reset
reset<NUL>
Checking DDR......OK
UBL Version: 1.46t(DM365)16:10:30 Aug 4 2017
Oscillator: 24MHZ
ARM Rate: 432 MHZ
DDR Rate: 340 MHZ
BootMode: SPI
Starting SPI Memory Copy...
DONE
U-Boot 1.3.6 (jerry) (May 23 2018 - 17:21:42)
DRAM: 128 MB
SF: Got idcode ef 40 18 00 00
SF: Detected W25Q128FV with page size 256, total 16 MB
In: serial
Out: serial
Err: serial
Ethernet PHY: GENERIC @ 0x05,id:221513
total gio 2
gio[22]=1
gio[25]=1
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Filename 'upgrade_info_7db780a713a4.txt'.
Load address: 0x80100000
Loading: T T T
Retry count exceeded; starting again
Fail to get info file!
Init error!
Filename 'failed.txt'.
Load address: 0x80200000
Loading: T T T
==>use default images
APP_OFFSET_NEW test
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: Linux-2.6.18_pro500-davinci_evm-
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1799172 Bytes = 1.7 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
XIP Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux........................................................................................................................ done, booting the kernel.
Linux version 2.6.18_pro500-davinci_evm-arm_v5t_le (jenkins@e1eace7d2920) (gcc version 4.2.0 (MontaVista 4.2.0-16.0.32.0801914 2008-08-30)) #1 PREEMPT Tue Mar 19 22:11:02 CST 2019
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: DaVinci DM365 EVM
new hwid:VTO2000A:0:4:1:3:5:0:1:9:3:3:0:1B0:0:0:0:0:0:0:0
use newmem, newmemStartAddr:0x80000000 newmemSize:0x5900000(89M)
Memory policy: ECC disabled, Data cache writeback
DaVinci DM0365 variant 0x8
prediv = 6, pll0_mult = 85, postiv = 1, pll_div4 = 4, pll_rate = 680000000, pll_div6 = 25
PLL0: fixedrate: 24000000, commonrate: 170000000, vpssrate: 340000000 PLL1_ARMRATE = 340000000
PLL0: vencrate_sd: 27200000, ddrrate: 340000000 mmcsdrate: 136000000
##: prediv = 1, pll1_mult = 9, postdisv = 1, pll-rate = 432000000, pll_div2 = 1, pll_div4 = 21, pll-div5 = 16
PLL1: armrate: 432000000, voicerate: 20571428, vencrate_hd: 27000000, ddrratePLL2 = 432000000
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
Built 1 zonelists. Total pages: 22784
dh_keyboard:0
PID hash table entries: 512 (order: 9, 2048 bytes)
Clock event device timer0_0 configured with caps set: 07
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 89MB = 89MB total
Memory: 86272KB available (2992K code, 721K data, 172K init)
Security Framework v1.0.0 initialized
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
MUX: initialized SPI0_SDENA0
DaVinci: 104 gpio irqs
MUX: initialized GPIO20
MUX: initialized I2C_SCL
pMem_relimitBaseAddr:0xc6000000
Generic PHY: Registered new driver
configured buff delay: 50
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 4096 bind 2048)
TCP reno registered
product has no spi2 device.
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
squashfs: version 3.4 (2008/08/26) Phillip Lougher
squashfs: LZMA suppport for slax.org by jro
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
LTT : ltt-facilities init
LTT : ltt-facility-core init in kernel
davinci_wdt_init proc enable
rtc probe addr 0x68, probeByte 0x00...
RTC_i2c_attach_client:addr:0x68
== Found RTC chip DS1338, I2C addr 0x68 ==
rtc probe addr 0x6f, probeByte 0x00...
rtc probe addr 0x57, probeByte 0x00...
rtc probe addr 0x32, probeByte 0x00...
