root@fritz:/var/mod/root# dmesg
Linux version 2.6.32.41 (gcc version 4.6.1 (Buildroot 2011.08) ) #1 Mon Jun 4 16:38:22 CEST 2012
bootconsole [early0] enabled
CPU revision is: 00019068 (MIPS 4KEc)
[memsize] memsize=0x4000000
ur8_clk_get_pll_factor: 300000000
ur8_get_pci_clock 33333333
[setup_pci_master]
registering PCI controller with io_map_base unset
TI UR8 (7270), ID: 0x0030, Revision: 0x10
Determined physical RAM map:
Wasting 8192 bytes for tracking 256 unused pages
Zone PFN ranges:
Normal 0x00014000 -> 0x00018000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00014000 -> 0x00018000
On node 0 totalpages: 16384
free_area_init_node: node 0, pgdat 9457a660, node_mem_map 95000000
Normal zone: 128 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 16256 pages, LIFO batch:3
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: annex=B
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[avm_cache_set_coherency]: setting cache coherency for HWRevision=144 to write through
Primary instruction cache 16kB, VIPT, 4-way, linesize 16 bytes.
Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 16 bytes
Memory: 58036k/64064k available (3220k kernel code, 5960k reserved, 1366k data, 244k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:256
[mips_cpu_irq_init] irq_base 0
[mips_cpu_irq_init]change irqline 21 -> irqchan(prio) 8
[mips_cpu_irq_init]change irqline 8 -> irqchan(prio) 21
console [ttyS0] enabled, bootconsole disabled
Calibrating delay loop... 359.62 BogoMIPS (lpj=1798144)
Mount-cache hash table entries: 512
kernel_init: started
kernel_init: kernel locked
NET: Registered protocol family 16
[cpmac] Version: 1.108.1.101 - Revision 811:1778 - Mo 4.06.2012 16:38:04
MUSB UR8 pdev active!
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pcibios_read_config: accessing present PCI slot : 14, where 0, size 4
pci 0000:00:0e.0: reg 10 32bit mmio: [0x000000-0x00ffff]
Master and Slave Enabled
NET: Registered protocol family 8
NET: Registered protocol family 20
musb_hdrc: version 6.0, cppi-dma, host, debug=0
musb_hdrc: ConfigData=0x06 (UTMI-8, dyn FIFOs, SoftConn)
musb_hdrc: MHDRC RTL version 1.500
musb_hdrc: setup fifo_mode 2
musb_hdrc: 8/9 max ep, 3648/4096 memory
musb_core_init 1505: musb_hdrc: hw_ep 0shared, max 64
musb_core_init 1505: musb_hdrc: hw_ep 1tx, max 512
musb_core_init 1513: musb_hdrc: hw_ep 1rx, max 512
musb_core_init 1505: musb_hdrc: hw_ep 2tx, max 512
musb_core_init 1513: musb_hdrc: hw_ep 2rx, max 512
musb_core_init 1505: musb_hdrc: hw_ep 3tx, max 512
musb_core_init 1513: musb_hdrc: hw_ep 3rx, max 512
musb_core_init 1513: musb_hdrc: hw_ep 4rx, max 512
musb_hdrc: USB Host mode controller at a3400000 using DMA, IRQ 39
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[loadcontrol]module musb_hdrc registered
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.32.41 musb-hcd
usb usb1: SerialNumber: musb_hdrc
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
avm_net_trace: New net trace device 'usb1' registered with minor 161.
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
[simple_profiling] 0 entries 50 min
squashfs: version 3.4 (2008/08/26) Phillip Lougher
Installing knfsd (copyright (C) 1996 [email protected]).
fuse init (API version 7.13)
msgmni has been set to 113
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered (default)
[avm_membench_init]
avm_net_trace: Up and running.
[loadcontrol] set auto - scale=1
[avm] configured: watchdog event debug enable direct gpio
AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Jun 4 2012 16:37:37)
[simple-profiling]: no performance counters implemented
[avm]: AVM Simple Profiling enabled.
