[SOLVED]Help for installing freetz!!!
You don't have to set up anything if you're really using freetz-linux from here
All servers (samba, ssh, ftp) are already configured and running.
Your VM should have an IP-address in the same range as you host as it is configured via DHCP.
Sorry flame, but this isn't really depending on freetz anymore. Services are up and running as described (in german) in corresponding thread for the vmware/virtualbox image. ssh/ftp/samba are the services running, colonia metioned username and password.
in my opinion thera are not enough linux-basics for now on your side. Please have a little look for them, they are really needed to build/use and modify freetz.
Btw: There is another way to flash the image without using windows. freetz contains a script named push_firmware in the subfolder tools.
I am really close... I transfered it to my pc!!!:D
Now i have to update using the fritz option update firmware?
And one more question I have selected the patch to remove all the telephon and isdn file as long as i wont be using them. however it said that it was experimental, do u have any problems with that?
If something goes wrong but after the process the router is working i will be able to convert it to the previous state by loading the stock firmware right?
right
We don't hav any problems with your image ;-)
right
right
right
I mean if you have problems with this patch..:rolleyes:
Because when i made the image it gave me an warning, saying that i you replace "that" and "that" files may cause an unstable image...
I updated with the image I made.. But everything seems normal..:confused:
How do I connect to freetz? I see only the old functions.. It has red letter saying that the firmware is not from avm but nothing else... what I am missing?
You are missing the right port of the freetz-webinterface. Please connect to http://fritz.box:81
Page load error...
Failded to connect...
Is it kinding me?
I think it has something to do with the image I have made.. It is supposed that my custom image would update the avm firmware,right? It wasnt done.. I updated with the official firmware afterwards.. Then updated again with my image but still cant connect..
I am going to make the image again..
I dont understand what is going wrong..
I made an other image, updated with it but all the same.. Could connect..
Scaned fritzbox for open ports and there are only 80, 5060 and 8080..
There are no changes.. I removed the parental control and help(+some other stuff) but everything is still there. It is as if i never updated...:confused:
Although i get a message on the overview screen: "Changes not supported by manufacturer"
What Packages have you selectet?
Can you please post your conf file?
The path for the file is in the root directory, where you make your "make menuconfig" and the filename is :
.config
It is a hidden system file.
The content should start like this:
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_7270_04_76=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7112 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
# FREETZ_TYPE_FON_WLAN_7240 is not set
FREETZ_TYPE_FON_WLAN_7270=y
I have selected bridge-utils, dropbear, transmission and virtual ip..
FREETZ_AVM_VERSION_04_67=y
FREETZ_TYPE_FON_WLAN_7140=y
# FREETZ_TYPE_FON_WLAN_7270 is not set
# FREETZ_TYPE_FON_WLAN_7270_V3 is not set
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_AVM_VERSION_STRING="04.67"
# FREETZ_TYPE_LANG_DE is not set
# FREETZ_TYPE_LANG_A_CH is not set
FREETZ_TYPE_LANG_EN=y
FREETZ_TYPE_LANG_STRING="en"
FREETZ_TYPE_ANNEX_A=y
# FREETZ_TYPE_ANNEX_B is not set
FREETZ_TYPE_STRING="7140"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_KERNEL=y
FREETZ_SHOW_ADVANCED=y
# FREETZ_TARGET_IPV6_SUPPORT is not set
FREETZ_TARGET_REF="8mb_26"
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_LAYOUT="ohio"
FREETZ_KERNEL_MTD_SIZE=119
FREETZ_HAS_PHONE=y
# FREETZ_HAS_TAM is not set
FREETZ_HAS_WLAN=y
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_USB_HOST=y
# FREETZ_HAS_AVM_INETD is not set
FREETZ_HAS_LIBSSL=y
# Mod ------------------------------------
# FREETZ_LANG_DE is not set
FREETZ_LANG_EN=y
FREETZ_LANG_STRING="en"
# Patches
# Remove Brandings
# FREETZ_REMOVE_BRANDING_avme is not set
FREETZ_REMOVE_HELP=y
FREETZ_PATCH_ENUM=y
FREETZ_PATCH_SIGNED=y
FREETZ_PATCH_USBSTORAGE=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_EXT2 is not set
FREETZ_AUTOMOUNT_EXT3=y
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTOMOUNT_REISER_FS is not set
FREETZ_AUTORUN_AUTOEND=y