DS1338 driver v1.04sem proc enable,
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
&&&: uart_add_one_port, line = 0, uartclk = 0
&&&: uart_add_one_port, line = 1, uartclk = 170000000
ttyS0: autoconf (0x0000, 0xfbc20000): <6>serial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfbc20000 (irq = 40) is a 16550A
&&&: uart_add_one_port, line = 0, uartclk = 24000000
ttyS1: autoconf (0x0000, 0xfbd06000): <6>serial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550A
Broadcom BCM5411: Registered new driver
Broadcom BCM5421: Registered new driver
Broadcom BCM5461: Registered new driver
Broadcom BCM5481: Registered new driver
Broadcom BCM54811: Registered new driver
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
Linux video capture interface: v2.00
i2c /dev entries driver
System bootup mode:SPI
JECDEC ID : 0xef4018
ext_jedec ID : 0x0
chip id W25Q128FV
found W25Q128FV in table.
m25p80 spi0.0: W25Q128FV (16384 Kbytes)
Creating 10 MTD partitions on "spi0.0":
0x00000000-0x00040000 : "bootloader"
0x00040000-0x00060000 : "HWID"
0x00060000-0x00260000 : "kernel"
0x00260000-0x003e0000 : "web"
0x003e0000-0x006e0000 : "rootfs"
0x006e0000-0x006f0000 : "product"
0x006f0000-0x00da0000 : "user"
0x00da0000-0x00ec0000 : "data"
0x00ec0000-0x00f60000 : "backup"
0x00f60000-0x01000000 : "config"
dm_spi.0: davinci SPI Controller driver at 0xc6266000 (irq = 42) use_dma=0
[*****geyj******1]register master =0xc06de800;bus_num = 0
dm_spi.1: davinci SPI Controller driver at 0xc6268800 (irq = 17) use_dma=0
[*****geyj******1]register master =0xc06de400;bus_num = 1
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
usbcore: registered new driver asix
usbcore: registered new driver cdc_ether
usbcore: registered new driver net1080
usbcore: registered new driver zaurus
musb_hdrc: version 6.0, pio, host, debug=0
musb_hdrc: USB Host mode controller at c626a000 using PIO, IRQ 12
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
u32 classifier
Performance counters on
TCP bic registered
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Time: timer0_1 clocksource has been installed.
Clock event device timer0_0 configured with caps set: 08
Switched to high resolution mode on CPU 0
IP-Config: No network devices available.
VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 172K
<CR>init started: BusyBox v1.9.1 (2017-06-12 16:54:28 CST)
<CR>starting pid 198, tty '': '/etc/init.d/dnode'
2.65s
<CR>starting pid 203, tty '': '/etc/init.d/rcS'
cp: cannot stat '/sbin/telnetd': No such file or directory
Fri Apr 28 19:24:27 2023 0.000000 seconds
<ESC>[0;32;32m[gpio] initialize success, build at 22:15:12, Mar 19 2019<ESC>[m<ESC>[0;32;32m[gpio] CMD=9, Setting product type: 0
<ESC>[m<ESC>[0;32;32m[libdv<ESC>[0;32;32m[gpio] CMD=4, Setting product fchip: 3
<ESC>[mr]
libdvr.so B<ESC>[0;32;32m[gpio] CMD=3, Setting hardware version: 0
<ESC>[muild time: Mar 19 2019 at 22:14:05.
<ESC>[m<ESC>[0;32;32m[libdvr] SVN NUM: 8433.
<ESC>[mGIO_SET_PRODUCT_TYPE = 9
<ESC>[0;32;32m[gpio] SD card hardware reset is done, gio55=0.
<ESC>[mcurrent wdt period=5000 ms
<ESC>[0;32;32m[libdvcurrent wdt period=25000 ms
r]
libdvr.so Build time: Mar 19 2019 at 22:14:05.
<ESC>[m[syshelper] syshelper Build time: Jun 27 2018 at 09:24:25.
[syshelper] V1.21(no exit): startup time=25 s, appauto=1, hctosystime=1500,type=0
[syshelper] start watch dog success, period is 25000 ms.