Serial: SERIAL_AVM_8250 driver
ttyS0 at MMIO 0x0 (irq = 15) is a PORT_16550A
[physmap_flash_probe] line=101, doing probes
physmap platform flash device: 01000001 at 10000000
[do_map_probe] driver_name=cfi_probe
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash.0: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
6 find_squashfs partitions found on MTD device physmap-flash.0
Creating 6 MTD partitions on "physmap-flash.0":
0x000000183c00-0x000000f80000 : "rootfs"
mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
0x000000020000-0x000000183c00 : "kernel"
mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
0x000000000000-0x000000020000 : "urlader"
0x000000f80000-0x000000fc0000 : "tffs (1)"
0x000000fc0000-0x000001000000 : "tffs (2)"
0x000000e80000-0x000000f80000 : "jffs2"
Generic platform RAM MTD, (c) 2004 Simtec Electronics
[dectsync] inactive
prefetch_code: 942b3000: len=1856
[cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver libusual
CAPI Subsystem Rev 1.1.2.8
AVM PA 2.7.7 2012-05-02
AVM PA skb pktinfo at offset 128 size 188
[loadcontrol]module avm_pa registered
TCP cubic registered
mcfw: IGMPv3 fast forwarding
NET: Registered protocol family 10
NET: Registered protocol family 17
atmpvc_init() failed with -17
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
mount on mtd3 and mtd4 (double buffering)
Adam2 environment variables API installed.
kernel_init: basic setup done
[squashfs] use lzma compression
VFS: Mounted root (squashfs filesystem) readonly on device 31:0.
Freeing bootloader memory: 1024k freed
Freeing unused kernel memory: 244k freed
trying /sbin/init
TFFS Name Table H
led_modul_Fritz_Box_7270plus: module license 'unspecified' taints kernel.
Disabling lock debugging due to kernel taint
__io_remap_setwriteprotect: info: no pte for addr 97ae0000
AVM_WATCHDOG: System Init UEberwachung 480 Sekunden
__io_remap_setwriteprotect: info: no pte for addr 97ad8000
rtc-avm rtc-avm.0: rtc core: registered avm as rtc0
[avm-rtc]: avm_rtc_probe: register: ret=0x97969200
[avm-rtc]: avm_rtc_probe: success
[avm_debug]standard kernel-messages
__io_remap_setwriteprotect: info: no pte for addr 97b00000
[piglet]use settings for 144(6 gpios from hw_config)
patch_dectfw: c025a000, totallen = 70210(11242)
patch_dectfw: patch_adress: f1038 max_len: 26 with Version 2 Len: 17
patch_dectfw: dectmode 2
dect_loader: fast-bootmode
dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_488.hex' successfull
[piglet]bitfile '/lib/modules/bitfile.bit'
[piglet] clock from pll3(384000000)
[piglet] bitfile 72743 bytes done
[piglet]TDM: FS: 8000 Hz CLK:2047990 Hz
__io_remap_setwriteprotect: info: no pte for addr 97b80000
JFFS2 version 2.2 (NAND) (ZLIB) (RTIME) (c) 2001-2006 Red Hat, Inc.
__io_remap_setwriteprotect: info: no pte for addr 97b70000
loop: module loaded
[4294938623][0]system-load 7 25 tasks:19 % curr:usbcfgctl(0 %) max:init(12 %, pid:1), readytorun: 1, pgfault 1549/s (max 1 avg 1.0)
[pcmlink]svn: 1552
driver params overwritten io_addr=0x0 irq_num=0
[pcmlink]chrony-support
[pcmlink]c55: simple checksum: 62D8F7
capicodec_init()
[capi_codec] support fax
[capi_codec] support Codecs
__io_remap_setwriteprotect: info: no pte for addr 94900000
dect_uicp_from_dect, ignore 8 bytes, dect_manager not up: %B
dect_uicp_from_dect, ignore 16 bytes, dect_manager not up: %B
fat: exports duplicate symbol fat_add_entries (owned by kernel)
__io_remap_setwriteprotect: info: no pte for addr 96c18000
ramzswap: /dev/ramzswap0 initialized: disksize_kb=8192
Adding 8184k swap on /dev/ramzswap0. Priority:-1 extents:1 across:8184k SS
[4294939627][0]system-load 9 87 tasks:16 % curr:configd(0 %) max:rc.S(1 %, pid:24), readytorun: 21, pgfault 3636/s (max 1 avg 1.0)
__io_remap_setwriteprotect: info: no pte for addr 96fc0000
[dsl_ur8] DDC_cpsarChOpen done:0: Ch=15, Dir=TX
[dsl_ur8] DDC_cpsarChOpen done:0: Ch=15, Dir=RX
[dsl_ur8] driver version: 3.02.02.00
[dsl_ur8] before enabling Saras Digital Control: ADSLSS_PRCR(0xA1000500)=0x00000000!
