Fritz!Box Fon WLAN 7050 1&1 to Annex A ?
@KlausBock
Yes you can call me on my voxalot number, will be glad to hear you, it is running on my laptop :)
@KunterBunter
If I only use au.voxalot.com and not au.voxalot.com:2060 in registrar and proxy in softphone (I use Counterpath Bria) it won't connect. So port 5060 is for sure blocked.
@KlausBock
It gives the following message:
Connecting to au.voxalot.com...Could not open connection to the host, on port 5060: Connect failed
@funxlab,
thanks for the short connection ;) Now I know that this VoIP provider also work with my Box (with 7270 FW) :)
The output of the telnet seems, that port 5060 is really blocked, but I don't know if any provider allows connections to alternative ports :noidea:
So, it's late here and I'll need to sleep, tomorrow the work is waiting ....
Wish you a good night !
BR
KlausBock
KlausBock, sipsorcery supports 2060/ 5080/8060 and voxalot supports 2060/3060/4060/80. I have accounts with both.
You sleep well, its midnight here, I think I should sleep too for work at 8.
Good Night. :)
I tryed a update with howto from here and i got this WinError. Then i was waiting a minute, but nothing is hapened. I drew the cable with the 12V and after 10 seconds i did it in the hole again. And now the box is dead. No LEDs are lighting and nothing happens (no answers to ping). Is it the famous dead of adam2? How can i make the box alive?
Hi! I have the same problem: I'd like to change from Annex B to Annex A, I read this topic but I don't really understand what should I do. Could someone give me a link please from the first step in english what should I do? I have the firmware version 14.04.31. Thanks a lot.