4.56s
coremnt not found
7z ANSI-C Decoder 9.20 : Igor Pavlov : Public domain : 2010-11-18
DH:: [rootlistinit:982] rootlistinit buf len=53
Extracting cmemk.ko
Extracting davinci_emac.ko
Extracting display.ko
Extracting dm365mmap.ko
Extracting dm365_ad.ko
Extracting edmak.ko
Extracting evdev.ko
Extracting getjif.ko
Extracting h3ak.ko
Extracting irqk.ko
Extracting mcu_spi.ko
Extracting mfrc522.ko
Extracting mmc_blk.ko
Extracting mmc_core.ko
Extracting mmc_drv.ko
Extracting mymemcpy.ko
Extracting pwm.ko
Extracting pwm_gpio.ko
Extracting Sensor.ko
Extracting sound.ko
Extracting spi.ko
Extracting spi_mcu.ko
Extracting vpbek.ko
Extracting vpfek.ko
Everything is Ok
/mnt/mtd/Config/ppp
Extracting English.txt
Everything is Ok
/mnt/mtd/Config/ppp
Extracting sshd
Everything is Ok
Extracting VideoDaemon
ERROR #1
Extracting sonia
ERROR #1
chmod: /var/usr/VideoDaemon: No such file or directory
chmod: /var/usr/sonia: No such file or directory
/mnt/mtd/Config/ppp
Davinci EMAC MII Bus: probed
MAC address is 38:AF:29:BA:E3:45
TI DaVinci EMAC Linux version updated 4.0
<ESC>[mbootargs:console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=cramfs,nolock mem=90M newmem=90M video=davincifb:vid0=OFF:vid1=OFF
sd0=OFF
sd1=OFF
bootargs_prefix: console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=cramfs,nolock
bootargs_suffix: video=davincifb:vid0=OFF:vid1=OFF
sd0=OFF
sd1=OFF
mem_old:90M
mem_new:90M
cmem= 90
CMEMK module: built on Apr 14 2010 at 13:45:45
Reference Linux version 2.6.18
File /workspace/dm365/dvsdk_2_10_01_18_guangpan/linuxutils_2_24_03/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x2600000
CMEM Range Overlaps Kernel Physical - allowing overlap
CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x85900000)
cmemk initialized
IRQK module: built on Apr 14 2010 at 13:46:34
File /workspace/dm365/dvsdk_2_10_01_18_guangpan/linuxutils_2_24_03/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
irqk initialized
EDMAK module: built on Apr 14 2010 at 13:46:46
File /workspace/dm365/dvsdk_2_10_01_18_guangpan/linuxutils_2_24_03/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
getjif init @ 091230
##: HZ = 10
register getjif driver successful !
<ESC>[0;32;32m[VPBE] VPBE Build on Mar 19 2019 at 22:15:20.
<ESC>[m<ESC>[0;32;32m[VPBE] SVN NUM: 9699.
<ESC>[m<ESC>[0;32;32m[VPBE] ch0 default output "LCD", mode "800x480"
<ESC>[m<ESC>[0;32;32m[VPBE] ch1 default output "COMPOSITE", mode "NTSC"
<ESC>[m<ESC>[0;32;32m[VPBE] VPBE Encoder Initialized
<ESC>[m<ESC>[0;32;32m[VPBE] options =:vid0=OFF:vid1=OFF
sd0=OFF
sd1=OFF
<ESC>[m<ESC>[0;32;32m[VPBE] dm_osd0_fb: 0x0x16@0,0 with framebuffer size 750KB
<ESC>[m<ESC>[0;32;32m[VPBE] dm_vid0_fb: 0x0x16@0,0 with framebuffer size 1125KB
<ESC>[m<ESC>[0;32;32m[VPBE] dm_osd1_fb: 0x0x4@0,0 with framebuffer size 750KB
<ESC>[m<ESC>[0;32;32m[VPBE] dm_vid1_fb: 0x0x16@0,0 with framebuffer size 1125KB
<ESC>[m<ESC>[0;32;32m[VPBE] Trying to register davinci display video device.
<ESC>[m<ESC>[0;32;32m[VPBE] davinci_init
aVinci V4L2 Display Driver V1.0 loaded
<ESC>[m<ESC>[0;32;32m[VPBE] VPBE Driver Initial OK, Build On : Mar 19 2019, 22:15:20.
<ESC>[m
<ESC>[0;32;32m[VPFE] VPFE Build on Mar 19 2019 at 22:15:15.
<ESC>[m<ESC>[0;32;32m[VPFE] SVN NUM: 8556.
