FBF WLan 7050 und FBF WLan über WDS
enny99
16 Aug 2005
Hallo
Versuche seid Tagen eine FRITZ!Box Fon WLAN 7050 (UI), Firmware-Version 14.03.86 Master und eine FRITZ!BoxFonWLAN, Firmware-Version 08.03.87m4.27 Slave über WDS zu verbinden Internet geht!Aber am Slave kein VoiP(Nicht registriert)!
**** FRITZ!Box CONFIGURATION EXPORT
Password=$$$$MBJNDHVVEYCNUZ1VEXGQSJITJCSXJUFTM6TU2RTEVIQFNQJ1HR1WA5LYQVJ6611EZH2M3YRF1P2K6Y4VVYBT5AAYQPFZOFFDBCCWTGQA
FirmwareVersion=08.03.87
CONFIG_INSTALL_TYPE=ar7_4MB_1eth_2ab_isdn_pots_wlan_43040
OEM=avm
Country=049
**** CFGFILE:ar7.cfg
 * /var/flash/ar7.cfg
 * Sun Sep  8 14:05:27 2002
ar7cfg {
        mode = dsldmode_full_bridge;
        tsdisabled = yes;
        igddenabled = yes;
        igdd_control_enabled = no;
        wan_bridge_with_dhcpc = no;
        wan_bridge_gateway = 192.168.178.1;
        dhcpc_use_static_dns = no;
        ethmode = ethmode_bridge;
        StatisticStartOfMonth = 1;
        macdsl_override = 00:00:00:00:00:00;
        ethinterfaces {
                name = "eth0";
                dhcp = no;
                ipaddr = 192.168.178.2;
                netmask = 255.255.255.0;
                dstipaddr = 0.0.0.0;
                dhcpenabled = no;
                dhcpstart = 0.0.0.0;
                dhcpend = 0.0.0.0;
                name = "eth0:0";
                dhcp = no;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
                name = "eth1";
                dhcp = no;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
                name = "usbrndis";
                dhcp = no;
                ipaddr = 192.168.179.1;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
                name = "wlan";
                dhcp = no;
                interfaces = "tiwlan0", "wdsup0", "wdsdw0", "wdsdw1",
                             "wdsdw2", "wdsdw3";
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
        brinterfaces {
                name = "lan";
                dhcp = no;
                interfaces = "eth0", "usbrndis", "eth1", "tiwlan0", "wdsup0",
                             "wdsdw0", "wdsdw1", "wdsdw2", "wdsdw3";
                dhcpenabled = no;
                dhcpend = 0.0.0.0;
                name = "lan:0";
                dhcp = no;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
        dslinterface {
                name = "dsl";
                dhcp = no;
                netmask = 255.255.255.255;
                dstipaddr = 192.168.179.1;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
        dslinterface_metric = 2;
        pppoefw {
                interfaces = "usbrndis", "eth0", "eth1", "tiwlan0", "wdsup0",
                nofirewall = yes;
                ipnetbiosfilter = yes;
                dnsfilter_for_active_directory = yes;
                hostuniq_filter = "";
                dpconfig {
                        security = dpsec_host;
                        lowinput {
                                policy = "reject";
                                accesslist =
                                             "permit ip any any connection outgoing-related",
                                             "permit ip any any connection incoming-related",
                                             "permit icmp any any";
                        lowoutput {
                                policy = "permit";
                        highinput {
                                policy = "permit";
                        highoutput {
                                policy = "permit";
                                accesslist =
                                             "reject ip any 242.0.0.0 255.0.0.0",
                                             "deny ip any host 255.255.255.255",
                                             "reject ip any 169.254.0.0 255.255.0.0",
                                             "reject udp any any eq 135",
                                             "reject tcp any any eq 135",
                                             "reject udp any any range 137 139",
                                             "reject tcp any any range 137 139",
                                             "reject udp any any range 161 162",
                                             "reject udp any any eq 520",
                                             "reject udp any any eq 111",
                                             "reject udp any any eq 22289",
                                             "reject udp any any eq 1710",
                                             "reject udp any any eq 1048",
                                             "reject udp any any eq 158",
                                             "reject udp any any eq 515",
                                             "reject icmp any 149.1.1.0 255.255.255.0",
                                             "reject tcp any host 202.106.185.127 eq 25";
                        shaper = "globalshaper";
        budget {
                Enabled = no;
                Period = 2;
                VolumeLow = 0;
                VolumeHigh = 0;