# FREETZ_PATCH_MAXDEVCOUNT is not set
# FREETZ_PATCH_GETCONS is not set
FREETZ_REMOVE_SUPPORT=y
# FREETZ_REMOVE_UPNP is not set
FREETZ_REMOVE_USERMAN=y
# FREETZ_REMOVE_FTPD is not set
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_SMBD is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
FREETZ_REMOVE_VOIPD=y
FREETZ_REMOVE_VOIP_ISDN=y
# FREETZ_REMOVE_WLAN is not set
# Package selection
# *** not all packages support selected language ***
FREETZ_SELECTED_LANG_ONLY=y
# Standard packages
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
FREETZ_PACKAGE_BRIDGE_UTILS=y
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNSMASQ is not set
FREETZ_PACKAGE_DROPBEAR=y
# FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY is not set
# FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB is not set
FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_INETD is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MINI_FO is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETSNMP is not set
FREETZ_PACKAGE_NTFS=y
# FREETZ_PACKAGE_OPENNTPD is not set
# FREETZ_PACKAGE_OPENVPN is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_VSFTPD is not set
# Web interface
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
# FREETZ_PACKAGE_AVM_FIREWALL is not set
# FREETZ_PACKAGE_CPMACCFG_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
# FREETZ_PACKAGE_PPP_CGI is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
# FREETZ_PACKAGE_SYSLOGD_CGI is not set
FREETZ_PACKAGE_TRANSMISSION_CGI=y
FREETZ_PACKAGE_VIRTUALIP_CGI=y
# FREETZ_PACKAGE_WOL_CGI is not set
# Debug helpers
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Testing
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
# FREETZ_PACKAGE_FORTUNE is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NFSROOT is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# OpenSSH
# FREETZ_PACKAGE_OPENSSH_SSHD is not set
# FREETZ_PACKAGE_OPENSSH_CLIENT is not set
# FREETZ_PACKAGE_OPENSSH_SCP is not set
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_SFTPCLIENT is not set
# FREETZ_PACKAGE_OPENSSH_SFTP is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PPPD_CHAT is not set
# FREETZ_PACKAGE_PPTP is not set
# FREETZ_PACKAGE_PPTPD is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SQUID is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_SYNCE_SERIAL is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TINYPROXY is not set
FREETZ_PACKAGE_TRANSMISSION=y
FREETZ_PACKAGE_TRANSMISSION_CLIENT=y
FREETZ_PACKAGE_TRANSMISSION_DAEMON=y
# FREETZ_PACKAGE_TRANSMISSION_REMOTE is not set
# FREETZ_PACKAGE_TRANSMISSION_STATIC is not set
FREETZ_PACKAGE_TRANSMISSION_WEBINTERFACE=y
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_SHOW_UNSTABLE_PACKAGES is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_SITE="ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7140/firmware/english/annex_a"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7140.AnnexA.en.39.04.67.image"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: [url]http://freetz.3dfxatwork.de[/url]
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: [url]http://freetz.wirsind.info[/url]
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: [url]http://freetz.magenbrot.net[/url]
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_SECURITY_LEVEL=1
FREETZ_VERBOSITY_LEVEL=2
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_SUBVERSION_STRING=y
FREETZ_DEVELOPER_VERSION_STRING=y
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
FREETZ_USER_DEFINED_COMMENT=""
# FREETZ_CUSTOM_IMAGE_NAME is not set
# Info pages
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
# FREETZ_REMOVE_DOT_CONFIG is not set
# External
# EXTERNAL_ENABLED is not set
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_DIFF is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_IP is not set
# FREETZ_BUSYBOX_PATCH is not set
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_LESS is not set
FREETZ_BUSYBOX_NICE=y
# FREETZ_BUSYBOX_LS_COLOR is not set
# FREETZ_BUSYBOX_FASTPROC is not set
# FREETZ_BUSYBOX_KEYS is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_TAC is not set
# FREETZ_BUSYBOX_MDEV_RENAME is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_MOUNT_LABEL is not set
# FREETZ_BUSYBOX_VOLUMEID is not set
# Kernel modules
# FREETZ_MODULES_ALL is not set
# crypto
# FREETZ_MODULE_aes is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
FREETZ_MODULE_scsi_mod=y
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# FREETZ_MODULE_option is not set
