[INFO] Neue Version DD-WRT v23 Beta
den request hatte ich schon oft. mal schauen was ich im build system noch einbauen kann damit das für euch etwas einfacher wird.
ahso wehn es interessiert. ich vermarkte dd-wrt für kommerzielle zwecke unter www.blueline-ag.de
für privatnutzer und nicht kommerzielle projekte bleibt aber natürlich alles frei incl. der quellcodes
06.10.2005:
upnp site added (thx for your great patch nohud)
wan detection dix (again, thx nohud)
client mode fixed
some small asus related fixes added
symbols for tcpdump added
matrixssl updated
new design added (by Daniel Wikar)
updated pptp client by Cesar Gonzales
04.10.2005:
ssh is back (mini version)
ASUS-WL500G Deluxe is supported now
wireless mode selection fixed. (mixed mode problem)
kromos style fixes integrated
WMM/WME additions within the network code
another try for a upnp solution
Neue BETA2 in 3 (!) Ausführungen, für G, GS und GS Hardwareversion 4
v23-beta-2:
14.10.2005:
zlib support added for dropbear
12.10.2005:
pppoe support for wireless client mode added (does this really work?)
zero config for chillispot updated
port forwarding port from/to swapping issue fixed
11.10.2005:
additional port forwarding table added (with from and to assignment, yes)
multicast proxy added
10.10.2005:
ssh fixed
auto disable for backup and firmware upgrade within https environment
ipkg repository list updated
kaid removed from voip version due fw size limit
ebtables is back for qos
(warning, lowers your network speed if you're using it)
thats means also, never use qos with LAN/WLAN selection if you want high
performance. use wan based networking instead
wireless mac issue fixed (asus only)
logging issue fixed (auto switching loglevel)
port forwarding bug fixed (tcp/udp switch)
port forwarding save bug fixed
connlimit/connrate added
internal memory management optimized (webgui only)
07.10.2005:
progressive port forwarding added (gui)
progressive port triggering added (gui)
mixed readded for client mode
some internal kernel changes (will be used in future)
new pptpd version
new dropbear version
20.10.2005:
removed unused web-cgi code
removed unused linux modules
httpd (ssl) staticly linked to matrixssl (smaller)
udhcpd statics fixed
l7filter fixed
dnsmasq does now support lease informations too
19.10.2005:
dynamic dhcp static lease table added
dnsmasq dhcp does now support static leases too
build date added to the header line
2 new fancy styled added (red and green by Guilty Spark)
Neue Version vom 21. Ich finde: WOW
Ein "must have".
Der Skin "cyan" ist ziemlich gut gelungen!
  • screenshots_943.zip
Was ist eigentlich der Unterschied zwischen der dd-wrt.v23_voip.bin und der dd-wrt.v23_voip_wrt54g.bin
Und irgendwie scheint es da auch nochn Problem mit dem CLONE MAC ADRESS zu geben denn das funktioniert nicht richtig. Wenn ich dort die Adresse die bei meinem Provider registriert is eingebe, wird diese vom Provider nicht richtig erkannt in der Beta 1 ging das noch alles ausserdem gibts irgendwie immer probleme beim Backup, klicke ich den Button dann hängt sich der Router auf.
du mußt die wan mac clonen das war auch schon immer so.
und die backup funktion geht mit der voip nur ordentlich auf dem gs da der wrt54g einfach nicht mehr genug speicher hat.
an sonsten gibt es zwischen der voip, voipwrt54g und voip wrt54gs keinen unterschied. es sind nur unterschiedliche binary formate für tftp flashen.
die normale voip geht via webinterface eigentlich bei allen. bei neueren modellen muß man allerdings zuerst die mini flashen da die neueren linksys firmwares keine firmware binaries größer 3 mb mögen
so. da bin ich mal wieder
dd-wrt unterstützt seit heute auch das Siemens Gigaset SE505
27.10.2005:
Siemens SE505 support finished. works and fully tested (mini,std,voip)
(see hwsupport.txt for additional notes)
added linksys wds/wpa fixes
26.10.2005:
iptables reworked for memory optimization
library size optimization added
possibly tx/rx antenna selection problem fixed
25.10.2005:
service restart functions enhanced. (some services arent restarted correctly from the Service GUI etc.)
Siemens gigaset 505 detection introduced (not finished yet, so dont play around with it)
iptables fix for upnp (please try it)
FilterSummary table header fixed
24.10.2005:
webgui fix for dhcpd (crashbug cause of missplaced pointer var)
wbr2g54s typo fix (wireless driver wasnt loaded)
merge of latest squashfs sources to the lzma squashfs code (decreases memory usage)
