ovpn.log
Mon Mar 3 08:23:32 2014 us=851643 WARNING: file '/var/tmp/client.key' is group or others accessible
Mon Mar 3 08:23:32 2014 us=853141 Static Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mon Mar 3 08:23:32 2014 us=854321 Static Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Mar 3 08:23:32 2014 us=856015 Static Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mon Mar 3 08:23:32 2014 us=857101 Static Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Mar 3 08:23:32 2014 us=858536 Socket Buffers: R=[204800->131072] S=[204800->131072]
Mon Mar 3 08:23:32 2014 us=881563 TUN/TAP device tun0 opened
Mon Mar 3 08:23:32 2014 us=882454 TUN/TAP TX queue length set to 100
Mon Mar 3 08:23:32 2014 us=884299 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mon Mar 3 08:23:32 2014 us=885283 /sbin/ifconfig tun0 192.168.7.2 pointopoint 192.168.7.1 mtu 1500
Mon Mar 3 08:23:32 2014 us=902450 /sbin/route add -net 192.168.0.0 netmask 255.255.255.0 gw 192.168.7.1
Mon Mar 3 08:23:32 2014 us=910730 Data Channel MTU parms [ L:1548 D:1350 EF:48 EB:4 ET:0 EL:0 ]
Mon Mar 3 08:23:32 2014 us=912099 Fragmentation MTU parms [ L:1548 D:1400 EF:48 EB:4 ET:0 EL:0 ]
Mon Mar 3 08:23:32 2014 us=912935 UDPv4 link local (bound): [undef]
Mon Mar 3 08:23:32 2014 us=913927 UDPv4 link remote: [AF_INET]4.4.4.4:1200
Mon Mar 3 08:23:34 2014 us=78617 FRAG_IN error flags=0xfa2a187b: FRAG_TEST not implemented
Mon Mar 3 08:23:34 2014 us=79324 FRAG_IN error flags=0xfa287f34: spurrious FRAG_WHOLE flags
... (2 lines repeated )
Mon Mar 3 08:27:35 2014 us=815451 FRAG_IN error flags=0xfa2a187b: FRAG_TEST not implemented
Mon Mar 3 08:27:35 2014 us=815941 FRAG_IN error flags=0xfa287f34: spurrious FRAG_WHOLE flags
Mon Mar 3 08:27:42 2014 us=293583 Inactivity timeout (--ping-restart), restarting
Mon Mar 3 08:27:42 2014 us=294012 TCP/UDP: Closing socket
Mon Mar 3 08:27:42 2014 us=294459 /sbin/route del -net 192.168.0.0 netmask 255.255.255.0
Mon Mar 3 08:27:42 2014 us=301866 Closing TUN/TAP interface
Mon Mar 3 08:27:42 2014 us=303384 /sbin/ifconfig tun0 0.0.0.0
Mon Mar 3 08:27:42 2014 us=344028 SIGUSR1[soft,ping-restart] received, process restarting
Mon Mar 3 08:27:42 2014 us=345206 Restart pause, 2 second(s)
# busybox route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.7.1 * 255.255.255.255 UH 0 0 0 tun0
192.168.180.1 * 255.255.255.255 UH 2 0 0 dsl
192.168.180.2 * 255.255.255.255 UH 2 0 0 dsl
5.5.5.5 * 255.255.255.255 UH 2 0 0 dsl
217.237.151.205 * 255.255.255.255 UH 2 0 0 dsl
217.237.150.115 * 255.255.255.255 UH 2 0 0 dsl
192.168.0.0 192.168.7.1 255.255.255.0 UG 0 0 0 tun0
192.168.179.0 * 255.255.255.0 U 0 0 0 guest
192.168.10.0 * 255.255.255.0 U 0 0 0 lan
169.254.0.0 * 255.255.0.0 U 0 0 0 lan
default * 0.0.0.0 U 2 0 0 dsl
# netstat -an
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:51111 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:51112 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:1011 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:8888 0.0.0.0:* LISTEN
tcp 0 0 192.168.10.239:22 192.168.10.1:49675 ESTABLISHED
tcp 0 0 127.0.0.1:1011 127.0.0.1:59663 ESTABLISHED
tcp 0 0 192.168.10.239:22 192.168.10.1:49326 ESTABLISHED
tcp 0 0 127.0.0.1:59663 127.0.0.1:1011 ESTABLISHED
tcp 0 0 192.168.10.239:22 192.168.10.1:62048 ESTABLISHED
udp 0 0 192.168.10.239:137 0.0.0.0:*
udp 0 0 169.254.1.1:137 0.0.0.0:*
udp 0 0 0.0.0.0:137 0.0.0.0:*
udp 0 0 192.168.10.239:138 0.0.0.0:*
udp 0 0 169.254.1.1:138 0.0.0.0:*
udp 0 0 0.0.0.0:138 0.0.0.0:*
udp 0 0 192.168.10.239:41631 0.0.0.0:*
udp 0 0 192.168.10.239:58283 0.0.0.0:*
udp 0 0 0.0.0.0:1200 0.0.0.0:*
udp 0 0 127.0.0.1:323 0.0.0.0:*
udp 0 0 0.0.0.0:67 0.0.0.0:*
udp 0 0 0.0.0.0:1900 0.0.0.0:*
udp 0 0 192.168.10.239:1900 0.0.0.0:*
udp 0 0 0.0.0.0:123 0.0.0.0:*
raw 0 0 0.0.0.0:2 0.0.0.0:* 2
