Client connecting to 192.168.1.198, TCP port 5001
TCP window size: 8.00 KByte (default)
[1812] local 192.168.1.5 port 3122 connected with 192.168.1.198 port 5001
[ ID] Interval Transfer Bandwidth
[1812] 0.0- 1.0 sec 2552 KBytes 20906 Kbits/sec
[1812] 1.0- 2.0 sec 2696 KBytes 22086 Kbits/sec
[1812] 2.0- 3.0 sec 2664 KBytes 21823 Kbits/sec
[1812] 3.0- 4.0 sec 2600 KBytes 21299 Kbits/sec
[1812] 4.0- 5.0 sec 2640 KBytes 21627 Kbits/sec
[1812] 5.0- 6.0 sec 2560 KBytes 20972 Kbits/sec
[1812] 6.0- 7.0 sec 2696 KBytes 22086 Kbits/sec
[1812] 7.0- 8.0 sec 2656 KBytes 21758 Kbits/sec
[1812] 8.0- 9.0 sec 2704 KBytes 22151 Kbits/sec
[1812] 9.0-10.0 sec 2656 KBytes 21758 Kbits/sec
[1812] 0.0-10.0 sec 26432 KBytes 21619 Kbits/sec
iperf -c 192.168.1.198 -P 1 -i 1 -p 5001 -f k -t 10
[1808] local 192.168.1.5 port 3596 connected with 192.168.1.198 port 5001
[1808] 0.0- 1.0 sec 3336 KBytes 27329 Kbits/sec
[1808] 1.0- 2.0 sec 2696 KBytes 22086 Kbits/sec
[1808] 2.0- 3.0 sec 2568 KBytes 21037 Kbits/sec
[1808] 3.0- 4.0 sec 2696 KBytes 22086 Kbits/sec
[1808] 4.0- 5.0 sec 2704 KBytes 22151 Kbits/sec
[1808] 5.0- 6.0 sec 2624 KBytes 21496 Kbits/sec
[1808] 6.0- 7.0 sec 2648 KBytes 21692 Kbits/sec
[1808] 7.0- 8.0 sec 2688 KBytes 22020 Kbits/sec
[1808] 8.0- 9.0 sec 2600 KBytes 21299 Kbits/sec
[1808] 9.0-10.0 sec 2640 KBytes 21627 Kbits/sec
[1808] 0.0-10.0 sec 27208 KBytes 22254 Kbits/sec
Done.
iperf -c 192.168.1.198 -P 1 -i 1 -p 5001 -w 56.0K -f k -t 10
TCP window size: 56.0 KByte
[1808] local 192.168.1.5 port 3615 connected with 192.168.1.198 port 5001
[1808] 0.0- 1.0 sec 4488 KBytes 36766 Kbits/sec
[1808] 1.0- 2.0 sec 4480 KBytes 36700 Kbits/sec
[1808] 2.0- 3.0 sec 4440 KBytes 36372 Kbits/sec
[1808] 3.0- 4.0 sec 4536 KBytes 37159 Kbits/sec
[1808] 4.0- 5.0 sec 4624 KBytes 37880 Kbits/sec
[1808] 5.0- 6.0 sec 4456 KBytes 36504 Kbits/sec
[1808] 6.0- 7.0 sec 4400 KBytes 36045 Kbits/sec
[1808] 7.0- 8.0 sec 4368 KBytes 35783 Kbits/sec
[1808] 8.0- 9.0 sec 4328 KBytes 35455 Kbits/sec
[1808] 9.0-10.0 sec 4384 KBytes 35914 Kbits/sec
[1808] 0.0-10.0 sec 44512 KBytes 36407 Kbits/sec
Done.
Ah ... das wusste ich nicht. Die AVM "Hotline" hat sich an meiner Aussage "WDS halbiert den Durchsatz nicht." nicht stören lassen. Naja ...Bei WDS halbiert sich der Durchsatz, denn der Repeater wird alles was empfangen wurde nochmal aussenden, egal ob jemand im WLAN lauscht oder nicht.
Ich nehme an du machst eine Anspielung auf 802.11b. Ich habe es jetzt einmal testweise ausgeschaltet. In der Tat habe ich keine 802.11b Geräte. Ich bleibe jetzt vorerst einmal bei 802.11 n+g bis ich das Ding hier im Griff habe.Gibt es einen Grund, warum du im 2,4GHz-Band "802.11n+g+b" gewählt hast?
C:\Documents and Settings\Administrator>"d:\Program Files\iperf\iperf.exe" -i 1 -f k -c 192.168.1.190
Client connecting to 192.168.1.190, TCP port 5001
[1812] local 192.168.1.5 port 3876 connected with 192.168.1.190 port 5001
[1812] 0.0- 1.0 sec 2072 KBytes 16974 Kbits/sec
[1812] 1.0- 2.0 sec 2048 KBytes 16777 Kbits/sec
[1812] 2.0- 3.0 sec 2008 KBytes 16450 Kbits/sec
[1812] 3.0- 4.0 sec 1696 KBytes 13894 Kbits/sec
[1812] 4.0- 5.0 sec 1528 KBytes 12517 Kbits/sec
[1812] 5.0- 6.0 sec 2048 KBytes 16777 Kbits/sec
[1812] 6.0- 7.0 sec 2064 KBytes 16908 Kbits/sec
[1812] 7.0- 8.0 sec 2072 KBytes 16974 Kbits/sec
[1812] 8.0- 9.0 sec 2096 KBytes 17170 Kbits/sec
[1812] 9.0-10.0 sec 2072 KBytes 16974 Kbits/sec
[1812] 0.0-10.0 sec 19712 KBytes 16123 Kbits/sec
Ich möchte zunächst einmal wissen was die FB7390 maximal kann, ohne Schnickschnack à la WDS usw. Also eben mit optimalen Einstellungen. Wenn ich deine Werte so sehe die du oben gepostet hast, dann sehe ich das wohl als Ziel an (#117 Mib/s).Welche Datenrate ist denn eigentlich Dein Ziel?