<ESC>[m<ESC>[0;32;32m[VPFE] VPFE Driver Initial OK, Build On : Mar 19 2019, 22:15:15.
<ESC>[m
<ESC>[0;32;32m[H3A] H3A Driver Build on Mar 19 2019 at 22:15:18.
<ESC>[m<ESC>[0;32;32m[H3A] SVN NUM: 8033.
<ESC>[m<ESC>[0;32;32m[H3A] VideoBuf Driver Initial OK !
<ESC>[m<ESC>[0;32;32m[H3A] DEV_h3aHwInit
<ESC>[m<ESC>[0;32;32m[H3A] VideoBuf Create queuefor dm365_aew OK !
<ESC>[m<ESC>[0;32;32m[H3A] AEW Driver Initial OK !
<ESC>[m<ESC>[0;32;32m[H3A] VideoBuf Create queuefor dm365_af OK !
<ESC>[m<ESC>[0;32;32m[H3A] AF Driver Initial OK !
<ESC>[m<ESC>[0;32;32m[H3A] H3A Driver Initial OK
<ESC>[m<ESC>[0;32;32m[SND]build Dec 11 2019 14:40:11 SVN 2194
<ESC>[m<ESC>[0;32;32m[alc3261] alc3261_powerOn
<ESC>[m[i2c]Found I2C Device (i2c addr 0x1c)
<ESC>[0;32;32m[alc3261] VTO2000A alc3261 regs param
<ESC>[m<ESC>[0;32;32m[alc3261] init EQ EQMODE:0
<ESC>[m<ESC>[0;32;32m[alc3261] EQ disable
<ESC>[m[base]found the soc chip: alc3261 on i2c bus
<ESC>[0;32;32m[MCBSP] word0=0, word1=2
<ESC>[m<ESC>[0;32;32m[MCBSP] word_num=2
<ESC>[m<ESC>[0;32;32m[MCBSP] word_length=16
<ESC>[m<ESC>[0;32;32m[MCBSP] word0=0, word1=2
<ESC>[m<ESC>[0;32;32m[MCBSP] word_length=2
<ESC>[m<ESC>[0;32;32m[alc3261] alc3261 set rate 16000
<ESC>[m<ESC>[0;32;32m[alc3261] VTO2000A aec param
<ESC>[m<ESC>[0;32;32m[alc3261] mono left gain value 95
<ESC>[m<ESC>[0;32;32m[alc3261] alc3261_mono_ad_gain_l vol=0x5400
<ESC>[m<ESC>[0;32;32m[alc3261] alc3261_spo_l volume=70
<ESC>[m<ESC>[0;32;32m[alc3261] VTO2000A set vol most
<ESC>[m<ESC>[0;32;32m[alc3261] alc3261_spo_l vol=0x8500
<ESC>[m<ESC>[0;32;32m[alc3261] alc3261_vol_outl volume=100
<ESC>[m<ESC>[0;32;32m[alc3261] alc3261_vol_outl vol=0x9f00
<ESC>[mBusyBox v1.9.1 (2017-06-12 16:54:28 CST) multi-call binary
Usage: mknod [OPTIONS] NAME TYPE MAJOR MINOR
Cr<ESC>[0;32;32m[spi_smlt] Serving For product VTO2000A by spi hardware.
<ESC>[meate a special file (block, character, or pipe)
Options:
-m Create the special file using the specified mode (default a=rw)
TYPEs include:
b: Make a block (buffered) <ESC>[0;32;32m[spi_smlt] initialize success, build at 22:15:11, Mar 19 2019
<ESC>[mdevice
c or u:<ESC>[0;32;32m[spi_smlt] delay 10us
<ESC>[m Make a character (un-buffered) device
p: Make a named pipe. MAJOR and MINOR are ignored for named pipes
Archive: /mnt/pd/product.zip
<ESC>[0;32;32m[sensor]
<ESC>[m creating: prod<ESC>[0;32;32m[sensor] Sensor.ko Build on Mar 19 2019 at 22:15:43.
<ESC>[muct/
creatin<ESC>[0;32;32m[sensor] SVN NUM: 9701.