                ConnectionTime = 0;
                WarnOnly = yes;
        vccs {
                VPI = 1;
                VCI = 32;
                dsl_encap = dslencap_pppoe;
                ipbridgeing = no;
                connections = "internet";
        dslifaces {
                name = "internet";
                dsl_encap = dslencap_inherit;
                ppptarget = "internet";
                etherencapcfg {
                        use_dhcp = yes;
                        ipaddr = 0.0.0.0;
                        netmask = 0.0.0.0;
                        gateway = 0.0.0.0;
                        dns1 = 0.0.0.0;
                        dns2 = 0.0.0.0;
                stay_always_online = no;
                redial_delay_after_auth_failure = 1m;
                redial_limit = 3;
                redial_after_limit_reached = 1h;
                username_prefix_after_auth_failure = "";
                dsldpconfig {
                        security = dpsec_firewall;
                        lowinput {
                                policy = "permit";
                                accesslist =
                                             "deny ip any 242.0.0.0 255.0.0.0",
                                             "deny udp any any eq 135",
                                             "deny tcp any any eq 135",
                                             "deny udp any any range 137 139",
                                             "deny tcp any any range 137 139",
                                             "deny udp any any range 161 162",
                                             "deny udp any any eq 520",
                                             "deny udp any any eq 111",
                                             "deny udp any any eq 22289",
                                             "deny udp any any eq 1710",
                                             "deny udp any any eq 1048",
                                             "deny udp any any eq 158",
                                             "deny udp any any eq 515";
                        lowoutput {
                                policy = "permit";
                        highinput {
                                policy = "permit";
                        highoutput {
                                policy = "permit";
                                accesslist =
                        forwardrules = "tcp 0.0.0.0:0 0.0.0.0:0 1 out",
                                       "udp 0.0.0.0:0 0.0.0.0:0 1 out",
                                       "udp 0.0.0.0:5060 0.0.0.0:5060",
                                       "udp 0.0.0.0:7078 0.0.0.0:7078",
                                       "udp 0.0.0.0:7079 0.0.0.0:7079",
                                       "udp 0.0.0.0:7080 0.0.0.0:7080",
                                       "udp 0.0.0.0:7081 0.0.0.0:7081",
                                       "udp 0.0.0.0:7082 0.0.0.0:7082",
                                       "udp 0.0.0.0:7083 0.0.0.0:7083",
                                       "udp 0.0.0.0:7084 0.0.0.0:7084",
                                       "udp 0.0.0.0:7085 0.0.0.0:7085",
                                       "# tcp 0.0.0.0:21 192.168.178.20:21 0 # FTP-Server",
                                       "# tcp 0.0.0.0:80 192.168.178.20:80 0 # HTTP-Server",
                                       "# tcp 0.0.0.0:4662 192.168.178.20:4662 0 # eMule",
                                       "# udp 0.0.0.0:4672 192.168.178.20:4672 0 # eMule",
                                       "# tcp 0.0.0.0:3389 192.168.178.20:3389 0 # MS Remote Desktop";
                name = "voip";
                ppptarget = "voip";
                etherencapcfg {
                        use_dhcp = yes;
                        ipaddr = 0.0.0.0;
                        netmask = 0.0.0.0;
                        gateway = 0.0.0.0;
                        dns1 = 0.0.0.0;
                        dns2 = 0.0.0.0;
                stay_always_online = yes;
                redial_limit = 3;
                dsldpconfig {
                        lowinput {
                                policy = "permit";
                                accesslist = "permit udp any any",
                                             "permit icmp any any",
                                             "reject ip any any";
                        lowoutput {
                                policy = "permit";
                        highinput {
                                policy = "permit";
                        highoutput {
                                policy = "permit";
                                       "udp 0.0.0.0:7085 0.0.0.0:7085";
        voip_routes = "permit ip any any connection exists",
                      "permit udp any eq 5060 any",
                      "permit udp any eq 7077 any eq 53",
                      "permit udp any range 7078 7085 any";
        targets {
                type = pppcfg_target_internet;
                name = "internet";
                only_crypt_auth = no;
                local {
