root@fritz:/var/mod/root#
root@fritz:/var/mod/root# dmesg | tail -n 10 ; echo "###lsmod" ; lsmod | grep -e 'ipt\|ip_t\|xt_\|nf_' ; echo -e "\n\n##### VOR ipta
bles mit NAT ####" ;iptables -t nat -L ; echo -e "\n\n##### NACH iptables mit NAT ####" ; dmesg | tail -n 10 ; echo "###lsmod" ;ls
ieee80211_ioctl_siwmode: imr.ifm_active=66176, new mode=3, valid=1
sc nodebug 0
device ath1 entered promiscuous mode
lan: topology change detected, propagating
lan: port 2(ath1) entering forwarding state
system-load 100 % curr: ctlmgr runnable: 6
dfs_attach: use DFS enhancements
DFS min filter rssiThresh = 15
DFS max pulse dur = 151 ticks
stop_current_scan - control chan detects=0 extension channel detects=0 above_dc_detects=0 below_dc_detects=0
###lsmod
##### VOR iptables mit NAT ####
[module-alloc-by-name] give 0xb000 bytes at 0x8166e000 to module 'nf_conntrack'
[module-alloc-by-name] give 0x1000 bytes at 0x81679000 to module 'nf_defrag_ipv4'
[module-alloc-by-name] give 0x3000 bytes at 0x8167a000 to module 'nf_conntrack_ipv4'
[module-alloc-by-name] give 0x4000 bytes at 0x8167d000 to module 'nf_nat'
[module-alloc-by-name] give 0x2000 bytes at 0x81681000 to module 'iptable_nat'
Chain PREROUTING (policy ACCEPT)
target prot opt source destination
Chain POSTROUTING (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
system-load 9 curr: ar7cfgctl runnable: 3
nf_conntrack version 0.5.0 (1903 buckets, 7612 max)
###lsmod
iptable_nat 4688 0
nf_nat 14176 1 iptable_nat
nf_conntrack_ipv4 11264 3 iptable_nat,nf_nat
nf_defrag_ipv4 1184 1 nf_conntrack_ipv4
nf_conntrack 44992 3 iptable_nat,nf_nat,nf_conntrack_ipv4
root@fritz:/var/mod/root# CPU 0 Unable to handle kernel paging request at virtual address 00100140, epc == 8166e684, ra == 8003fb74
Oops[#1]:
Cpu 0
$ 0 : 00000000 00000000 00100100 00000080
$ 4 : 87a56618 87a56a54 ffffb747 1ff2b600
$ 8 : 3b9aca00 0000000d 6a1341a3 00000000
$12 : 7ffffe75 858eb324 ffffffff ffffffff
$16 : 87a56618 8166e658 804c0000 87a56618
$20 : 804b80e8 00200200 804c0000 80373d10
$24 : 00000005 8001f450
$28 : 80370000 80373ce8 00000100 8003fb74
Hi : 000f1bb8
Lo : 00000000
epc : 8166e684 __nf_conntrack_find+0x1c8/0x2b4 [nf_conntrack]
Tainted: P
ra : 8003fb74 run_timer_softirq+0x15c/0x20c
Status: 1100fc03 KERNEL EXL IE
Cause : 00800008 exc_code:2 TLBL
BadVA : 00100140
errepc: 80011cb0 fusiv_restart+0x1bc/0x1c4
Tainted: P
PrId : 0001964c (MIPS 24Kc)
Modules linked in: iptable_nat nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_conntrack ath_pktlog(P) umac userman_mod(P) ath_dev(P) ath_dfs(P) ath_spectral(P) ath_rate_atheros(P) ath_hal(P) asf(P) adf(P) sch_sfq ulpcmlink(P) sch_llq sch_tbf avm_pa_fusiv(P) aae(P) kdsldmod(P) ohci_hcd ehci_hcd usbcore ramzswap lzo_compress lzo_decompress nls_utf8 vfat fat dect_io(P) avm_dect(P) capi_codec(P) isdn_fbox_fon5(P) pcmlink(P) Piglet_noemif(P) bmedrv(P) opensrc_lkm aclap_driver_lkm(P) sysKCode_lkm(P) ethdriver_lkm(P) periap_driver_lkm(P) timers_lkm(P) bmdriver_lkm(P) ap2ap_lkm(P) fusivlib_lkm(P) rtc_avm rtc_core led_modul_Fritz_Box_7390(P)
Process swapper (pid: 0, threadinfo=80370000, task=80374000, tls=00000000)
Stack : 804b9890 80373d38 804b78e0 0000000a 804b78e0 8003fb74 00000000 003d0900
000000e1 1ff2b600 87a56a54 81135478 00000001 0000000a 00000100 804b0000
804b0000 804b7778 804b7774 804c0000 804c0000 8003afdc 000000e1 1ff2b600
00000000 000000e1 1ff2b600 1fb5ce0b 80380000 3b9aca00 1fb5ce0b 80379250
000000e1 80055778 83040000 00010000 86e6b880 6e5bf566 00000000 7fffffff
Call Trace:
[<8166e684>] __nf_conntrack_find+0x1c8/0x2b4 [nf_conntrack]
Code: 00000000 0859b9a7 3c028004 <8c420040> 10400003 00000000 0040f809 00000000 3c028004
Call Trace:
[<802d0688>] dump_stack+0x8/0x38
[<802d07ac>] panic+0x44/0x220
[<8001c3c4>] die+0xd4/0xdc
[<8002290c>] do_page_fault+0x34c/0x5c0
[<80016580>] ret_from_exception+0x0/0x10
Kernel panic - not syncing: Fatal exception in interrupt
WARNING: use tffs in panic mode (minor 96)
Rebooting in 5 seconds..
disabling IRQ's and enabling reset bit in all AP's
(AVM) EVA Revision: 1.819 Version: 1819
(C) Copyright 2005 AVM Date: Dec 2 2009 Time: 10:51:29 (1) 2 0x0-0x340D
[FLASH:] MACRONIX Uniform-Flash 16MB 64 Bytes WriteBuffer
[FLASH:](Eraseregion [0] 128 sectors a 128kB)
[SYSTEM:] IKANOS on 500MHz/166MHz
[RESERVED:] 0x6000000 - 0x6800000
Eva_AVM >
Eva_AVM >
