Neue Firmware für das Openstage 60 SIP
securiti
26 Jan 2005
Es ist eine neue Firmware erschienen für das Openstage 60 SIP.
OS_60_SIP_V2_R0_41_0.
Welchen Unterschied sie zur vorgehenden hat habe ich noch nicht herausgefunden.
LG
Oliver
Fixed Bugs
ID Cluster Summary
NA04223599 Openstage 40 Get Freeze
NA03996041 VoiceMail / Missed Call Button (envelope button) works differently on V1 and V2 OpenStage software
NA04079877 SIP INFO message destroys call context
NA04331416 Settings menu displayed after mobile user log off
NA04314394 unlock not possible after push notification from XML Server
NA04331782 Problem with DNS-SRV
NA04020673 Software download via HTTPS isn't possible
NA04012862 OpenStage timezone offset is not converted correctly.
NA04325724 OpenStage 60 reboots without user interaction
NA03958080 When the OpenStage is restarted from DLS or from the Web I-face it sends snmp generic-trap: coldStart instead of warmStart
NA04278500 BLF-Module-LED-update after restart of Asterisk Pbx-system.
NA04061325 Long pres at keypad key entering number twice
NA04350108 If country settings are changed from GB (default) to any other (here: DE) via phone's User menu/Locality, phone confirms with message "Changes saved successfully" but afterwards GB is still active.
NA04285850 Openstage 40 no sounds (no sound on ringing, loudspeaker and handset)
NA04238828 sometimes deflect popup is empty
NA04389148 Openstage reboot by himself
NA04409846 missing 180 ringing message from phone
NA04438521 Phone is ringing permanent until reboot
NA04446468 OpenStage 60 at attendant stations stuck
NA04460799 intermittently no audio for incoming call on Openstage 40
NA04480408 sporadic no ringtone
NA04387668 Openstage 20 sporadically reboots
NA04498998 OS40 send RTP after BYE//no Audio incoming Call
NA04509255 “500 Internal server error” message after short bye/invite sequence
NA04521474 Openstage 15 sporadically reboots
Quelle: Siemens Wiki