                        username = "";
                        passwd = "";
                remoteauth = pppcfg_authtype_chap;
                remoteauth_only_on_incoming = yes;
                remote {
                inactivity_timeout = 5m;
                bUseChargeInterval = no;
                nChargeInterval = 1m;
                logicaldisconnect_with_physical = yes;
                disconnect_timeout = 0w;
                finaldisconnectcall = no;
                ipnetbiosspoofing = no;
                dnsfilter_for_active_directory = no;
                no_outgoing_calls = no;
                coso = pppcfg_coso_caller;
                callback_delay = 1s;
                icbmode = pppcfg_icbmode_none;
                ocbmode = pppcfg_ocbmode_none;
                mscbprefered = no;
                multilink {
                        extra_static_channels = 0;
                        max_channels = 1;
                        automatic = no;
                        automatic_param {
                                window = 20s;
                                add_percent = 85;
                                drop_percent = 70;
                                sportlich = no;
                header_compression = yes;
                data_compression = pppcfg_datacomp_auto;
                stac_reset_with_history_number = no;
                encryption = pppcfg_crypt_none;
                inactivity_prevention_interval = 0w;
                new_ipaddr_on_connect = no;
                my_ipaddr = 0.0.0.0;
                his_ipaddr = 0.0.0.0;
                bVolumeRoundUp = no;
                VolumeRoundUpBytes = 0;
                bProviderDisconnectPrevention = yes;
                ProviderDisconnectPreventionInterval = 1d;
                ProviderDisconnectPreventionHour = 3;
                name = "voip";
                local {
                        username = "";
                        passwd = "";
                remote {
                inactivity_timeout = 0w;
                mscbprefered = no;
                multilink {
                        max_channels = 1;
                        automatic = no;
                        automatic_param {
                                window = 20s;
                                add_percent = 85;
                                drop_percent = 70;
                                sportlich = no;
        dslglobalconfig {
                autodetect = no;
                pppoeiface = "eth0";
                speed_in_netto = 3000;
                speed_out_netto = 400;
                connect_delay_when_synced = 3s;
                templates {
                        VPI = 1;
                        VCI = 32;
                        manu = 0;
                        VPI = 8;
                        VCI = 35;
                        manu = 0;
                        VPI = 8;
                        VCI = 48;
                        manu = 0;
                        encap = dslencap_pppoa;
                        VPI = 8;
                        VCI = 48;
                        manu = 0;
                        encap = dslencap_pppoa_llc;
                        VPI = 8;
                        VCI = 67;
                        manu = 0;
                        VPI = 8;
                        VCI = 67;
                        manu = 0;
                        VPI = 8;
                        VCI = 64;
                        manu = 0;
                        VPI = 8;
                        VCI = 36;
                        manu = 0;
                        VPI = 0;
                        VCI = 35;
                        manu = 0;
                        VPI = 0;
                        VCI = 35;
                        manu = 0;
                        VPI = 9;
                        VCI = 35;
                        manu = 0;
                        VPI = 0;
                        VCI = 32;
                        manu = 0;
                        VPI = 0;
                        VCI = 32;
                        manu = 0;
                        VPI = 0;
                        VCI = 32;
                        manu = 0;
                        VPI = 0;
                        VCI = 34;
                        manu = 0;
                        VPI = 0;
                        VCI = 34;
                        manu = 0;
                        VPI = 0;
                        VCI = 34;
                        manu = 0;
                        VPI = 0;
                        VCI = 30;
                        manu = 0;
                        VPI = 8;
                        VCI = 32;
                        manu = 0;
                        VPI = 8;
                        VCI = 32;
                        manu = 0;
                        VPI = 8;
                        VCI = 32;
                        manu = 0;
                        VPI = 0;
                        VCI = 38;
                        manu = 0;
                        VPI = 0;
                        VCI = 38;
                        manu = 0;
                        VPI = 8;
                        VCI = 35;
