Bei welchen FW-Versionen funktioniert VirtualIP (nicht mehr)?
ich vermisse noch Deinen Syslog-Output. Kannst Du den bitte auch noch anhängen?
ps
PID USER       VSZ STAT COMMAND
    1 root      1308 S    init
    2 root         0 SWN  [ksoftirqd/0]
    3 root         0 SW   [watchdog/0]
    4 root         0 SW<  [events/0]
    5 root         0 SW<  [khelper]
    6 root         0 SW<  [kthread]
   18 root         0 SW<  [kblockd/0]
   32 root         0 SW   [pdflush]
   33 root         0 SW   [pdflush]
   34 root         0 SW<  [kswapd0]
   35 root         0 SW<  [aio/0]
   71 root         0 SW   [pm_info]
   75 root         0 SW<  [CPMAC]
   79 root         0 SW   [mtdblockd]
  101 root         0 SW   [tffsd_mtd_0]
  338 root         0 SWN  [jffs2_gcd_mtd5]
  367 root         0 SW<  [capi_oslib]
  368 root         0 SW<  [capi_oslib]
  369 root         0 SW   [capitransp]
  379 root         0 SW   [avm_dect_thread]
  396 root         0 SW<  [khubd]
  523 root         0 SW<  [scsi_eh_0]
  524 root         0 SW<  [usb-storage]
  548 root     10788 S N  /usr/bin/avm/ctlmgr
  672 root     10788 S N  /usr/bin/avm/ctlmgr
  679 root     10788 S N  /usr/bin/avm/ctlmgr
  682 root     10788 S N  /usr/bin/avm/ctlmgr
  754 root       912 S    ftpd -D -q -t 120 -m 15 -h FRITZ!Box Fon WLAN 7270
  838 root      5120 S    mediasrv
  842 root      4480 S    hostapd -B /var/tmp/hostapd.conf
  843 root      5120 S    mediasrv
  846 root      5120 S    mediasrv
  850 root      5120 S    mediasrv
  855 root      3844 S    usermand
  860 root      4968 S    igdd
  865 root      4048 S    multid
  874 root      4984 S    dsld -i -n
  882 root      8540 S    telefon a127.0.0.1
  887 root      3184 S    dect_manager
  889 root      7748 S <  voipd
  892 root      4068 S    pbd
  893 root      4068 S    pbd
  898 root      4068 S    pbd
  899 root      4068 S    pbd
  902 root       960 S    /bin/run_clock -c /dev/tffs -d
  953 root         0 SWN  [kdsld_token]
  960 root      1304 S    httpd -p 81 -c /mod/etc/httpd.conf -h /usr/mww/ -r Fr
  981 root      1320 S    syslogd -L -C
  983 root      1304 S    /sbin/klogd -c 4
 1049 root      1304 S    inetd
 1181 root      1428 S    /bin/ash /usr/sbin/callmonitor
 1182 root      1304 S    logger -t callmonitor -p daemon.info
 1210 root      1428 S    /bin/ash /usr/sbin/callmonitor
 1211 root      1300 S    sleep 20000d
 1212 root      1304 S    busybox nc 127.0.0.1 1012
 1213 root      1428 S    /bin/ash /usr/sbin/callmonitor
 1215 root      1140 S    dropbear -p 22
 1252 root      1304 S    httpd -p 82 -c /mod/etc/httpd-wol.conf -h /mod/pkg/wo
 1302 root      4968 S    igdd
 1303 root      4968 S    igdd
 1304 root      4968 S    igdd
 1305 root      3120 S N  smbd -D -s /mod/etc/smb.conf
 1307 root      2176 S    nmbd -D -s /mod/etc/smb.conf
 1351 root      1308 S    init
 1810 root      1328 S    httpd -p 81 -c /mod/etc/httpd.conf -h /usr/mww/ -r Fr
 1811 root       860 S    /usr/bin/haserl -u -U /var/tmp /usr/mww/cgi-bin/rudi_
 1812 root      1316 S    /bin/sh
 1816 root      1312 S    sh
 1817 root      1308 S    sed -e s/&/\&amp;/g ; s/</\&lt;/g ; s/>/\&gt;/g
 1818 root      1304 S    head -c 64000
 1819 root      1312 R    ps
bekomme immer noch nicht den apache zum laufen
komme nicht von internet über die dyndns adresse auf den apache drauf
habe die ip: 192.168.178.253 port 80 und 85 freigegeben
und die dyndns adresse auch eingeschrieben geht aber immer noch nicht
:mad:
Die Ausgaben vom Callmonitor im Ringpuffer kannst du löschen. Die gehen wohl niemand von uns was an. ;-)
Sieht für mich so aus als wäre VirtualIP zu früh!?
ifconfig: SIOCSIFNETMASK: Cannot assign requested address
MfG Oliver
Achtung, Du solltest dringend die Callmonitor-Ausgaben löschen!
