NAT/DHCP server not working?
marduk
24 Jul 2007
I have got a Fritz!Box fon WLAN 7140 recently. One of the first things I did was upgrading the firmware from 39.04.20 to 39.04.34. It took me a while to find out that an 169.254.1.1 address is used in recent versions, but now I have recovered the connectivity to my box :)
The most pressing issue I have not sorted out yet is that Fritz!Box does not assign via DHCP the IP addresses from the private network subnet to the devices in my network. It is connected to a cable modem and has internet connection sharing via LAN 1 port enabled. If I have DHCP enabled on the wired interface of my PC and then plug it into LAN 2 port of the Fritz!Box, Fritz!Box acts a "hub" and the PC gets IP address directly from the DHCP server of my ISP. On wireless interface this does not happen, I think. PC simply fails to obtain address then.
AVM positions Fritz!Box as a WLAN router with DHCP server and IP masquerading/Network Address Translation. But I can't find how the DHCP server and NAT configuration are to be done. I would appreciate if someone could point me in needed direction.
I think I know why I am missing this. There is no "IP Addresses" button in "System / Network Settings" menu in expert mode. This has been this way on both tried firmware versions. Very interesting...
I have discovered that many other tabs among those that should be shown in expert mode (if not all) are missing. Anybody had similar experience? AVM support is so slow...
My bad, I shouldn't have used the "Share existing Internet connection in the network (IP Client)" mode. Changing mode to "Establish own Internet connection (NAT router with PPPoE or IP)" solved the issue.
Ayzham