                        manu = 0;
                        VPI = 8;
                        VCI = 35;
                        manu = 0;
                        VPI = 0;
                        VCI = 81;
                        manu = 0;
                        VPI = 0;
                        VCI = 81;
                        manu = 0;
                        VPI = 0;
                        VCI = 81;
                        manu = 0;
                        VPI = 8;
                        VCI = 81;
                        manu = 0;
                        VPI = 8;
                        VCI = 81;
                        manu = 0;
                        VPI = 8;
                        VCI = 81;
                        manu = 0;
                        VPI = 0;
                        VCI = 100;
                        manu = 0;
                        VPI = 0;
                        VCI = 100;
                        manu = 0;
                        VPI = 0;
                        VCI = 100;
                        manu = 0;
        shapers {
                name = "globalshaper";
                OutFragmentWhenVoIP = 0;
                shaperconnection {
                        enabled = yes;
                        targets = "";
                        name = "Fritz!Box";
                        limiters {
                                name = "default-out";
                                bps_limit {
                                        limit_total = 100;
                                        limit_p0 = 0;
                                        limit_p1 = 95;
                                        limit_p2 = 95;
                                        limit_p3 = 0;
                                pps_limit {
                                        limit_total = 0;
                                        limit_p0 = 0;
                                        limit_p1 = 0;
                                        limit_p2 = 0;
                                        limit_p3 = 0;
                                min_priority = 0;
                                max_priority = 3;
                                grouping_by_source_ip = no;
                                grouping_by_dest_ip = no;
                                grouping_by_source_port = no;
                                grouping_by_dest_port = no;
                                dynamic_balancing = no;
                                bps_child_limit {
                                        limit_total = 0;
                                        limit_p0 = 0;
                                        limit_p1 = 0;
                                        limit_p2 = 0;
                                        limit_p3 = 0;
                                pps_child_limit {
                                        limit_total = 0;
                                        limit_p0 = 0;
                                        limit_p1 = 0;
                                        limit_p2 = 0;
                                        limit_p3 = 0;
                                shapeOutgoingOnIncomingCounters = no;
                                name = "default-in";
                                bps_limit {
                                        limit_total = 0;
                                        limit_p0 = 0;
                                        limit_p1 = 0;
                                        limit_p2 = 0;
                                        limit_p3 = 0;
                                pps_limit {
                                        limit_total = 0;
                                        limit_p0 = 0;
                                        limit_p1 = 0;
                                        limit_p2 = 0;
                                        limit_p3 = 0;
                                min_priority = 0;
                                max_priority = 0;
                                bps_child_limit {
                                        limit_total = 0;
                                        limit_p0 = 0;
                                        limit_p1 = 0;
                                        limit_p2 = 0;
                                        limit_p3 = 0;
                                pps_child_limit {
                                        limit_total = 0;
                                        limit_p0 = 0;
                                        limit_p1 = 0;
                                        limit_p2 = 0;
                                        limit_p3 = 0;
                        out_rules {
                                name = "download-tcp-ack";
                                filter = "tcp and len <= 64";
                                priority = 2;
                                limiters = "default-out";
                                name = "dns";
                                filter = "udp port 53";
                                priority = 1;
                                name = "fon-rtp";
                                filter = "udp[8] = 0x80 or udp port 5060";
                                priority = 3;
