M
mase
Guest
Hallo!
Läuft unter Debian Squeeze DAHDI mit HCF Karten nicht mehr richtig?
Im Log steht:
Ein dahdi_cfg -vvvv gibt:
Anrufe funktionieren zwar trotzdem, aber es stottert ziemlich.
Hier meine system.conf:
und meine chan_dahdi.conf:
Im Log steht:
[Feb 13 03:22:21] ERROR[8164] res_timing_dahdi.c: Asterisk has detected a problem with your DAHDI configuration and will shutdown for your protection. You have options:
1. You only have to compile DAHDI support into Asterisk if you need it. One option is to recompile without DAHDI support.
2. You only have to load DAHDI drivers if you want to take advantage of DAHDI services. One option is to unload DAHDI modules if you don't need them.
3. If you need DAHDI services, you must correctly configure DAHDI.
For more information on Asterisk timing modules, including ways to potentially fix this problem, please see doc/timing.txt
DAHDI Version: 2.3.0.1
Echo Canceller(s): OSLEC
Configuration
SPAN 1: CCS/ AMI Build-out: 0 db (CSU)/0-133 feet (DSX-1)
Channel map:
Channel 01: Clear channel (Default) (Echo Canceler: oslec) (Slaves: 01)
Channel 02: Clear channel (Default) (Echo Canceler: oslec) (Slaves: 02)
Channel 03: Hardware assisted D-channel (Default) (Echo Canceler: none) (Slaves: 03)
3 channels to configure.
Setting echocan for channel 1 to oslec
Setting echocan for channel 2 to oslec
Setting echocan for channel 3 to none
span=1,1,0,ccs,ami
bchan=1-2
hardhdlc=3
echocanceller=oslec,1-2
# Global data
loadzone = de
defaultzone = de
[trunkgroups]
[channels]
language=de
switchtype=euroisdn
pridialplan=unknown
prilocaldialplan=unknown
internationalprefix = 00
nationalprefix = 0
;localprefix = VORWAHL
;privateprefix = VORWAHL+MSN
unknownprefix =
priindication = outofband
facilityenable = yes
usecallerid=yes
callwaiting=yes
usecallingpres=yes
callwaitingcallerid=yes
threewaycalling=yes
transfer=yes
canpark=yes
cancallforward=yes
callreturn=yes
immediate=no
echocancel=yes
echocancelwhenbridged=yes
echotraining=yes
callgroup=1
pickupgroup=1
mohinterpret=default
mohsuggest=default
group=1
signalling=bri_cpe_ptmp
; p2p TE mode => bri_cpe
; p2mp TE mode => bri_cpe_ptmp
; p2p NT mode => bri_net
; p2mp NT mode => bri_net_ptmp
context=isdn-in
channel => 1-2