# fs
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
FREETZ_MODULE_ext3=y
FREETZ_MODULE_ext2=y
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
FREETZ_MODULE_fuse=y
FREETZ_MODULE_jbd=y
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# ndas
# FREETZ_MODULE_ndas_block is not set
# FREETZ_MODULE_ndas_core is not set
# FREETZ_MODULE_ndas_sal is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdods is not set
# FREETZ_MODULE_jffs2 is not set
FREETZ_MODULE_mbcache=y
# lib
# FREETZ_MODULE_crc_ccitt is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Shared libraries
# FREETZ_STRIP_LIBRARIES is not set
# Libraries -------------------------------
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libatm is not set
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# Crypto & SSL
# GMP ------------------------------------
# FREETZ_LIB_libgmp is not set
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libxyssl is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
# FREETZ_LIB_libavmhmac is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
FREETZ_LIB_libz=y
# Graphics & fonts
FREETZ_LIB_libfreetype=y
FREETZ_LIB_libart_lgpl_2=y
# FREETZ_LIB_libjpeg is not set
FREETZ_LIB_libpng12=y
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_libresolv=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
# FREETZ_LIB_libuClibc__ is not set
FREETZ_LIB_libgcc_s=y
FREETZ_LIB_libglib_1=y
# GLib2
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# ncurses
FREETZ_LIB_libncurses=y
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
FREETZ_SHARE_terminfo=y
# FREETZ_SHARE_terminfo_showall is not set
FREETZ_SHARE_terminfo_ansi=y
FREETZ_SHARE_terminfo_gnome=y
FREETZ_SHARE_terminfo_konsole=y
FREETZ_SHARE_terminfo_linux=y
FREETZ_SHARE_terminfo_putty=y
FREETZ_SHARE_terminfo_rxvt=y
FREETZ_SHARE_terminfo_screen=y
FREETZ_SHARE_terminfo_screenMINUSw=y
FREETZ_SHARE_terminfo_sun=y
FREETZ_SHARE_terminfo_vt100=y
FREETZ_SHARE_terminfo_vt102=y
FREETZ_SHARE_terminfo_vt102MINUSnsgr=y
FREETZ_SHARE_terminfo_vt102MINUSw=y
FREETZ_SHARE_terminfo_vt200=y
FREETZ_SHARE_terminfo_vt220=y
FREETZ_SHARE_terminfo_vt52=y
FREETZ_SHARE_terminfo_xterm=y
FREETZ_SHARE_terminfo_xtermMINUScolor=y
FREETZ_SHARE_terminfo_xtermMINUSxfree86=y
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# FREETZ_LIB_libcapi20 is not set
FREETZ_LIB_libcurl=y
FREETZ_LIB_libevent=y
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libpcap is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# FREETZ_LIB_libsqlite3 is not set
FREETZ_LIB_libusb=y
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libftdi is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libdevmapper is not set
FREETZ_LIB_libfreetz=y
# FREETZ_LIB_libpcre is not set
# FREETZ_LIB_libpcreposix is not set
# Compiler options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=2
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_KERNEL_VERSION_2_6_13_1=y
# FREETZ_KERNEL_VERSION_2_6_19_2 is not set
FREETZ_KERNEL_VERSION="2.6.13.1"
# FREETZ_TARGET_UCLIBC_VERSION_0_9_28 is not set
FREETZ_TARGET_UCLIBC_VERSION_0_9_29=y
# FREETZ_TARGET_UCLIBC_VERSION_0_9_30 is not set
# FREETZ_TARGET_COMPILER_GCC_4_1_2_UCLIBC_0_9_28 is not set
# FREETZ_TARGET_COMPILER_GCC_4_2_4_UCLIBC_0_9_28 is not set
FREETZ_TARGET_COMPILER_GCC_4_2_4_UCLIBC_0_9_29=y
# FREETZ_TARGET_COMPILER_GCC_4_3_3_UCLIBC_0_9_29 is not set
# FREETZ_TARGET_COMPILER_GCC_4_3_3_UCLIBC_0_9_30 is not set
FREETZ_TARGET_GCC_VERSION="4.2.4"
FREETZ_TARGET_UCLIBC_VERSION="0.9.29"
FREETZ_TARGET_BINUTILS_VERSION="2.18"
FREETZ_TARGET_UCLIBC_REF="mod"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
FREETZ_TARGET_CCACHE=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
# FREETZ_TARGET_TOOLCHAIN is not set
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
Would you be so kind to use
-Tags instead of [quote]
It looks good so far, I think all necessary things are included in your firmware
you should be able to connect via
ssh on port 22 to the console of the box if the dropbear is working.
I wonder if there are issues with the "english only" packages, but I don't think so.
Do you have this additional menu point in your original UI (see picture)?
Do you have any funny settings on your browser set, that might prevent fom authentication?
You should see a popup asking for username & Password
I cant connect via ssh and i dont have the additional menu..
Do you have a phone connected to the box? There are phone codes to enable telnet, then you can login and check what services are running.