[dsl_ur8] after enabling Saras Digital Control: ADSLSS_PRCR(0xA1000500)=0x000007FF!
[dsl_ur8] datapump path (/lib/modules/dsp_ur8/ur8-B-dsl.bin)
[dsl_ur8] DSP binary filesize = 440878 bytes
[dsl_ur8] shim_osLoadFWImage: Completed
[dsl_ur8] DSP image page address: (96500000)
[dsl_ur8] PM2EMIF=06500000 DM2EMIF=06500000 at DSLSS Start Time. PM2EMIF changes when DSL DP runs
[dsl_ur8] dslhal_support_hostDspCodeDownload: Done. Datapump version: 01.52.53.11
[dsl_ur8] dsl serial number successfully set to "465249545a21426f78466f6e574c414e37323430093030314633464441444444"
[dsl_ur8] AVM Fw Version successfully set into EOC Stuct 73.05.23
[dsl_ur8] DDC_dsl_init: Done
[dsl_ur8] DDC_atm_init: Done priv = 96c01400
[dsl_ur8] DDA_atm_irq_request: SAR Interrupt registered
[dsl_ur8] AVM Datapump
[dsl_ur8] DDA_atm_irq_request: DSL Interrupt registered
[dsl_ur8] Powermanagment (States => 1,10) supported!
[dsl_ur8] Loading Linux DSL Driver done
[4294940647][0]system-load 100 % 36 tasks:31 % curr:busybox(29 %) max:busybox(29 %, pid:622), readytorun: 7, pgfault 1199/s (max 1 avg 1.0)
kdsldmod: init start (Jul 6 2012 13:32:16) sizeof(struct sk_buff)=440
kdsldmod: init done
[dsl_ur8] ioctl set inventory invoked
[dsl_ur8] dsl serial number successfully set to "303031463346444144444442204621426f78373234302037332e30352e323300"
eth: port 0 status 2 throttle 0
eth: port 1 status 1 throttle 1
[cpmac] [adm_power_config] tried to set a mode 1 that is not possible for this port 1.
[avm_power] : ethernet switch failed
eth: port 2 status 1 throttle 1
[cpmac] [adm_power_config] tried to set a mode 1 that is not possible for this port 2.
eth: port 3 status 1 throttle 1
[cpmac] [adm_power_config] tried to set a mode 1 that is not possible for this port 3.
ADDRCONF(NETDEV_UP): cpmac0: link is not ready
ADDRCONF(NETDEV_UP): lan: link is not ready
ADDRCONF(NETDEV_UP): eth0: link is not ready
device eth0 entered promiscuous mode
device cpmac0 entered promiscuous mode
ADDRCONF(NETDEV_UP): guest: link is not ready
avm_pa: disabled
[dsl_ur8] hwrev=144 is_ATA_Ld_Hw=0
[dsl_ur8] from ATA to DSL Mode
[dsl_ur8] DSP in QUIET Mode. State Machine is being restarted
[dsl_ur8] SARAS PWDREG = 0x0000
avm_pa: disabled
[4294941649][0]system-load 100 % 45 tasks:47 % curr:wlancfgctl(0 %) max:ctlmgr(31 %, pid:712), readytorun: 1, pgfault 3554/s (max 2 avg 1.0)
ADDRCONF(NETDEV_CHANGE): cpmac0: link becomes ready
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
lan: port 1(eth0) entering forwarding state
__io_remap_setwriteprotect: info: no pte for addr 96e40000
[wlan_eeprom] calibration data blocks found = 1
[wlan_eeprom] Got calibration data version 2 for instance #1
[wlan_eeprom] Loading "/lib/modules/wlan_eeprom_hw0.bin"
[wlan_eeprom] Patching calibration data into eeprom
[wlan_eeprom] Patching MAC address to 00:1f:3f:d0:92:eb
[wlan_eeprom] Customer data="7240_V7B13_Dualband_CTL"
wlanfw: Init.
avm_wlan_memory: Init.
ath_hal: 0.9.14.25 (AR5416, REGOPS_FUNC)
__io_remap_setwriteprotect: info: no pte for addr 96740000
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
__io_remap_setwriteprotect: info: no pte for addr 96780000
wlan: 0.8.4.2 (Atheros/multi-bss)
Registered for AVM event source.
__io_remap_setwriteprotect: info: no pte for addr 96770000
ath_rate_atheros: Version 2.0.1
Copyright (c) 2001-2004 Atheros Communications, Inc, All Rights Reserved
__io_remap_setwriteprotect: info: no pte for addr 967c0000
ath_spectral: Version 2.0.0
__io_remap_setwriteprotect: info: no pte for addr 95800000
ath_pci: 0.9.4.5 (Atheros/multi-bss)
ath_pci: CR-LSDK-1.3.1.146
cache line size: 16
Chan Freq RegPwr HT CTL CTL_U CTL_L DFS
1 2412n 20 HT20 1 0 1 N
2 2417n 20 HT20 1 0 1 N
3 2422n 20 HT40 1 0 1 N
4 2427n 20 HT40 1 0 1 N
5 2432n 20 HT40 1 1 1 N
6 2437n 20 HT40 1 1 1 N
7 2442n 20 HT40 1 1 1 N
8 2447n 20 HT40 1 1 1 N
9 2452n 20 HT40 1 1 1 N
10 2457n 20 HT40 1 1 0 N
11 2462n 20 HT40 1 1 0 N
12 2467n 20 HT20 1 1 0 N
13 2472n 20 HT20 1 1 0 N
36 5180n 30 HT20 1 0 1 N
38 5190n 20 HT40 1 0 0 N
40 5200n 30 HT20 1 1 0 N
44 5220n 30 HT20 1 0 1 N
46 5230n 20 HT40 1 0 0 N
48 5240n 30 HT20 1 1 0 N
52 5260n 20 HT20 1 0 1 Y
54 5270n 20 HT40 1 0 0 Y
56 5280n 20 HT20 1 1 0 Y
60 5300n 20 HT20 1 0 1 Y
62 5310n 20 HT40 1 0 0 Y
64 5320n 20 HT20 1 1 0 Y
100 5500n 27 HT20 1 0 1 Y
102 5510n 27 HT40 1 0 0 Y
104 5520n 27 HT20 1 1 0 Y
108 5540n 27 HT20 1 0 1 Y
110 5550n 27 HT40 1 0 0 Y
112 5560n 27 HT20 1 1 0 Y
116 5580n 27 HT20 1 0 1 Y
118 5590n 27 HT40 1 0 0 Y
120 5600n 27 HT20 1 1 0 Y
124 5620n 27 HT20 1 0 1 Y
126 5630n 27 HT40 1 0 0 Y
128 5640n 27 HT20 1 1 0 Y
132 5660n 27 HT20 1 0 1 Y
134 5670n 27 HT40 1 0 0 Y
136 5680n 27 HT20 1 1 0 Y
140 5700n 27 HT20 1 0 0 Y
get_wlan_memory: (Rx) dd->dd_desc: b7fd4000, dd->dd_desc_paddr: 17fd4000, dd->dd_desc_len: 9510, *bf: 97fde000
get_wlan_memory: (Tx) dd->dd_desc: b7f90000, dd->dd_desc_paddr: 17f90000, dd->dd_desc_len: 246c0, *bf: 97fb5000
ath_descdma_setup: beacon DMA map: b6e1e000 (1152) -> physical 16e1e000 (1152)
dfs_init_radar_filters: dfs->dfs_rinfo.rn_numradars: 0
DFS min filter rssiThresh = 21
DFS max pulse dur = 131 ticks
ic_chainmask=3x3
wifi0: 11na rates: 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
wifi0: 11na MCS: 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
wifi0: 11ng rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
wifi0: 11ng MCS: 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
wifi0: mac 128.2 phy 13.0 radio 12.0
wifi0: Use hw queue 1 for WME_AC_BE traffic
wifi0: Use hw queue 0 for WME_AC_BK traffic
wifi0: Use hw queue 2 for WME_AC_VI traffic
wifi0: Use hw queue 3 for WME_AC_VO traffic
wifi0: Use hw queue 8 for CAB traffic
wifi0: Use hw queue 9 for beacons
wifi0: Use hw queue 7 for UAPSD
avm_net_trace: New net trace device 'HW (2.4 + 5 GHz, wifi0)' registered with minor 128.
wifi0: Atheros 9280: mem=0x40000000, irq=80 hw_base=0xc1d80000
__io_remap_setwriteprotect: info: no pte for addr 967e0000
__io_remap_setwriteprotect: info: no pte for addr 96618000
wlan: mac acl policy registered
__io_remap_setwriteprotect: info: no pte for addr 96e08000
avm_net_trace: New net trace device 'AP (2.4 + 5 GHz, ath0)' registered with minor 130.
avm_net_trace: New net trace device 'AP (2.4 + 5 GHz, ath0)' registered with minor 131.