                                name = "http-requests";
                                filter = "(tcp dst port 80 or dst port 8080 or dst port 3128) and (len <= 800)";
                                priority = 1;
                                name = "pri-out";
                                filter = "icmp";
                                priority = 1;
                                name = "default";
                                filter = "";
                                priority = 0;
                        in_rules {
                                name = "default";
                                filter = "";
                                priority = 0;
                                limiters = "default-in";
                        demasquerade = no;
        RunVoIPDSLAutodetect = 0;
servercfg {
        dns1 = 192.168.178.1;
        dns2 = 0.0.0.0;
websrv {
        port = "80";
        read_timeout = 15m;
        request_timeout = 30s;
        keepalive_timeout = 5m;
        nokeepalive = "*";
        errordir = "/usr/lib/websrv/errors";
        webdir = "/usr/www";
        cgidir = "cgi-bin";
        indexfn = "index.var", "index.htm", "index.html";
dhcpserver {
        saveinterval = 1h;
        generic {
                default_lease_time = 10d;
                max_lease_time = 13d;
dhcpclient {
        metric = 9;
dnsserver {
        cache_maxKB = 16;
        negative_ttl = 5m;
ddns {
        accounts {
                enabled = no;
                domain = "";
                iface = 0;
                username = "";
                passwd = "";
                ddnsprovider = "dyndns.org";
        types {
                type = "dyndns";
                url = "/nic/update?system=dyndns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
                type = "dyndns-custom";
                url = "/nic/update?system=custom&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
                type = "dyndns-statdns";
                url = "/nic/update?system=statdns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
                type = "noip";
                url = "/ducupdate.php?update=<b64>username=<username>&pass=<pass>&h[]=<domain>&ip=<ipaddr></b64>";
                type = "2mydns";
                url = "/dyn.asp?username=<username>&password=<pass>&hostname=<domain>&myip=<ipaddr>";
                type = "dns4biz";
                url = "/nic/update?hostname=<domain>&myip=<ipaddr>";
                type = "selfhost";
                url = "/nic/update?myip=<ipaddr>";
                type = "userdefined";
                url = "";
        provider {
                name = "dyndns.org";
                type = "dyndns";
                livedelay = 0w;
                touchtime = 30d;
                server = "members.dyndns.org";
                infourl = "http://www.dyndns.org/";
                name = "dyndns.org-custom";
                livedelay = 0w;
                touchtime = 30d;
                name = "dyndns.org-statdns";
                livedelay = 0w;
                touchtime = 30d;
                name = "No-IP.com";
                type = "noip";
                livedelay = 4m;
                touchtime = 0w;
                server = "dynupdate.no-ip.com:8245";
                infourl = "http://www.no-ip.com/";
                name = "2myDNS";
                type = "2mydns";
                livedelay = 0w;
                touchtime = 0w;
                server = "dyn.2mydns.com";
                infourl = "http://www.2mydns.com/";
                name = "DNS4BIZ.DE Premium";
                type = "dns4biz";
                livedelay = 0w;
                touchtime = 0w;
                server = "au-eu.dns4biz.net";
                infourl = "http://www.dns4biz.com/services_avm.php3";
                name = "DNS4BIZ.DE Business";
                type = "dns4biz";
                livedelay = 0w;
                touchtime = 0w;
                server = "au-eu.dns4biz.biz";
                name = "selfhost.de";
                type = "selfhost";
                livedelay = 0w;
                touchtime = 0w;
                server = "carol.selfhost.de";
                infourl = "http://www.selfhost.de";
                name = "Benutzerdefiniert";
                livedelay = 4m;
                touchtime = 0w;
                server = "";
                infourl = "http://";
webui {
        username = "";
        password = "";
        expertmode = yes;
        wizard_completed = no;
capiovertcp {
        enabled = no;
        maxctrl = 1;
        port = 5031;
emailnotify {
        enabled = no;
        interval = daily;
        From = "";
        To = "";
        SMTPServer = "";
        accountname = "";
        passwd = "";
usbhost {
        readonly = no;
        password = "";
        autoprov_enabled = yes;
ntpclient {
        server_list = "0.europe.pool.ntp.org";
// EOF
**** END OF FILE ****
**** CFGFILE:voip.cfg
 * /var/flash/voip.cfg
 * Sun Sep  8 14:02:12 2002
voipcfg {
        dnsport = 7077;
        rtpport_start = 7078;
        ua1 {
                enabled = yes;
