Where can I find the server name of KabelBW?
What kind of server do you expect to find of Kabel-BW? Kabel-BW is only the ISP and has nothing whatsoever to do with VoIP or any other applications you run over your connection.
So, let's try this a bit more systematically.
(1) You have your Fritz!Box Fon WLAN 7170 connected to the Kabel-BW cable modem with LAN1 and your PC is on LAN2, LAN3 or LAN4? Check the serial number of your FBF 7170 if it is in one of the ranges
- ####.229.00.000.001 - ####.229.00.004.641
- ####.228.00.000.001 - ####.228.00.187.671
- ####.221.00.000.001 - ####.221.00.999.999.
If so, this is not your lucky day. These early models you cannot reliably operate on a cable modem. If the serial is not in the range, consider yourself lucky
(2) What is the firmware version on your FBF 7170? If it is some xx.04.yy, this should work. You may want to upgrade to the latest firmware, which is 29.04.80. You can get it from
the official AVM download server.
(3) Connect the cable modem to the FBF 7170 with a straight Ethernet patch cable between the Ethernet port of the cable modem and LAN1 of the FBF 7170. Connect a PC to LAN2. Configure the FBF as follows (menu "Internet" -> "Zugangsdaten"):
- "Internetzugang über LAN1"
- "Internetverbindung selbst aufbauen (NAT-Router mit PPPoE oder IP)"
- "Zugangsdaten werden nicht benötigt (IP)"
- "IP-Adresse automatisch über DHCP beziehen"
- Enter credible values for upstream/downstream further below
- Save this form's settings
Now power off your cable modem and the FBF 7170. Wait 20 seconds. Power the cable modem on again. Wait 60 seconds. Switch on the FBF 7170. Wait 30 seconds. Power on your computer (which is on LAN2). Point a browser to the Fritz!Box Fon and check that there is a proper Internet connection. Try
www.google.de to verify the Internet connection.
(4) Point the browser to
www.actionvoip.com and see if it works. Open a DOS window and ping sip.actionvoip.com (the registrar server of actionvoip). This should look like
$ ping sip.actionvoip.com
PING sip.actionvoip.com (77.72.174.128): 56 data bytes
64 bytes from 77.72.174.128: icmp_seq=0 ttl=248 time=109 ms
64 bytes from 77.72.174.128: icmp_seq=1 ttl=248 time=10 ms
64 bytes from 77.72.174.128: icmp_seq=2 ttl=248 time=13 ms
64 bytes from 77.72.174.128: icmp_seq=3 ttl=248 time=11 ms
I also have Kabel-BW CleverKabel and can ping the SIP server. You should be able to do the same.
(5) Delete from the "Internettelefonieanbieter" configuration of VoIP providers any entries you don't need. Create a new one for ActionVoIP according to the instructions given
on their web site.
- Tick "Internetrufnummer verwenden" at the top
- Internettelefonie-Anbieter: "anderer Anbieter"
- Internetrufnummer: 8000
- Benutzername: your actionvoip user name
- Kennwort & Kennwortbestätigung: your actionvoip password
- Registrar: sip.actionvoip.com
- Proxy-Server: leave empty
- STUN-Server: leave empty
- Internetrufnummer für die Anmeldung verwenden: don't tick this box
- Rufnummernformat according to your location
This should set up ActionVoIP as a provider. You should see in the overview page that this account registered. If not, you'll get an error message in the log.
(6) Try to make a call using this provider using the respective *12x# prefix code on an analogue telephone connected to the FBF 7170. Make sure the number format is correct (depending on the "Rufnummernformat" you specified).
If you should get stuck in any step, let's know what happened. If we end up getting your box running, I should probably put this text into the wiki for further reference.
--gandalf.
