@lunzet - aus dem Handbuch:
Disconnect Tone - This is the tone script which describes to the SPA the tone to detect as a disconnect tone. The syntax follows a standard Tone Script with some restrictions. Default value is standard US reorder (fast busy) tone, for 4 seconds.
Restrictions:
1. 2 frequency components must be given. If single frequency is desired, the same frequency is used for both
2. The tone level value is not used. –30 (dBm) should be used for now.
3. Only 1 segment set is allowed
Das 450@-30,450@-30;1.4(.35/.35/1+2) oder 425@-30,425@-30;1.4(.35/.35/1+2) klingt sehr nach meiner Anlage, insbesondere die 0.35 Sekunden ...
Restrictions:
