Sun Feb 13 20:32:56 2011 OpenVPN 2.1.1 mipsel-linux [SSL] [LZO2] [EPOLL] [MH] built on Feb 13 2011
Sun Feb 13 20:32:56 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Sun Feb 13 20:32:56 2011 Static Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sun Feb 13 20:32:56 2011 Static Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Feb 13 20:32:56 2011 Static Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sun Feb 13 20:32:56 2011 Static Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Feb 13 20:32:56 2011 LZO compression initialized
Sun Feb 13 20:32:56 2011 TUN/TAP device tun0 opened
Sun Feb 13 20:32:56 2011 TUN/TAP TX queue length set to 100
Sun Feb 13 20:32:56 2011 /sbin/ifconfig tun0 192.168.200.1 pointopoint 192.168.200.2 mtu 1500
Sun Feb 13 20:32:56 2011 Data Channel MTU parms [ L:1545 D:1450 EF:45 EB:135 ET:0 EL:0 AF:3/1 ]
Sun Feb 13 20:32:56 2011 Socket Buffers: R=[110592->131072] S=[110592->131072]
Sun Feb 13 20:32:56 2011 UDPv4 link local (bound): [undef]
Sun Feb 13 20:32:56 2011 UDPv4 link remote: [undef]
Sun Feb 13 20:34:57 2011 Inactivity timeout (--ping-restart), restarting
Sun Feb 13 20:34:57 2011 TCP/UDP: Closing socket
Sun Feb 13 20:34:57 2011 Closing TUN/TAP interface
Sun Feb 13 20:34:57 2011 /sbin/ifconfig tun0 0.0.0.0
Sun Feb 13 20:34:57 2011 SIGUSR1[soft,ping-restart] received, process restarting
Sun Feb 13 20:34:57 2011 Restart pause, 2 second(s)
Sun Feb 13 20:34:59 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Sun Feb 13 20:34:59 2011 Static Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sun Feb 13 20:34:59 2011 Static Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Feb 13 20:34:59 2011 Static Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sun Feb 13 20:34:59 2011 Static Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Feb 13 20:34:59 2011 LZO compression initialized
Sun Feb 13 20:34:59 2011 TUN/TAP device tun0 opened
Sun Feb 13 20:34:59 2011 TUN/TAP TX queue length set to 100
Sun Feb 13 20:34:59 2011 /sbin/ifconfig tun0 192.168.200.1 pointopoint 192.168.200.2 mtu 1500
Sun Feb 13 20:35:00 2011 Data Channel MTU parms [ L:1545 D:1450 EF:45 EB:135 ET:0 EL:0 AF:3/1 ]
Sun Feb 13 20:35:00 2011 Socket Buffers: R=[110592->131072] S=[110592->131072]
Sun Feb 13 20:35:00 2011 UDPv4 link local (bound): [undef]
Sun Feb 13 20:35:00 2011 UDPv4 link remote: [undef]
