bin/curl --max-time 30 -o tmp_kabel.htm -d mCmInfoDsFreq1=594000000&mCmInfoUsId1=2 http://192.168.100.1/goform/InitialScan
Reconnect (old IP: xxx.xxx.xxx.xxx)
% This is the RIPE Whois query server #1.
% The objects are in RPSL format.
% The RIPE Database is subject to Terms and Conditions.
% See http://www.ripe.net/db/support/db-terms-conditions.pdf
% Note: This output has been filtered.
% To receive output for a database update, use the "-B" flag.
% Information related to '217.114.220.0 - 217.114.220.63'
inetnum: 217.114.220.0 - 217.114.220.63
netname: DE-KEYWEB-XTRAMEDIA
descr: xtra-media.de IP Network
country: DE
admin-c: ES3819-RIPE
tech-c: ES3819-RIPE
status: ASSIGNED PA
mnt-by: KEYWEB-MNT
source: RIPE # Filtered
person: Enrico Saewert
address: xtra-media
address: Saalfelder Str. 74
address: 07381 Poessneck
address: Germany
e-mail: [email protected]
phone: +49 3647 505986
mnt-by: KEYWEB-MNT
nic-hdl: ES3819-RIPE
DNS Lookup For 217.114.220.33
;; Answer received from 127.0.0.1 (158 bytes)
;; HEADER SECTION
;; id = 25177
;; qr = 1 opcode = QUERY aa = 0 tc = 0 rd = 1
;; ra = 1 ad = 0 cd = 0 rcode = NOERROR
;; qdcount = 1 ancount = 1 nscount = 2 arcount = 2
;; QUESTION SECTION (1 record)
;; 33.220.114.217.in-addr.arpa. IN PTR
;; ANSWER SECTION (1 record)
33.220.114.217.in-addr.arpa. 86400 IN PTR www33.cyberghostvpn.com.
;; AUTHORITY SECTION (2 records)
220.114.217.in-addr.arpa. 86400 IN NS ns.keyweb.de.
220.114.217.in-addr.arpa. 86400 IN NS ns2.keyweb.de.
;; ADDITIONAL SECTION (2 records)
ns2.keyweb.de. 81692 IN A 62.141.49.15
ns.keyweb.de. 35612 IN A 95.169.160.9
if [ -n "$(echo -n "$h_type" | sed -e 's/.*\(octet-stream\|application\|mp4\).*//')" ];then
filename="video.mp4"
... das einzige was ich nicht von dir Runtergeladen habe ist von blusha Beitrag #2264 ....
hilfe? lädst du websiteninhalte mit fritz!load runter?![]()
Hi Bitronik, der Link war direkt aus unseren Quellsourcen. Sprich ist das selbe Coding wie jetzt in der neuen Version 0.15.hier ist der Beitrag von SagHalt
Habe auf meiner Fritzbox 7240 Version 0.15 per Firmwareupdate eingespielt. Habe kein Telefon zur Hand, um Telnet zu aktivieren.
Ich komme nicht auf die GUI (habe mich an die Readme im Paket gehalten -> das Verzeichnis "apache" liegt auf der angeschlossenen, externen Festplatte)
Hi nein es wurde laut RS irgend was über VPN gemacht ich habe heute NICHTS mit FritzLoad als PremUser geladen und es wurden schon wieder 14 neue Accounts erstellt die ich auch wieder bekommen habe jetzt habe ich aber heute mit einem Tool mein RS Account aufgeräumt als PremUser habe jetzt mal den Autor angeschrieben was er dazu sagt mein System wurde Intensiv mit Kaspersky Internet Security 2009 gescannt und es wurde nichts gefunden und Hijackthis sagt auch alles im grünen Bereich. Sorry für .,- von daher muss ich sagen das es NICHT an fritzload gelegen haben kann noch mal Sorry an die Coder@Bitronik: Ist es bei dir vielleicht so eingestellt, dass wenn kein Traffic mehr vorhanden ist, er RapidPoints in Traffic umwandeln soll? Würde zumindest erklären warum trotz Sicherheitsschloss die Punkte verschwanden.
MfG SpeziAlex
