Initiating file transfer of 'kernel.image' ...
Please be patient, it takes about one minute to erase the mtd1 partition ...
Debugging on (debug=1).
---> TYPE I
---> MEDIA FLSH
'MEDIA FLSH': command not understood.
---> PASV
---> STOR mtd1
---> PASV ]
---> STOR mtd3
---> PASV
---> STOR mtd4
---> SETENV firmware_version avm
'SETENV firmware_version avm': command not understood.
---> SETENV autoload no
'SETENV autoload no': command not understood.
---> SETENV ProductID Fritz_Box_7170
'SETENV ProductID Fritz_Box_7170': command not understood.
---> SETENV HWRevision 106.1.1.0
'SETENV HWRevision 106.1.1.0': command not understood.
---> SETENV kernel_args annex=B
'SETENV kernel_args annex=B': command not understood.
---> SETENV annex B
'SETENV annex B': command not understood.
---> REBOOT
'REBOOT': command not understood.
---> QUIT
Transfer error !
Make sure only one net-card is installed or specify the proper eth0 .. eth9
within speed-to-fritz menu options, WLAN-, IDSN- or TV-cards do count as as well.
If a VM (virtual machine) is in use make sure VM is stared with administrator rights.
Right click on the VM program and select 'Start as administrator'
If no restart on its own, you must reboot your box again.
Waiting for box to shut down and restart ...
Nun warte ich schon über eine halbe Stunde und nichts passiert außer inzwischen 8 Wartezeilen.
~/speed-to-fritz/tools/config/lxdialog/util.c:395: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:398: undefined reference to `waddnstr'
lxdialog/util.o: In function `draw_box':
~/speed-to-fritz/tools/config/lxdialog/util.c:416: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/util.c:435: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:419: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/util.c:419: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:421: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/util.c:421: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:425: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/util.c:425: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:427: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/util.c:427: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:431: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/util.c:431: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:433: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/util.c:433: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:429: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/util.c:429: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:423: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/util.c:423: undefined reference to `waddch'
lxdialog/util.o: In function `draw_shadow':
~/speed-to-fritz/tools/config/lxdialog/util.c:447: undefined reference to `has_colors'
~/speed-to-fritz/tools/config/lxdialog/util.c:449: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/util.c:451: undefined reference to `winch'
~/speed-to-fritz/tools/config/lxdialog/util.c:451: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:453: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/util.c:454: undefined reference to `winch'
~/speed-to-fritz/tools/config/lxdialog/util.c:454: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/util.c:455: undefined reference to `winch'
~/speed-to-fritz/tools/config/lxdialog/util.c:455: undefined reference to `waddch'
lxdialog/util.o: In function `on_key_esc':
~/speed-to-fritz/tools/config/lxdialog/util.c:498: undefined reference to `nodelay'
~/speed-to-fritz/tools/config/lxdialog/util.c:499: undefined reference to `keypad'
~/speed-to-fritz/tools/config/lxdialog/util.c:500: undefined reference to `wgetch'
~/speed-to-fritz/tools/config/lxdialog/util.c:501: undefined reference to `wgetch'
~/speed-to-fritz/tools/config/lxdialog/util.c:503: undefined reference to `wgetch'
~/speed-to-fritz/tools/config/lxdialog/util.c:505: undefined reference to `nodelay'
~/speed-to-fritz/tools/config/lxdialog/util.c:506: undefined reference to `keypad'
~/speed-to-fritz/tools/config/lxdialog/util.c:510: undefined reference to `ungetch'
lxdialog/util.o: In function `attr_clear':
~/speed-to-fritz/tools/config/lxdialog/util.c:247: undefined reference to `wtouchln'
lxdialog/util.o: In function `end_dialog':
~/speed-to-fritz/tools/config/lxdialog/util.c:294: undefined reference to `endwin'
lxdialog/util.o: In function `print_title':
~/speed-to-fritz/tools/config/lxdialog/util.c:307: undefined reference to `waddch'
lxdialog/util.o: In function `print_button':
~/speed-to-fritz/tools/config/lxdialog/util.c:402: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/util.c:457: undefined reference to `wnoutrefresh'
lxdialog/inputbox.o: In function `print_buttons':
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:37: undefined reference to `wmove'
lxdialog/inputbox.o: In function `dialog_inputbox':
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:58: undefined reference to `stdscr'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:64: undefined reference to `COLS'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:65: undefined reference to `LINES'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:69: undefined reference to `newwin'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:70: undefined reference to `keypad'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:75: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:75: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:75: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:77: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:77: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:79: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:79: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:97: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:106: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:111: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:113: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:116: undefined reference to `wgetch'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:177: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:236: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:160: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:161: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:163: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:173: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:134: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:136: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:108: undefined reference to `waddnstr'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:220: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:189: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:190: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:230: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:213: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:214: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:143: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:143: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:144: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:145: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:165: undefined reference to `flash'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:156: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:158: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/inputbox.c:38: undefined reference to `wrefresh'
lxdialog/textbox.o: In function `print_position':
~/speed-to-fritz/tools/config/lxdialog/textbox.c:387: undefined reference to `wbkgdset'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:389: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:390: undefined reference to `wprintw'
lxdialog/textbox.o: In function `print_line':
~/speed-to-fritz/tools/config/lxdialog/textbox.c:328: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:329: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:330: undefined reference to `waddnstr'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:341: undefined reference to `wclrtoeol'
lxdialog/textbox.o: In function `print_page':
~/speed-to-fritz/tools/config/lxdialog/textbox.c:315: undefined reference to `wnoutrefresh'
lxdialog/textbox.o: In function `refresh_text_box':
~/speed-to-fritz/tools/config/lxdialog/textbox.c:43: undefined reference to `wmove'
lxdialog/textbox.o: In function `dialog_textbox':