                username = "$$$$BLUBB";
                authname = "";
                passwd = "$$$$BLA";
                registrar = "sip.web.de";
                ttl = 30m;
                sipping_enabled = yes;
                sipping_interval = 280s;
                name = "01212320xxxxxx";
                authenticatemode = authenticate_mode_none;
                infodtmfnotsupported = no;
                register_failwaitmax = 30m;
                stunserver = "";
                stunserverport = 3478;
                is_nat_aware = no;
                clirtype = clir_displayname;
                only_one_dialog = no;
                presence_supported = no;
                mwi_supported = yes;
                tx_packetsize_in_ms = 30;
        ua2 {
                enabled = no;
                username = "";
                authname = "";
                passwd = "";
                registrar = "";
                ttl = 30m;
                name = "";
                stunserver = "";
                is_nat_aware = no;
        use_audiocodecs = no;
        audiocodecs = "PCMA", "PCMU", "G726-32", "G726-40", "G726-24";
        verbose = no;
        sip_prio = 0;
        rtp_prio = 0;
        dyn_codecs = yes;
        send_ringtone = no;
        enum_support_enabled = no;
        enumdomains = "e164.arpa", "e164.org";
        rtpstream {
                voice_activity_detection {
                        enabled = no;
                        vad_threshold = 10000;
                generate_noise {
                        on_packetloss = no;
                        on_capi_underrun = yes;
                jitter {
                        auto_on = yes;
                        in_ms = 50;
                        in_packets = 0;
// EOF
**** CFGFILE:wlan.cfg
 * /var/flash/wlan.cfg
 * Sun Sep  8 14:13:05 2002
wlancfg {
        ap_enabled = 1;
        channel = 1;
        ssid = "Fritz.box";
        hidden_ssid = 0;
        power_level = 1;
        bg_mode = 0;
        user_isolation = 0;
        encryption = 1;
        passwd = "";
        wep_auth_type = "open";
        allowSharedKeyAuth = yes;
        key_id = 0;
        key_value0 = "$$$$G1DBFXLD6DPCXP3KRPZK1O5ZLK6OZ5663YJSKS5MDOLJ4LTBYSEG3PI2UGNSBT5X1TGQBWJ3OIHPGJAIM2OYXGPMHIBTI1BDCFHQDVQA";
        key_len0 = 13;
        key_value1 = "$$$$G6H3O2KV2FF2RURJ3SI2G23DMBHWFTT6J6U1YR1WXYJHJMMW1XTYRYATBQ6CFVILKAFJBQ13ESSJGM1RFBGCZQ1WPRDLPPGOIPXJNLQA";
        key_len1 = 13;
        key_value2 = "$$$$2QGGCE52FCATCAWM4HKPLTLFVDUPQ1EUGIZ433GHHOZ2QNWQZ5MB43I1WTFTJXWWDPHNBRAWGM13T62NFKFENWHDUNBPWUGKV5LOLUQA";
        key_len2 = 13;
        key_value3 = "$$$$F4SSYC2SRUPU2NVAP13GY1EMMFEZTBHXIO3XZGZ2FTDBZE4Q5NROT6TT3WEY6Y4XXU2NPHJE4PO2FHGFEMMQWL6HRJJS3KG1BFGKNPYA";
        key_len3 = 13;
        pskvalue = "";
        interval = 3600;
        turbomode = yes;
        WDS_enabled = yes;
        WDS_hop = 1;
        WDS_mac_master = 00:04:0E:72:47:0E;
        WDS_mac_slave0 = 00:00:00:00:00:00;
        WDS_mac_slave1 = 00:00:00:00:00:00;
        WDS_mac_slave2 = 00:00:00:00:00:00;
        WDS_mac_slave3 = 00:00:00:00:00:00;
        WDS_encryption = 1;
        WDS_key = "";
kann mir jemand helfen ?
enny99
@dm41
Danke wahr wohl schon etwas spät gestern!
Hatt keiner einen Tipp für mich
Master FBF Wlan 7050 hatt 192.168.178.1
Slave FBF Wlan hatt 192.168.178.2
DHCP am Slave ist aus!
Hallo enny!
Der VoIP-Dienst baut die Verbindung über das DSL-Interface auf.
Darum muss das DSL-Interface auf das WLAN umgebogen werden:
Unter System / Netzwerkeinstellungen / IP-Adressen: "Alle Computer befinden..." markieren
Per Telnet die ar7.cfg editieren:
1. "mode = dslmode_bridge"
2. "wan_bridge_gateway = 192.168.178.2"
3. "dslinterface {
name = "dsl";
dhcp = yes;
4. "dslglobalconfig {
pppoeiface = "tiwlan0";
Neu starten!
Das DSL-Interface bekommt jetzt eine IP von der 7050 und kann somit eine Internet-Verbindung aufbauen.
Eventuell müssen bei der 7050 noch einige Ports geöffnet werden. Oder du vergiebst der FBF eine fest IP (ar7.cfg unter dslinterface) und stellst die IP in der 7050 als "Exposed Host" ein.
Edit: Mit der festen IP scheint so nicht zu funktionieren ... muss ich noch mal testen. Also wie beschrieben DHCP am DSL-Interface aktivieren.
Gruß Chili
@chili
Danke jetzt geht VoiP!!!!!!!!!Super!!!!!!!!!
aber leider komme ich nicht mehr auf die Box weder Lan noch USB!
Hasst du noch einen vorschlag?
Habe jetzt mal die 2. "wan_bridge_gateway = 192.168.178.2"
auf 192.168.178.1 gesetz kann die Box wieder erreichen und alles funst!!!
nochmal danke an chili
Woher hast du denn die 08.03.87 ?
Die gibts doch gar nicht oder ?
Carlos
@carlos
Doch gibt es aber nur als .mod und nur für die alte FBF WLan ohne 7050!
läuft aber auch mit 08.03.73
gruß enny99
Stelle hier mal zusammen wie ich es bei mir zum laufen bekommen habe FRITZ!Box Fon WLAN 7050 (UI), Firmware-Version 14.03.86 Master
FRITZ!BoxFonWLAN, Firmware-Version 08.03.87m4.27 Slave über WDS mit VoiP(läuft aber auch mit 08.03.73)
da ich danach gefragt wurde!
Erst eimal vielen Dank an @Darkwing, @Chili ,@olistudentund und alle anderen ohne die das wohl nie etwas geworden wäre!
