[Gelöst] OpenStage 40 Fehler RF2 an FritzBox
mcmods
17 Feb 2021
Moin, hab mein 40er HFA V3 mit der Firmware OS40_SIP_V3_R5_17_0 bestückt und soweit "eingerichtet" jedoch bekomme es nicht hin das es läuft
hab auch das mit dem 8 Buchstaben etz. eingegeben... jedoch lüppt einfach nicht.....
Diagnose Übersicht
2021-02-17 17:45:31
00 Terminal number10000620
01 SIP server192.168.178.1
02 SIP port5060
03 SIP registrar192.168.178.1
04 SIP registrar port5060
05 SIP gatewayNone
06 SIP gateway port5060
07 SIP transportUDP
08 TLS renegotiationSecure (RFC5746)
09 SIP local5060
10 Server featuresNo
11 DNS resultsnone
12 MultilineNo
13 Keyset linesNone
14 Backup activeYes
15 Backup proxyNone
16 Use secure callsNo
17 SDES statusDisabled
18 SIP server cert. checkNo certificate check
19 Software versionV3R5.17.0 SIP 190920
20 Display messageTelefonie ausgefallen (RF2)
21 Last restart2021-02-17T17:34:57
22 Memory free30740K free
23 Protocol modeIPv4_IPv6
24 IP4 address192.168.178.84
25 IP4 subnet mask255.255.255.0
26 IP4 default route192.168.178.1
27 Primary DNS192.168.178.1
28 Secondary DNSNone
29 IP4 route 1 IPNone
30 IP4 route 1 gatewayNone
31 IP4 route 1 maskNone
32 IP4 route 2 IPNone
33 IP4 route 2 gatewayNone
34 IP4 route 2 maskNone
35 IP6 addressNone
36 IP6 prefix lengthNone
37 IP6 global gatewayNone
38 IP6 link local addrNone
39 IP6 route 1 destNone
40 IP6 route 1 pref lenNone
41 IP6 route 1 gatewayNone
42 IP6 route 2 destNone
43 IP6 route 2 pref lenNone
44 IP6 route 2 gatewayNone
45 MAC address001ae872b60f
46 LLDPYes
47 VLAN discoveryLLDP-MED
48 DHCPv4Yes
49 DHCPv4 re-useNo
50 DHCPv6Yes
51 DHCPv6 re-useNo
52 LAN port typeAutomatic
53 PC port statusDisabled
54 PC port typeAutomatic
55 PC port autoMDIXNo
56 VLAN IDNone
57 QoS Layer 2Yes
58 QoS Layer 2 voice5
59 QoS Layer 2 signalling3
60 QoS Layer 2 default0
61 QoS Layer 3Yes
62 QoS Layer 3 voiceEF / 46
63 QoS Layer 3 signallingAF31 / 26
64 LLDP-MED operationSent: Wed Feb 17 17:45:30 2021
Chassis ID TLV Data
.Subtype = Network address
.IANA_TYPE = IPv4 Address
.ID = 192.168.178.84
Port ID TLV Data
.Subtype = MAC address
.ID = 00:1A:E8:72:B6:0F
TTL TLV data
.seconds = 120
System Caps TLV Data
.Supported = Bridge, Telephone,
.Enabled = Telephone,
MAC_Phy config TLV data
.Auto-set supported = Yes
.Auto-set enabled = Yes
.PMD = 0x6c00
.PMD1 = 10BASE-T half duplex mode
.PMD2 = 10BASE-T full duplex mode
.PMD3 = 100BASE-TX half duplex mode
.PMD4 = 100BASE-TX full duplex mode
.MAU = 100BaseTXFD : 0x10
LLDP-MED Caps TLV Data
.Caps - LLDP-MED = Yes
.Caps - Network Policy = Yes
.Caps - Location ID = No
.Caps - Extended Power Mdi PD = Yes
.Caps - Extended Power Mdi Pse = No
.Caps - Inventory = No
.Type = Endpoint Class III
Network policy (Voice) TLV data
.Policy unknown = Yes
.Tagged = No
.VLAN ID = 0
.Layer 2 priority = 0
.DSCP = 0
Network policy (Voice Signalling) TLV data
.Tagged = No
.VLAN ID = 0
.DSCP = 0
Network policy (Video conferencing) TLV data
.Tagged = No
.VLAN ID = 0
.DSCP = 0
Extended Power TLV data
.Type = PD
.Source = Unknown
.Priority = Critical
.Power value = 46
Received: Wed Feb 17 17:45:30 2021
TTL TLV data
.seconds =
Network policy
.TLV not available
65 NG911 locationDisabled
66 FIPS enabledNo
einer ne Idee ?
ähm ja....... guten Morgen.. DANKE :D
