ISDN Terminal Adaptor GR9 Loader v1.01.001 build Apr 2 2014 19:24:45
Arcadyan Technology Corporation
A2x VR9,
0xbf106a10 : 78
0xbf106a11 : 0
0xbf106a0c : 88
MXIC MX29LV640EB bottom boot 16-bit mode found
Copying boot params.....DONE
Get Primary to 0.....
Flash Checking Passed.
Unzipping firmware at 0x80002000 ... with AREA[2][ZIP 3]
[ZIP Extra] [ZIP 1] source:816f0011
done
Ready to run firmware
In c_entry() function ...
install_exception
Co config = 80048483
sys_irq_init ...
VR9 is A21 chip !!!!, ifx_bsp_basic_mps_decrypt bf001f38
0xbf106a10 : 78
0xbf106a11 : 0
0xbf106a0c : 88
##### _ftext = 0x80002000
##### _fdata = 0x805D63C0
##### __bss_start = 0x80669598
##### end = 0x83068790
allocate_memory_after_end: alloc from 83070790 to 83103980, length=602584
##### Backup Data from 0x805D63C0 to 0x83070790~0x83103968 len 602584
##### Backup Data completed
##### Backup Data verified
[GPIO FLOW] SetGpio() Begin ..
PLL1 locked..fails 0.
ifx_gpio_init() !!!
ifx_gpio_pre_init() !!!
[KERN_INFO]IFX GPIO driver, version 1.2.10, (c)2009 Infineon Technologies AG
Register LED MODULE OK!!
Register BUTTON MODULE OK!!
[GPIO FLOW] SetGpio() End.
[INIT] System Log Pool startup ...
[INIT] MTinitialize ..
CPU Clock 500000000 Hz
mips_counter_frequency:250000000
r4k_offset: 0x0003d090(250000)
init_US_counter : time1 = 35 , time2 = 225070, diff 225035
US_counter = 112
set to constant US_counter = 112
cnt1 2040029 cnt2 2042610, diff 2581
cnt1 2886368 cnt2 2888172, diff 1804
Runtime code version: 01012701.00.007
System startup...
[INIT] Memory COLOR 0, 8242880 bytes ..
[INIT] Memory COLOR 1, 2097152 bytes ..
[INIT] Memory COLOR 2, 10906608 bytes ..
InitCommSys: RESOURCE_BASE = 29, NUMRES = 640
InitCommSys: EVENT_BASE = 163, NUMEVT = 818
InitCommSys: MAILBOX_BASE = 6, NUMMBX = 64
rzMemory start: 0x82357420, end 0x825734A8, size 2211976
Build Day = 03.08.2015, 10:09 Uhr Version = 01012701.00.007
Version Type 'NORMAL'
>>>>set_MP_pass_Magic to 3
Set flash memory layout to FL2MacAddr=18:83:BF:B1:C5:0D
Boot Parameters found !!!
Bootcode version: v1.01.001
Serial number: J438083396
Hardware version: 01
-->in_Factory_default=0
Firmware Ready!