[4294942655][0]system-load 100 % 45 tasks:7 % curr:iwpriv(0 %) max:rc.wlan(3 %, pid:762), readytorun: 1, pgfault 6127/s (max 2 avg 1.0)
Noise floor calibration not compleated (-50)
device ath0 entered promiscuous mode
lan: port 2(ath0) entering forwarding state
[4294943656][0]system-load 100 % 58 tasks:34 % curr:wlancfgctl(0 %) max:hostapd(6 %, pid:1445), readytorun: 1, pgfault 3863/s (max 3 avg 1.0)
AVM_WATCHDOG: System Init UEberwachung abgeschlossen (413760 ms noch verfuegbar)
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=3000 NormP=3000 mW -> SumNormP=3000 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=974 NormP=974 mW -> SumNormP=3974 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=100 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=4247 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=200 act_rate=0 mul=141 div=10 offset=100 NormP=2920 mW -> SumNormP=7167 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=7267 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=7367 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=100 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=8307 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=0 mul=55 div=10 offset=0 NormP=2750 mW -> SumNormP=11057 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=200 div=78 offset=150 NormP=406 mW -> SumNormP=11463 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=80 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=12963 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=467 act_rate=16777433 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=13480 mW
SysRq : Changing Loglevel
Loglevel set to 4
[4294944657][0]system-load 100 % 62 tasks:6 % curr:busybox(0 %) max:ctlmgr(1 %, pid:712), readytorun: 2, pgfault 6823/s (max 2 avg 1.0)
[4294945659][0]system-load 100 % 68 tasks:4 % curr:busybox(0 %) max:menu-update(1 %, pid:2320), readytorun: 2, pgfault 3009/s (max 1 avg 1.0)
[4294956204][0]system-load 1 56 tasks:1 % curr:luacgi(0 %) max:ctlmgr(0 %, pid:712), readytorun: 2, pgfault 94/s (max 2 avg 1.0)
[4294957238][0]system-load 6 56 tasks:26 % curr:luacgi(7 %) max:ctlmgr(14 %, pid:712), readytorun: 2, pgfault 453/s (max 1 avg 1.0)
[dsl_ur8] params 0x00000000
[dsl_ur8] ioctl retrain the modem
[4294959021][0]system-load 2 56 tasks:15 % curr:luacgi(7 %) max:luacgi(7 %, pid:2486), readytorun: 2, pgfault 127/s (max 1 avg 1.0)
[4294960330][0]system-load 2 56 tasks:12 % curr:luacgi(5 %) max:luacgi(5 %, pid:2488), readytorun: 2, pgfault 148/s (max 1 avg 1.0)
[4294961392][0]system-load 4 60 tasks:9 % curr:wlancfgctl(0 %) max:ctlmgr(5 %, pid:712), readytorun: 1, pgfault 2116/s (max 1 avg 1.0)
[4294962395][0]system-load 100 % 60 tasks:23 % curr:rc.wlan(0 %) max:luacgi(10 %, pid:3041), readytorun: 2, pgfault 7210/s (max 1 avg 1.0)
lan: port 2(ath0) entering disabled state
[4294965548][0]system-load 8 61 tasks:11 % curr:version(0 %) max:ctlmgr(8 %, pid:712), readytorun: 2, pgfault 869/s (max 1 avg 1.0)
/proc/tffs: info request: success