Wenn ich dich richtig verstehe müsste meine FB3270 dann "AP-Client- bzw. Universalrepeater-Modus" sein/können.Als Client geht derzeit nur eine 7390 oder eben ein Router/AP mit AP-Client- bzw. Universalrepeater-Modus.
Es ist schon erstaunlich. Du und deinen Kollegen testen nun schon über drei Monate, und jetzt nimmst du einen anderen Laptop und kommst schlagartig auf den doppelten Durchsatz?Alle Code Schnippsel der letzten paar iperf Ausgaben wurden mit einem bestimmten Laptop gemacht. Mit einem anderen Laptop komme ich auf 35 Mib/s
Ja ... ich erkläre ... (1.) teste ich nicht 3 Monate. Ich habe auch noch andere Dinge zu tun . Die Sache wurde vor einigen Tagen hier wieder aktuell, deshalb habe ich nachgehakt. (2.) Das mit dem Laptop war in der Tat nicht sehr optinal gemacht. Das Laptop welches ich in den letzten Tests benutzt habe ist zwar recht neu, jedoch blicke ich bei den Einstellungen nicht ganz durch. Datenblatt sagt 802.11a/g/n und 300 Mib/s, jedoch habe ich meine Zweifel ob's wirklich 40 MHz macht bzw. dies mit der FB7390 korrekt aushandelt. Das zweite Laptop ist gerade mal 8 Monate alt (Sony VAIO). Mit diesem erreiche ich dann auch die 40 Mib/s, eben das höchste was ich mit meiner FB7390 je gesehen habe. (3.) Kollegen kamen mit FB7390 und diverser Hardware auch nie über 40 Mib/s. Für weitere Tests bleibe ich beim Sony VAIO, der bisher die höchsten Werte erreicht hat.Es ist schon erstaunlich. Du und deinen Kollegen testen nun schon über drei Monate, und jetzt nimmst du einen anderen Laptop und kommst schlagartig auf den doppelten Durchsatz?
Alle Tests waren bei mir jeweils unter optimalen Bedingungen, also Nahbereich ohne Wände und andere WLAN Geräte.Das Optimum von 120 Mbit/s netto geht natürlich nur im Nahbereich, weiter weg und hinter Wänden wird es sukzessive weniger.
"Nur eine 7390" bedeutet bei mir, dass keine andere AVM-Box im Moment den WLAN/AP-Client-Modus kann und du eine zweite 7390 benötigst oder preiswertere 300Mbit-AP-Client-fähige Router von anderen Herstellern.
... Also wenn ein AVM Produkt, dann muss es eine FB7390 sein. Danke!
C:\Users\geohei\Desktop\iperf>iperf -c 192.168.1.5 -f k -P 1
Client connecting to 192.168.1.5, TCP port 5001
[148] local 192.168.1.9 port 51328 connected with 192.168.1.5 port 5001
[148] 0.0-10.0 sec 36440 KBytes 29841 Kbits/sec
C:\Users\geohei\Desktop\iperf>iperf -c 192.168.1.5 -f k -P 12
[228] local 192.168.1.9 port 51339 connected with 192.168.1.5 port 5001
[244] local 192.168.1.9 port 51341 connected with 192.168.1.5 port 5001
[236] local 192.168.1.9 port 51340 connected with 192.168.1.5 port 5001
[204] local 192.168.1.9 port 51336 connected with 192.168.1.5 port 5001
[220] local 192.168.1.9 port 51338 connected with 192.168.1.5 port 5001
[172] local 192.168.1.9 port 51332 connected with 192.168.1.5 port 5001
[196] local 192.168.1.9 port 51335 connected with 192.168.1.5 port 5001
[160] local 192.168.1.9 port 51331 connected with 192.168.1.5 port 5001
[212] local 192.168.1.9 port 51337 connected with 192.168.1.5 port 5001
[188] local 192.168.1.9 port 51334 connected with 192.168.1.5 port 5001
[180] local 192.168.1.9 port 51333 connected with 192.168.1.5 port 5001
[148] local 192.168.1.9 port 51330 connected with 192.168.1.5 port 5001
[244] 0.0-10.0 sec 7280 KBytes 5955 Kbits/sec
[228] 0.0-10.0 sec 9840 KBytes 8048 Kbits/sec
[204] 0.0-10.0 sec 8896 KBytes 7280 Kbits/sec
[220] 0.0-10.0 sec 10064 KBytes 8235 Kbits/sec
[236] 0.0-10.0 sec 9832 KBytes 8043 Kbits/sec
[172] 0.0-10.0 sec 9856 KBytes 8061 Kbits/sec
[196] 0.0-10.0 sec 9752 KBytes 7979 Kbits/sec
[212] 0.0-10.0 sec 9520 KBytes 7793 Kbits/sec
[160] 0.0-10.0 sec 9600 KBytes 7855 Kbits/sec
[180] 0.0-10.0 sec 9928 KBytes 8129 Kbits/sec
[188] 0.0-10.0 sec 9088 KBytes 7439 Kbits/sec
[148] 0.0-10.0 sec 9008 KBytes 7376 Kbits/sec
[SUM] 0.0-10.0 sec 112664 KBytes 91866 Kbits/sec
