tcpdump compile error
Do you realy use ruby, tcpdump and so on?
Regards
Oliver
not use, if not work compilation :-D After compile, i use :)
aclocal.m4:45: AC_LBL_C_INIT is expanded from...
configure.in:15: the top level
configure: WARNING: unrecognized options: --with-gnu-ld, --disable-nls
configure: loading cache /home/freetz/freetz-1.1.3/make/config.cache
checking build system type... (cached) i386-pc-linux-gnu
checking host system type... (cached) mipsel-unknown-linux-gnu
./configure: line 2548: syntax error near unexpected token `newline'
./configure: line 2548: `yes:'
make: *** [source/tcpdump-3.9.8/.configured] Fehler 2
freetz@freetz-linux:~/freetz-1.1.3$ ^C
freetz@freetz-linux:~/freetz-1.1.3$ svn checkout http://svn.freetz.org/tags/freetz-1.1.3
Checked out revision 5307.
tcpdump error, then please, tell me, how i fix and how i learn C and cvs development :)
What Linux do you use?
The command you posted is not okay!?
You have to do:
cd ~/
rm -rf freetz-1.1.3
svn co http://svn.freetz.org/branches/freetz-stable-1.1
cd freetz-stable-1.1
make
MfG Oliver
i use vmw play & putty, yes, 1.1 branch work fine, but i post error in 1.1.3, is possible? i try delete dir and make
If this doesn't work in freetz-1.1.3 it won't work for ever because the tag freetz-1.1.3 will never be updated. Please read about trunk, branch and tag and what their meaning is.
Regards
Oliver
now i use make dirclean and still get error:
checking for stdint.h... (cached) yes
checking for unistd.h... (cached) yes
checking for dlfcn.h... (cached) yes
checking for mipsel-linux-g++... (cached) /home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-g++-uc
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether /home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-g++-uc accepts -g... (cached) yes
checking how to run the C++ preprocessor... (cached) /home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -E
configure: error: C++ preprocessor "/home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -E" fails sanity check
See `config.log' for more details.
make: *** [source/expat-2.0.1/.configured] Fehler 1
any idea?
Ameponert
