Hylafax faxaddmodem hängt bei probing
humanlike
20 Mrz 2009
Ich scheine asterisk soweit korrekt eingerichtet zu haben:
asteriskXantorix*CLI> iax2 show peers
Name/Username    Host                                           Mask                                      Port           Status      Description
iaxmodem         127.0.0.1                                (D)  (null)                                    4570           OK (3 ms)
1 iax2 peers [1 online, 0 offline, 0 unmonitored]
asteriskXantorix*CLI> sip show peers
Name/username             Host                                    Dyn Forcerport Comedia    ACL Port     Status      Description
620/asterisk              192.168.103.1                               Yes        No             5060     Unmonitored
1 sip peers [Monitored: 0 online, 0 offline Unmonitored: 1 online, 0 offline]
Leider hänge ich bei hylafax beim probing ganz am Ende von faxaddmodem.
~# faxaddmodem
Serial port that modem is connected to [ttyS0]? ttyIAX0
Ok, time to setup a configuration file for the modem.  The manual
page config(5) may be useful during this process.  Also be aware
that at any time you can safely interrupt this procedure.
Reading scheduler config file /var/spool/hylafax/etc/config.
No existing configuration, let's do this from scratch.
Country code [1]? 49
Area code [415]? 9227
Phone number of fax modem [+1.999.555.1212]? +49.9227.9739127
Local identification string (for TSI/CIG) ["NothingSetup"]?
Long distance dialing prefix [1]? 0
International dialing prefix [011]? 00
Dial string rules file (relative to /var/spool/hylafax) [etc/dialrules]?
Tracing during normal server operation [1]?
Tracing during send and receive sessions [11]?
Protection mode for received facsimile [0600]?
Protection mode for session logs [0600]?
Protection mode for ttyIAX0 [0600]?
Rings to wait before answering [1]?
Modem speaker volume [off]?
Command line arguments to getty program ["-h %l dx_%s"]?
Pathname of TSI access control list file (relative to /var/spool/hylafax) [""]?
Pathname of Caller-ID access control list file (relative to /var/spool/hylafax) [""]?
Tag line font file (relative to /var/spool/hylafax) [etc/lutRS18.pcf]?
Tag line format string ["From %%l|%c|Page %%P of %%T"]?
Time before purging a stale UUCP lock file (secs) [30]?
Hold UUCP lockfile during inbound data calls [Yes]?
Hold UUCP lockfile during inbound voice calls [Yes]?
Percent good lines to accept during copy quality checking [95]?
Max consecutive bad lines to accept during copy quality checking [5]?
Max number of pages to accept in a received facsimile [25]?
Syslog facility name for ServerTracing messages [daemon]?
Set UID to 0 to manipulate CLOCAL [""]?
Use available priority job scheduling mechanism [""]?
The non-default server configuration parameters are:
CountryCode:            49
AreaCode:               9227
FAXNumber:              +49.9227.9739127
LongDistancePrefix:     0
InternationalPrefix:    00
DialStringRules:        etc/dialrules
SessionTracing:         11
RingsBeforeAnswer:      1
SpeakerVolume:          off
GettyArgs:              "-h %l dx_%s"
LocalIdentifier:        "NothingSetup"
TagLineFont:            etc/lutRS18.pcf
TagLineFormat:          "From %%l|%c|Page %%P of %%T"
MaxRecvPages:           25
Are these ok [yes]? yes
Now we are going to probe the tty port to figure out the type
of modem that is attached.  This takes a few seconds, so be patient.
Note that if you do not have the modem cabled to the port, or the
modem is turned off, this may hang (just go and cable up the modem
or turn it on, or whatever).
Probing for best speed to talk to modem: 38400
Was kann ich noch tun um zu schauen, ob ich soweit alles korrekt eingerichtet habe?
Hi, jetzt sind wir Leidensgenossen. Nach upgrade auf Debian11 hänge ich auch da beim Modemtest.
