Habe das mpg123 Packet installiert und versuche mit
exten => *9,1,WaitMusicOnHold(30)
MusicOnHold zum Laufen zu bringen... klappt aber ned!
Es kommt immer folgende Meldung wenn ich *9 an meinem ISDN-Telefon wähle:
Vor allem die erste Zeile "Unknown option: --mono"...
Was mach ich falsch? Habe alles so wie es aus dem Archiev kam gelassen...
musiconhold.conf
Muss dafür eine Soundkarte installiert sein???
High Performance MPEG 1.0 Audio Player for Layer 1,2 and 3. ..
Version 0.54 (97/03/27). Written and copyrights by Michael Hipp.
Uses code from various people. See 'README' for more!
usage: mpg123 [-n <num>] [-f <scalefactor>] [-t|-s] [-c] [-v] inputBS
where:
-t testmode .. only decoding, no output.
-s write to stdout
-c check for filter range violations.
-v verbose.
-q quiet.
-n <num> decode only <num> frames.
-skip <num> skip first <num> frames.
-f <factor> Change scalefactor (default: 32768).
-r <smplerate> Set samplerate (default: Automatic).
-g <gain> Set audio hardware output gain.
-os,-oh,-ol Set audio output line: speaker/headphone/line.
-single0,-single1 for stereomodes: decode only channel No.0 or No.1.
-singlemix only Layer3: mix both channels
inputBS input bit stream of encoded audio
musiconhold.conf
[classes]
default => quietmp3:/var/lib/asterisk/mohmp3
loud => mp3:/var/lib/asterisk/mohmp3
random => quietmp3:/var/lib/asterisk/mohmp3,-z
;unbuffered => mp3nb:/var/lib/asterisk/mohmp3
;quietunbuf => quietmp3nb:/var/lib/asterisk/mohmp3
; Note that the custom mode cannot handle escaped parameters (specifically embedded spaces)
;manual => custom:/var/lib/asterisk/mohmp3,/usr/bin/mpg123 -q -r 8000 -f 8192 -b 2048 --mono -s