Hardware:
FRITZ!Box Fon WLAN 7050 (192.168.178.1)
FRITZ!BoxFonWLAN (192.168.178.2)
Software:
FBEditor04ß
Config WLan 7050 Master:
                                       "tcp 0.0.0.0:21 192.168.178.20:21 0 # FTP-Server",
                                       "tcp 0.0.0.0:80 192.168.178.20:80 0 # HTTP-Server",
                                       "tcp 0.0.0.0:4662 192.168.178.20:4662 0 # eMule",
                                       "udp 0.0.0.0:4672 192.168.178.20:4672 0 # eMule",
                                       "# tcp 0.0.0.0:3389 192.168.178.20:3389 0 # MS Remote Desktop",
                                       "udp 0.0.0.0:3478+2 192.168.178.25:80 0 # UDP",
                                       "udp 0.0.0.0:5060+5 192.168.178.25:80 0 # UDP2",
                                       "udp 0.0.0.0:5070+3 192.168.178.25:80 0 # UDP3",
                                       "udp 0.0.0.0:7077+5 192.168.178.25:80 0 # UDP4",
                                       "udp 0.0.0.0:30000+6 192.168.178.25:80 0 # UDP5",
                                       "udp 0.0.0.0:9999+11 192.168.178.25:80 0 # UDP6",
                                       "udp 0.0.0.0:5000+11 192.168.178.25:80 0 # UDP7";
WDS_enabled = yes;
        WDS_hop = 0;
        WDS_mac_master = FBF WLan 7050
        WDS_mac_slave0 = FBF WLan ;
        WDS_encryption = 0;
        WDS_key = "WEP HEX der 7050";
Config FBF WLan Slave:
ar7cfg {
        mode = dsldmode_bridge;
        tsdisabled = yes;
        igddenabled = yes;
        ethinterfaces {
                name = "eth0";
                dhcp = no;
                dhcpenabled = no;
                dhcpend = 0.0.0.0;
        brinterfaces {
                name = "lan";
                dhcp = no;
                dhcpenabled = no;
                dhcpend = 0.0.0.0;
                name = "lan:0";
                dhcp = no;
                ipaddr = 192.168.178.254;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
        dslinterface {
                name = "dsl";
                dhcp = no;
                ipaddr = 192.168.178.1;
                dstipaddr = 192.168.178.1;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
        pppoefw {
                nofirewall = yes;
                dpconfig {
                        lowinput {
                                policy = "reject";
                                accesslist =
                        lowoutput {
                                policy = "permit";
                        highinput {
                                policy = "permit";
                        highoutput {
                                policy = "permit";
                                accesslist =
        budget {
                Enabled = no;
                Period = 2;
                VolumeLow = 0;
                VolumeHigh = 0;
                ConnectionTime = 0;
                WarnOnly = yes;
        vccs {
                VPI = 1;
                VCI = 32;
                ipbridgeing = no;
                connections = "internet", "voip";
        dslifaces {
                name = "internet";
                etherencapcfg {
                        use_dhcp = yes;
                        ipaddr = 0.0.0.0;
                        netmask = 0.0.0.0;
                        gateway = 0.0.0.0;
                        dns1 = 0.0.0.0;
                        dns2 = 0.0.0.0;
                redial_limit = 3;
                dsldpconfig {
                        lowinput {
                                policy = "permit";
                                accesslist =
                        lowoutput {
                                policy = "permit";
                        highinput {
                                policy = "permit";
                        highoutput {
                                policy = "permit";
                                accesslist =
                name = "voip";
                ppptarget = "voip";
                etherencapcfg {
                        use_dhcp = yes;
                        ipaddr = 0.0.0.0;
                        netmask = 0.0.0.0;
                        gateway = 0.0.0.0;
                        dns1 = 0.0.0.0;
                        dns2 = 0.0.0.0;
                redial_limit = 3;
                dsldpconfig {
                        lowinput {
                                policy = "permit";
                        lowoutput {
                                policy = "permit";
                        highinput {
                                policy = "permit";
                        highoutput {
                                policy = "permit";
        dslglobalconfig {
                autodetect = yes;
                speed_in_netto = 1024;
                speed_out_netto = 128;
                manual_speed = no;
servercfg {
        hostname = "(none)";
        dns1 = 192.168.180.1;
        dns2 = 192.168.180.2;
websrv {
        port = "80";
        read_timeout = 15m;
        nokeepalive = "*";
        cgidir = "cgi-bin";
dhcpserver {
        saveinterval = 1h;
        generic {
dhcpclient {
        metric = 9;
dnsserver {
        cache_maxKB = 16;
        negative_ttl = 5m;
capiovertcp {
        enabled = no;
        maxctrl = 1;
        port = 5031;
// EOF
 * Wed Oct 26 13:40:59 2005
voipcfg {
        dnsport = 7077;
        verbose = no;
        sip_prio = 0;
        rtp_prio = 0;
        dyn_codecs = yes;
        prio_low_codec = no;
        send_ringtone = no;
        blacklist = no;
        rtpstream {
                        enabled = no;
                generate_noise {
                jitter {
                        auto_on = yes;
                        in_ms = 50;
                        in_packets = 0;
// EOF
 * Sun Sep  8 14:07:38 2002
wlancfg {
        ap_enabled = 1;
        channel = 1;
        ssid = "gleiche wie7050";
        hidden_ssid = 0;
        power_level = 0;
        bg_mode = 0;
        user_isolation = 0;
        encryption = 1;
        passwd = "";
        allowSharedKeyAuth = no;
        key_id = 0;
        key_value0 =
        key_len3 = 13;
        pskvalue = "";
        interval = 3600;
        turbomode = yes;
        WDS_enabled = yes;
        WDS_hop = 1;
        WDS_mac_master = FBF WLan 7050;
        WDS_encryption = 1;
        WDS_key = WEP HEX der 7050;
        night_time_control_enabled = no;
Ich habe es so gemacht erst Internet mit WDS zum laufen bringen und dann VoiP!