<ESC>[mg: product/IPC-H<ESC>[0;32;32m[sensor] The Sensor Driver Version:Ver 2.0
<ESC>[mF3100/
inflating: product/IPC-HF3100/ProductDefinition
inflating: product/IPC-HF3100/CustomConfig
inflating: product/IPC-HF3100/shorthand.txt
inflating: product/IPC-HF3100/DefaultAccount
<ESC>[0;32;32m[sensor] Found I2C Device (i2c addr 0x10)
<ESC>[m<ESC>[0;32;32m[sensor] The Sensor is AR0130 ID:0x2402
<ESC>[m<ESC>[0;32;32m[sensor] The MT9M034 model ID is 0x2402
<ESC>[m<ESC>[0;32;32m[sensor] RESET PIN 63 reset MT9M034
<ESC>[m<ESC>[0;32;32m[sensor] We found the sensor chip: mt9m034 on i2c bus
<ESC>[m<ESC>[0;32;32m[sensor] sensor device init success
<ESC>[mArchive: /mnt/pd/2Acfg.zip
creating: 2Acfg/
creating: 2Acfg/OV9712/
inflating: 2Acfg/OV9712/aew_para.txt
inflating: 2Acfg/OV9712/aew_para.bin
creating: 2Acfg/MT9M034/
inflating: 2Acfg/MT9M034/aew_para.txt
inflating: 2Acfg/MT9M034/aew_para.bin
creating: 2Acfg/AR0130/
inflating: 2Acfg/AR0130/aew_para.txt
inflating: 2Acfg/AR0130/aew_para.bin
<ESC>[0;32;32m[sensor] The 70oc is 32772, the 55oC is 35758, Now is 414
<ESC>[m<ESC>[0;32;32m[sensor] The temperature now is 55
<ESC>[m<ESC>[0;32;32m[sensor] The 70oc is 32772, the 55oC is 35758, Now is 414
<ESC>[msensor_name:ar0130
<3>1:01 not found
<ESC>[0;32;32m[libdvADDRCONF(NETDEV_UP): eth0: link is not ready
r]
<ESC>[monly init eth0
"netinit help" for help
eth0:
MAC: <38:af:29:ba:e3:45>
<ESC>[0;32;31m[libdvr] ERROR (../src/net/net.c|SetGateWay|1141): SIOCADDRT<CR>netinit uses obsolete (PF_INET,SOCK_PACKET)
<LF>SIOCADDRT: Network is unreachable
<ESC>[m<ESC>[0;32;31m[libdvr] ERROR (../src/net/net.c|SetEthAttr|1467): SetGateWay error
IP: <192.168.178.11> netmask: <255.255.255.0>
Gateway: <192.168.178.1>
<ESC>[m[libdvr] set success
<ESC>[mIPV6: only init eth0
"netinit6 help" for help
eth0:
IPV6: <2008::6> preFixLen: <112>
<ESC>[1;33m[libdvr] WARN (../src/net/network6.c|NetWorkDelIP|982): del ip failed:No such device or address
<ESC>[mIPV6 Gateway: <2008::1>
/usr/etc/imod: line 341: /var/usr/VideoDaemon: not found
<ESC>[monly init eth2"netinit help" for help
/proc/sys/vm/drop_caches
imod end...
rm: cannot remove '/var/usr/VideoDaemon': No such file or directory
<CR>starting pid 384, tty '': '/etc/init.d/appauto'
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
<ESC>[mclaststate V1.0 for dm365times=3 @@@; usdate = 0xecf9362d
mode: normal
Fri Apr 28 19:24:45 2023 0.000000 seconds
./usr/etc/app.sh: line 4: /var/usr/sonia: not found
./usr/etc/app.sh: line 6: echo####application exit:127, system will reboot!: not found
<ESC>[mName: upgraded, bulid date: Dec 15 2017 17:39:05, svn: 1103
UPGRADED_MSG: start download file!
... crypto start ....
DH:: [reliableenvvalidate:1025] crypto dir=/usr/SigFileList,buf pos=4
falied---filename:[/usr/SigFileList] signfile [/usr/Data_Signature]
Restarting system.
<NUL>
Oscillator: 24MHZ
ARM Rate: 432 MHZ
DDR Rate: 340 MHZ
BootMode: SPI
DONE