#96*7* Telnet enabled
#96*8* Telnet disabled
Connected via telnet.. now what?
on the command line enter
/var/mod/root # ps
    2 root         0 SWN  [ksoftirqd/0]
    3 root         0 SW   [watchdog/0]
    4 root         0 SW<  [events/0]
    5 root         0 SW<  [khelper]
    6 root         0 SW<  [kthread]
   17 root         0 SW<  [kblockd/0]
   31 root         0 SW   [pdflush]
   32 root         0 SW   [pdflush]
   33 root         0 SW<  [kswapd0]
   34 root         0 SW<  [aio/0]
   70 root         0 SW   [pm_info]
   74 root         0 SW<  [CPMAC]
   78 root         0 SW   [mtdblockd]
  100 root         0 SW   [tffsd_mtd_0]
  364 root         0 SW   [cleanup_timer_f]
  375 root         0 SW   [dectuart_route]
  383 root         0 SWN  [jffs2_gcd_mtd5]
  429 root         0 SW<  [capi_oslib]
  430 root         0 SW<  [capi_oslib]
  431 root         0 SW   [capitransp]
  437 root         0 SW   [glob_codecs]
  441 root         0 SW   [avm_dect_thread]
  444 root         0 SW   [ksock tcp worke]
  445 root         0 SW   [ksock tcp serve]
  460 root         0 SW<  [khubd]
  582 root         0 SW<  [scsi_eh_0]
  583 root         0 SW<  [usb-storage]
  628 root     10500 R N  ctlmgr
  945 root     10500 S N  ctlmgr
  950 root     10500 S N  ctlmgr
  951 root     10500 S N  ctlmgr
 1247 root      3452 S    upnpd
 1266 root      3304 S    multid -t
 1278 root      3644 S    dsld -i -n
 1287 root      6532 S    telefon a127.0.0.1
 1291 root      4796 S <  voipd
 1296 root      3660 S    pbd
 1300 root      3660 S    pbd
 1302 root      3660 S    pbd
 1539 root      1624 S    httpd -P /var/run/webcfg.pid -p 81 -c /mod/etc
30165 root      1480 S    dropbear -p 22 -R
30166 root      1456 S    -sh
enter PS and check, if there is a httpd -P /var/run/webcfg.pid -p 81 -c /mod/etc and a dropbear -p 22 -R
There is no mod directory...
Only these..
# ps
  PID  Uid        VSZ Stat Command
    1 root       1308 S   init
    2 root            SWN [ksoftirqd/0]
    3 root            SW< [events/0]
    4 root            SW< [khelper]
    5 root            SW< [kthread]
    6 root            SW< [kblockd/0]
   23 root            SW< [pdflush]
   24 root            SW< [pdflush]
   26 root            SW< [aio/0]
   25 root            SW  [kswapd0]
   62 root            SW  [pm_info]
   66 root            SW< [CPMAC]
   70 root            SW  [mtdblockd]
   96 root            SW  [tffsd_mtd_0]
  206 root            SWN [jffs2_gcd_mtd6]
  231 root            SW< [capi_oslib]
  232 root            SW< [capi_oslib]
  233 root            SW  [capitransp]
  240 root            SW  [glob_codecs]
  255 root            SW< [khubd]
  296 root       7776 S N ctlmgr
  324 root       4396 S   igdd
  339 root       2588 S   multid
  343 root       2964 S   dsld -i -n
  359 root       5008 S   telefon a127.0.0.1
  364 root       4360 S < voipd
  367 root       2356 S   pbd
  368 root       2356 S   pbd
  373 root       2356 S   pbd
  374 root       2356 S   pbd
  380 root        856 S   /bin/run_clock -c /dev/tffs -d
  389 root       1308 S   init
  394 root       7776 S N ctlmgr
  395 root       7776 R N ctlmgr
  396 root       7776 S N ctlmgr
  397 root       7776 S N ctlmgr
  398 root       7776 S N ctlmgr
  419 root       4396 S   igdd
  420 root       4396 S   igdd
  421 root       4396 S   igdd
  429 root       2360 S   usermand
  432 root            RWN [kdsld_token]
  483 root       1308 S   telnetd -l /sbin/ar7login
  518 root       1324 S   -sh
  566 root       1308 R   ps
Are you sure, you have flashed your fresh-built image to the box?
you can do that dirctly from your build environment
go to subfolder tools
enter
push_firmware ../tools/<your image name>.image "<the boot ip of the box>"
e.g: Knoppix@Knoppix:~/freetz-1.0/tools push_firmware kernel.image 192.168.178.1
I ask, because the usermand is running, but you have selected to opt it out in your config.
I select: Setting->System->Firmware Update->Firmware File
Then i select my image and push start update..
It says Updating the system please wait a moment.. Meanwhile the info led is flashing..
Then a message comes up saying: Attention!
The specified file does not contain firmware released for this device by AVM.
Cancel or continue update..
I select continue
The info led is flashing again.. With a new mesg.. Transmitting the firmware to your system.
Then i think it reboots as when the info stops flashing then is power led turn..
I lose connection and when it stops flashing its on and up.
Then i can normaly connect internet but no freetz stuff...