VoiP:
1und1
Web.de
sipNetworks.de
alle drei laufen bei mir am Slave!
gruß enny99
Also bei mir funktioniert das nicht.
Folgendes wird bei mir angezeigt:
Status: verbunden
IP-Adresse 0.0.0.0
Status Internet-Rufnummer XXXXX: Nicht registriert
Habe meine ar7.cfg so eingestellt wie in deinem Beispiel.
Carlos
Ich habe das eben gerade mal probiert.
Master: 7050 14.03.86
Slave : Fon Wlan 08.03.73
Ging bei mir erst auch nicht.
Hatte da einen GMX Account eingebunden.
Kam immer :Nicht Registriert.
Dann habe ich es mal mit Voipbuster und Sipsnip probiert.
Die waren dann auch sofort beide registriert.
Und telefonieren ging auch über beide.
Also, bei mir jetzt alles OHNE Probleme :)
Die Slave Box habe ich wie in unten stehender Anleitung beschrieben
editiert! Sonst nix.......
Habe dafür den FBEditor genommen !
  • voip_per_wds_160.pdf
@charlos
Status: verbunden
IP-Adresse 0.0.0.0
steht bei mir auch !
1und1 geht
web.de geht
interfoni(sipNetworks.de) geht auch !
läuft jetzt seid 100 Stunden ohne Probleme!
Gruß enny99
Seltsam, jetz habe ich bei web.de einen account der funktioniert.
GMX und 1und1 gehen nicht.
Also an der Konfiguration scheint es dann nicht zu liegen.
Carlso
@carlos
1und1 und GMX einstellungen voipcfg!
dnsport = 7077;
        ua1 {
                enabled = no;
                username = "$$$$";
                authname = "";
                passwd = "$$$$";
                registrar ="1und1.de";--------------
                ttl = 30m;
                sipping_enabled = yes;---------------
                name = "Rufnummer_Ohne_Vorwahl";----------------
                authenticatemode =authenticate_mode_allow;------
                stunserver ="1und1.de";-----------------
                is_nat_aware = no;
                reject_refer = yes;
                no_register_fetch = no;
                outboundproxy = "";
Änderungen sind mit ------- makiert!!
Gruß enny99
habe dank Enny99 und chili auch Voip über 1und1 am Slave (FBFWLAN mit 73er FW) zum laufen bekommen.
Was noch fehlte in Chilis Anleitung:
1. Die Portfreigaben auf dem Master
2. Beim Slave in der Voipcfg bei stunserver ="1und1.de" eintragen.
Bei mir läuft es wunderbar.
Kann nur keine Sondernummern vom Slave anrufen (018, 0800) selbst wenn ich die Wahlregeln dafür ausschalte.
@suchmeister
Service Nummer sind über 1und1 nicht Wählbar da das bei 1und1 und auch bei Wep.de nicht vorgesehen ist!
Musst du dir noch einen zweiten Anbieter holen z.b. SipNetworks.de !
Gruß enny99
Geht dass dann auch wenn ich einen anderen Router als WDS Host nutze?
denke da an einen Sinus 154 Basic SE
Und kann mal jemand sagen welche ports ich genau weiterleiten muss?
Oder wird das mit der Aktuellen Firmware schon alles automatisch unterstützt und ich habe mir das umsonst durchgelesen :p (hoffentlich)
Gruß ika
Panicmaker