Moderatoren: Könnt Ihr das bitte evtl. machen?
geht immer noch nicht kann nicht mal einer eine fertige image mir mal zukommen lassen
mfg
Fertige Images dürfen aufgrund der AVM-Lizenzen nicht weitergegeben werden; da es sich wohl um ein Konfigurationsproblem handelt, wird Dir ein fertiges Image auch nicht weiterhelfen.
Benutz mal die Suchfunktion. Es hatte hier schonmal jemand das Problem, dass VirtualIP zu früh gestartet wurde.
MfG Oliver
Hier im THread weiter oben (Beitrag #33) hat doch schonmal jemand geäußert, dass es evtl. Probleme gibt, falls virtualip startet, bevor die Inet-Verbindung steht. Ist da etwas dran?
(sorry, aber ich kann es nicht testen, da ich virtualip nicht mehr verwende)
In diesem Thread geht es um die Startreihenfolge der diversen daemons (u.a. virtualip).
Vielleicht hilft es ja weiter, dort mal reinzuschauen?
nach diesem und den 4 folgenden Posts, muss die DSL-Verbindung stehen.
Du könntest mal den Code porbieren, denn ich für die rc.custom gepostet hatte, das müsste dann funktionieren.
edit: Was mich nur etwas wundert ist:
Wenn das weiterleiten auf die VirtuelleIP nur funktioniert, wenn die VIP nach der Herstellen der Internetverbindung gestartet wird, und nicht nach dem dsld, warum "überlebt" dann das Forwarding die Zwangstrennung?
Wie ist denn die Zwangstrennung implementiert? Wenn der dsld weiterläuft, kann es ja einfach sein, dass er beim ersten Herstellen der Verbindung eine Initialisierung durchführt, die für die Weiterleitung notwendig ist, die bei der Zwangstrennung dann aber bestehen bleibt.
wird wahrscheinlich zu sein ;)
Hmm. Gibt's eigentlich jemand, der VirtualIP mit 'nem aktuellen Trunk auf der 7270 zum Laufen bekommt?
Ich scheitere da leider :-/
Die IP selber funktioniert wahrschienlich, aber die Forwardings nicht. ;)
Hast du mal versucht die autostart raus zu nehmen und die IP erst zu erstellen, wenn das DSL verbunden ist?
Klappt es dann?
Bei mir läufts wunderbar. Zu beachten ist allerdings, was im Wiki dazu steht, mit Ausnahme der Aussage "leider keine Funktion mehr ab Firmware Version 57"
interessantes steht auch 4-5 Posts oben drüber, dass die IP nämlich nach dem herstellen der DSL-Verbindung erstellt werden muss, da sonst der dsld die Forwarding verwirft. :)
Klappt es dann?
Ja, hatte ich - kein Erfolg. (Da war was mit 'nem verzögerten Aufruf in der rc.custom, aber das brachte nix bei mir)
Hab hier im Moment die Original 63'er am Laufen, weil 1&1 rumzickt mit der Umstellung auf VoIP ("geht nicht, falsche FW-Version, machen se dat ma rischdisch!"), wird nach Umstellung sofort wieder umgestellt. Ich verstehe dich richtig, daß auch die 63'er laufen müßte?
ist dieses addon seit der avm firewall inkl. portforwardings denn überhaupt noch für jemanden interessant?
Denn schliesslich kann ich damit ja alles machen was mir vorher virtual ip erledigte und mehr...nur halt verlässlich...
Oder kennen die Avm firewall inkl portforwarding nur zu wenige?
Es gibt sicher noch einsatzgebiete wo man die VIP nutzten kann, sollte. Wenn man vielleicht wirklich noch ne IP für nen Dienst braucht, der sich an IP+Port bindet.
Ist aber sicher sehr spziell.
Die Forwardings sind sicher besser in der AVM-Firewall auf 0.0.0.0:port zu leiten und damit auch stabiler. :)
Kann mal bitte jemand einen Screenshot von der AVM Firewall machen. Am Besten mit Weiterleitungsregeln.
MfG Oliver
Hier mal ein Screenshot der AVM-Firewall Version 2.0.4 rc2 (Ansicht der Forwarding Regeln)
EDIT:
Bild erneuert.
mfg
Wonderdoc
Stripi