[365][0]system-load 1 60 tasks:4 % curr:version(0 %) max:ctlmgr(2 %, pid:712), readytorun: 2, pgfault 1299/s (max 1 avg 1.0)
[1458][0]system-load 2 57 tasks:13 % curr:dropbear(9 %) max:dropbear(9 %, pid:3827), readytorun: 1, pgfault 2727/s (max 1 avg 1.0)
root@fritz:/var/mod/root# lsmod
Module Size Used by Tainted: P
wlan_scan_ap 7537 1
wlan_acl 3184 1
wlan_wep 4375 0
wlan_tkip 9408 1
wlan_ccmp 6137 0
wlan_xauth 601 0
ath_pci 149400 0
ath_spectral 93193 1 ath_pci
ath_rate_atheros 59649 1 ath_pci
wlan 220606 9 wlan_scan_ap,wlan_acl,wlan_wep,wlan_tkip,wlan_ccmp,wlan_xauth,ath_pci,ath_rate_atheros
ath_dfs 40072 3 wlan_scan_ap,ath_pci,wlan
ath_hal 299091 5 ath_pci,ath_spectral,ath_rate_atheros,ath_dfs
avm_ath_extensions 41416 6 wlan_scan_ap,ath_pci,ath_rate_atheros,wlan,ath_dfs,ath_hal
kdsldmod 1089235 4
dsl_ur8 191113 0
ramzswap 18434 1
lzo_compress 1898 1 ramzswap
lzo_decompress 2031 1 ramzswap
dect_io 11547 0
avm_dect 239585 1 dect_io
capi_codec 417508 0
isdn_fbox_fon5 792793 5
pcmlink 383288 3 avm_dect,capi_codec,isdn_fbox_fon5
loop 13767 2
jffs2 107686 1
Piglet_noemif 48115 0
rtc_avm 5237 1 pcmlink
rtc_core 15336 1 rtc_avm
led_modul_Fritz_Box_7270plus 73611 2
root@fritz:/var/mod/root# ps
PID USER VSZ STAT COMMAND
1 root 1080 S init
2 root 0 SW [kthreadd]
3 root 0 SW [ksoftirqd/0]
4 root 0 SW [events/0]
5 root 0 SW [khelper]
6 root 0 SW [async/mgr]
7 root 0 SW [CPMAC workqueue]
8 root 0 SW [sync_supers]
9 root 0 SW [bdi-default]
10 root 0 SW [kblockd/0]
11 root 0 SW [khubd]
12 root 0 SW [rpciod/0]
13 root 0 SW [kswapd0]
14 root 0 SW [aio/0]
15 root 0 SW [nfsiod]
20 root 0 SW [pm_info]
21 root 0 SWN [avmdebug]
22 root 0 SW [mtdblockd]
23 root 0 SW [tffsd_mtd_0]
83 root 0 SW [cleanup_timer_f]
193 root 0 SWN [jffs2_gcd_mtd5]
213 root 0 SW< [loop0]
220 root 0 SW [capi_oslib]
221 root 0 SW [capi_oslib/0]
223 root 0 SW [capitransp]
226 root 0 SW< [avm_dect_thread]
227 root 0 SW [ksock tcp worke]
228 root 0 SW [ksock tcp serve]
434 root 1020 S < /sbin/udevd --daemon
523 root 1020 S < /sbin/udevd --daemon
603 root 2336 S /bin/configd
704 root 0 SWN [dectuart_route]
712 root 11068 S /usr/bin/avm/ctlmgr
735 root 4592 S multid -U -d
782 root 11068 S /usr/bin/avm/ctlmgr
783 root 11068 S /usr/bin/avm/ctlmgr
784 root 11068 S /usr/bin/avm/ctlmgr
835 root 4592 S multid -U -d
1287 root 1020 S < /sbin/udevd --daemon
1492 root 4408 S dsld -g -i -n
1498 root 3712 S pbd
1500 root 3712 S pbd
1501 root 3712 S pbd
1502 root 3712 S pbd
1503 root 3712 S pbd
1508 root 5008 S telefon a127.0.0.1
1510 root 5008 S telefon a127.0.0.1
1511 root 5008 S telefon a127.0.0.1
1518 root 4928 S < voipd
2028 root 828 S /bin/run_clock -c /dev/tffs -d
2259 root 1072 S {busybox} inetd
2474 root 1080 S init
3243 root 3028 S hostapd -B /var/tmp/wlan_ath0_topology
3492 root 1072 S {busybox} httpd-webcfg -P /var/run/webcfg.pid -p 81 -c /mod/etc/webcfg.conf -h /usr/mww/ -r Freetz
3719 root 1140 S dropbear -p 22 -R
3827 root 1208 S dropbear -p 22 -R
3834 root 1088 S -sh
3943 root 1076 R {busybox} ps
