TOOL) echo -n "tool/bluez-utils: " ;; *) echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n "configuring... ";
(conf_cmd() { ./configure "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; cd source/target-mips_uClibc-0.9.32.1/bluez-utils-2.25; rm -f config.{cache,status} ; cp -a ./configure ./configure.before_rpath_fix; sed -i -r -e "s|(runpath_var=)[$]runpath_var|\1|g" -e "s|(hardcode_into_libs=).+$|\1no|g" -e '/hardcode_libdir_flag_spec[_A-Za-z0-9]*=/s/[$][{]wl[}]-?-rpath(,| [$][{]wl[}])[$]libdir/-D__SOMETHING_NON_EMPTY_TO_FOOL_LIBTOOL__/g' -e 's/(hardcode_libdir_flag_spec(_ld)?=)[$]lt_([[][]]_LT_AC_TAGVAR[(])?hardcode_libdir_flag_spec[_A-Za-z0-9]*(, *[$]1[)])?/\1/g' ./configure; sed -i -r -e 's/ac(_cv(_('"header_usb_h|lib_usb_usb_open|lib_usb_usb_get_busses|lib_usb_usb_interrupt_read|header_fuse_h|lib_fuse_fuse_main"')))/'"bluez_utils"'\2/g' ./configure; sed -i -r -e 's/ac(_cv(_('"prog_cc_stdc"')))/'"bluez_utils"'\2/g' ./configure; PATH=""/home/freetz/trunk/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mips_gcc-4.6.3/mips-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games"" CC="/home/freetz/trunk/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc" CXX="/home/freetz/trunk/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-g++-wrapper" CFLAGS="-march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" PKG_CONFIG_PATH="/home/freetz/trunk/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/../lib/pkgconfig" PKG_CONFIG_LIBDIR="/home/freetz/trunk/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/../lib/pkgconfig" GLOBAL_LIBDIR=/home/freetz/trunk/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/usr/lib bluez-utils_header_usb_h=no bluez-utils_lib_usb_usb_open=no bluez-utils_lib_usb_usb_get_busses=no bluez-utils_lib_usb_usb_interrupt_read=no bluez-utils_header_fuse_h=no bluez-utils_lib_fuse_fuse_main=no bluez-utils_prog_cc_stdc=no FREETZ_TARGET_LFS="y" CONFIG_SITE=/home/freetz/trunk/include/site/mips-linux-uclibc conf_cmd --cache-file=/home/freetz/trunk/source/target-mips_uClibc-0.9.32.1/config.cache --target=mips-linux --host=mips-linux --build=i386-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls --with-usb=no --disable-dbus --disable-fuse --disable-obex --disable-alsa --disable-test --disable-cups --disable-pcmcia --disable-initscripts --disable-bccmd --disable-avctrl --disable-hid2hci --disable-dfutool --disable-bcm203x --disable-bluepin --with-bluez="/home/freetz/trunk/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/usr/include" )
touch source/target-mips_uClibc-0.9.32.1/bluez-utils-2.25/.configured
Genau, komipilieren ohne fehler dieses mahl! Vielen dank!
Why do you need this "no isoc" kernel patch?
Can you please list some sizes of the old and the new package and libs?
Regards
Oliver
At the moment I don't use Bluez 4 anymore.
The "no isoc" patch was needed to force the btusb module not to use isochronous modus, since at least the 7270 USB bus does not support this.
If there is some interest in this, I will update the patch for current trunk.
@oliver:
I have updated Bluez to 4.101 for current trunk.
Please note that I have not tested if it still works.
I have added the sizes of required libraries, modules and packages to the wiki page.
