Würde eine Fritzbox stabiler laufen?
Chefkoch85
26 Mai 2008
Da aufgrund der relativ hohen Dämpfung mein O2 Router ständig die Verbindung verloren hat, reduzierte jetzt mein DSL Profile auf die Hälfte.
Die Dämpfungswerte sehen folgendermaßen aus:
noise margin upstream: 17 db
output power downstream: 18 db
attenuation upstream: 24 db
tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 32- 63: 88 88 88 88 87 77 77 77 65 55 65 43 20 20 00 00
tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
noise margin downstream: 19 db
output power upstream: 12 db
attenuation downstream: 47 db
tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 64- 95: 00 23 45 55 55 55 66 77 77 77 77 77 77 76 77 76
tone 96-127: 25 55 56 66 66 66 65 66 66 65 55 55 55 55 55 55
tone 128-159: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
tone 160-191: 55 55 50 55 55 55 43 44 44 44 44 44 44 44 44 44
tone 192-223: 44 34 43 23 34 43 43 33 32 44 32 33 33 33 22 22
tone 224-255: 32 22 22 32 22 02 23 22 22 22 02 22 22 22 00 20
tone 256-287: 00 21 20 10 00 00 00 00 00 00 00 00 00 00 00 00
Meint ihr, eine Fritzbox könnte bei meinem alten Profil eine stabile Verbindung herstellen?
würde wenn dann eine Fritzbox mit externem Sphairon oder Speedtouch Modem an Lan A nutzen, den meine erfahrung mit den integrierten Fritzbox modems bei schlechteren leitungen sind nicht grad die besten.
Ich kann Dir ziemlich sicher mit "Nein" antworten.
tioan hat das ja ebenfalls schon so gesagt.
Das interne DSL-Modem der FritzBoxen ist nicht sehr gut. Mit schwachem DSL-Signal hat es Mühe.
Einzig das Modem der neuen FB7270/7240 scheint verbessert zu sein.
Dennoch: In Deiner Situation empfehle ich, ein einfaches DSL Modem (Zyxel, Speedtouch oder vergleichbares) vor die FB (bzw. den O2-Router) zu schalten und letzteren über LAN mit dem Modem zu verbinden.
Die FB muss auf "Internetzugang über LAN1" konfiguriert werden (im Menu "Internet" - "Zugangsdaten").
Danke für eure Rätschläge, aber ich glaube, dann lass ich einfach das UFO dran, bzw. wechsel zu nem Kabelprovider... ADSL suckt bei mir total :mad:
Waterhome