~/speed-to-fritz/tools/config/lxdialog/textbox.c:67: undefined reference to `stdscr'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:86: undefined reference to `COLS'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:87: undefined reference to `LINES'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:91: undefined reference to `newwin'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:92: undefined reference to `keypad'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:97: undefined reference to `subwin'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:99: undefined reference to `wbkgdset'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:101: undefined reference to `keypad'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:108: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:108: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:108: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:110: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:110: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:112: undefined reference to `wbkgdset'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:113: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:113: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:118: undefined reference to `wnoutrefresh'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:126: undefined reference to `wgetch'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:132: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:133: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:262: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:263: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:167: undefined reference to `scrollok'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:168: undefined reference to `wscrl'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:169: undefined reference to `scrollok'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:176: undefined reference to `wnoutrefresh'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:205: undefined reference to `scrollok'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:206: undefined reference to `wscrl'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:207: undefined reference to `scrollok'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:209: undefined reference to `wnoutrefresh'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:211: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:212: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:256: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:257: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/textbox.c:44: undefined reference to `wrefresh'
lxdialog/yesno.o: In function `print_buttons':
~/speed-to-fritz/tools/config/lxdialog/yesno.c:35: undefined reference to `wmove'
lxdialog/yesno.o: In function `dialog_yesno':
~/speed-to-fritz/tools/config/lxdialog/yesno.c:48: undefined reference to `stdscr'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:54: undefined reference to `COLS'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:55: undefined reference to `LINES'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:59: undefined reference to `newwin'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:60: undefined reference to `keypad'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:65: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:65: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:65: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:67: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:67: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:69: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:69: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:79: undefined reference to `wgetch'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:87: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:112: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:83: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:100: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:96: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:106: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/yesno.c:36: undefined reference to `wrefresh'
lxdialog/menubox.o: In function `do_scroll':
~/speed-to-fritz/tools/config/lxdialog/menubox.c:172: undefined reference to `scrollok'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:173: undefined reference to `wscrl'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:174: undefined reference to `scrollok'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:176: undefined reference to `wrefresh'
lxdialog/menubox.o: In function `print_arrows':
~/speed-to-fritz/tools/config/lxdialog/menubox.c:118: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:122: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:122: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:123: undefined reference to `waddnstr'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:133: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:134: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:142: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:142: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:143: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:143: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:144: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:144: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:145: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:145: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:148: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:138: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:138: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:139: undefined reference to `waddnstr'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:126: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:126: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:127: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:127: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:128: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:128: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:129: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:129: undefined reference to `waddch'
lxdialog/menubox.o: In function `do_print_item':
~/speed-to-fritz/tools/config/lxdialog/menubox.c:78: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:86: undefined reference to `wclrtoeol'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:89: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:89: undefined reference to `waddnstr'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:93: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:93: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:96: undefined reference to `wmove'
lxdialog/menubox.o: In function `print_buttons':
~/speed-to-fritz/tools/config/lxdialog/menubox.c:164: undefined reference to `wmove'
lxdialog/menubox.o: In function `dialog_menu':
~/speed-to-fritz/tools/config/lxdialog/menubox.c:192: undefined reference to `stdscr'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:204: undefined reference to `COLS'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:205: undefined reference to `LINES'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:207: undefined reference to `stdscr'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:209: undefined reference to `newwin'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:210: undefined reference to `keypad'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:215: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:215: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:215: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:217: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:217: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:219: undefined reference to `wbkgdset'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:220: undefined reference to `acs_map'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:220: undefined reference to `waddch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:232: undefined reference to `subwin'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:234: undefined reference to `keypad'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:271: undefined reference to `wnoutrefresh'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:277: undefined reference to `wmove'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:278: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:281: undefined reference to `wgetch'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:378: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:364: undefined reference to `wnoutrefresh'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:365: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:431: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:432: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:388: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:389: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:334: undefined reference to `scrollok'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:412: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:413: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:426: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:427: undefined reference to `delwin'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:149: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:99: undefined reference to `wrefresh'
~/speed-to-fritz/tools/config/lxdialog/menubox.c:165: undefined reference to `wrefresh'
collect2: ld gab 1 als Ende-Status zurück
make[1]: *** [mconf] Fehler 1
make[1]: Verlasse Verzeichnis '~/speed2fritz/tools/config'
make: *** [tools/config/mconf] Fehler 2
You must save configuration to './Firmware.conf' when exiting the menu!
Run './start' again.
