Oh I meet some questions. I am using britzbox 7590 and fritzos 7.29.Any way to extract firmware completely? I tried to extract from 7.29.image but I cant find httpd and other important binary files.->https:// en。AVM。De/service/知识库/Dok/FRITZ-Box-7490/1635_Access-to-the-FRITZ-Box-via-Telnet-is-not-supported/
Telnet:
[URL unfurl = "true"]https:// www。知识产权-相信De/44-和-7590 。 De/fritz-box-7580-firmware-153-06-90-telnet-service-freischalten-geht-auch-f % C3 % BCr-7560-and-7590。296678/[/包括]
Thanks for reply. That project seems stopped update. I still wonder that how can freetz-ng and yourfritz be used. According peterpawn I guess linking usr/sbin/telnetd to bin/busybox and change some flags and packing up as image, then using the image update the firmware can enable telnet works. Is it real?And can work in fritzos 7.29 ?Sorry for so many questions.@55k, @er13 will probably not comply with the request (see maintenance note):
https://github.com/Freetz/freetz#project-maintenance-note
And the firmware will be completely unpacked. There is no (separate) httpd in FRITZ!OS. The Webinterface is provided by a proprietary service (ctlmgr) and the httpd is a part of the busybox.
modfs
, SSH isn't). For the first time access, you need to enable Telnet start by phone code, if it's NOT enabled already or was activated otherwise.
