Fritz!Box 7270v3 Firmware Version 74.04.76 final online vom 25.06.2009
HWR 145 = FB Fon WLAN 7270 plus = die 7270v3
Das sind die mir bekannten HWrevisionsnummern:
This Hardware revision is used for Plugindownload.
HWR 58 = FB Fon
HWR 60 = FB WLAN
HWR 61 = FB Fon WLAN
HWR 62 = FB AnnexA
HWR 63 = FB SL AnnexA
HWR 64 = FB Fon AnnexA
HWR 65 = FB WLAN AnnexA
HWR 66 = FB Fon WLAN AnnexA
HWR 71 = FB Fon ata
HWR 72 = FB Fon 5050
HWR 73 = FB Fon 5050 AnnexA
HWR 76 = FB Fon WLAN 7050
HWR 77 = FB Fon WLAN 7050 AnnexA
HWR 78 = Eumex 300 IP
HWR 79 = FB WLAN 3070
HWR 82 = FB WLAN 3050
HWR 83 = FB 2030
HWR 84 = FB 2070
HWR 85 = FB WLAN 3030
HWR 86 = FB Fon 5010
HWR 87 = FB Fon CTP (*)
HWR 88 = FB Radio (*)
HWR 89 = FB Fon 5012
HWR 91 = Sinus W300V
HWR 93 = Speedport W501V
HWR 94 = FB Fon WLAN 7170
HWR 95 = FB Fon WLAN 7140
HWR 96 = FB Fon WLAN 7130
HWR 97 = Sinus W500V
HWR 101 = Speedport W701V
HWR 102 = Speedport W900V
HWR 104 = FB VOIP Gateway 5188
HWR 105 = FB Fon WLAN 7540V
HWR 106 = Fritz!Fon 7150
HWR 107 = FB Fon WLAN 7140 AnnexA
HWR 108 = FB Fon WLAN 7141
HWR 109 = FB Fon WLAN 7170SL
HWR 110 = FB Fon 5120
HWR 111 = FB Fon 5140
HWR 112 = FB WLAN 3131
HWR 113 = FB 2031
HWR 114 = FB Fon 5122 (*)
HWR 115 = FB Fon WLAN 7122 (*)
HWR 116 = FB Fon 5010 AnnexA
HWR 117 = FB WLAN 3170
HWR 118 = FB WLAN 3131
HWR 119 = FB 2170
HWR 120 = Speedport W702V
HWR 121 = Speedport W900V
HWR 122 = FB Fon WLAN 7270 (8 MB)
HWR 123 = Fritz!Media 8020
HWR 124 = Fritz!Media 8040
HWR 125 = FB Fon 5124
HWR 126 = FB Fon 5124 AnnexA
HWR 127 = FB Fon WLAN 7170 AnnexA
HWR 128 = Fritz!Fon 7150 AnnexA
HWR 129 = FB Fon WLAN 7113
HWR 130 = FB 2121
HWR 131 = FB Fon 5130
HWR 133 = FB 2110
HWR 134 = Speedport W721V
HWR 135 = Speedport W920V
HWR 136 = Speedport W503V
HWR 137 = FB WLAN 3270
HWR 138 = FRITZ! WLAN Repeater N/G
HWR 139 = FB Fon WLAN 7270 (16 MB)
HWR 140 = FB Fon 5125 AnnexA
HWR 141 = FB Fon WLAN 7270 AnnexA
HWR 142 = Speedport W721VK
HWR 143 = Speedport W101 Bridge
HWR 144 = FB Fon WLAN 7240
HWR 146 = FB Fon WLAN 7570 vDSL
HWR 147 = DSL-EasyBox A802-R
HWR 148 = DSL-EasyBox A602
HWR 149 = DSL-EasyBox A402
HWR 152 = Speedport W722V
HWR 159 = FB Fon WLAN 7112
Wie bereits gesagt:
Die 54er Reihe unterstützt zwei HwRevisionen der 7270.
Die 74er Reihe nur eine.
Schaut man sich die 7240 an, die ja nur um die ISDN-Funktion+Ip-Telefonie "ärmer" ist,
landen wir dann bei 9,8 MB .
Da die 7270v3 platinenmäßig der 7240 ähnlich scheint, sollte darin die Erklärung liegen.
Ich würde da nicht all zu sehr weitersuchen, die Firmware der v3 ist um einiges vollständiger, plugins werden nicht verwendet alles ist bereits in der Firmware was ansonsten mit plugins nachgladen wird.
Ein kdiff3 vergleich der beiden Firmwares zeigt, dass die meisten Files total gleich sind.
Kannst du übrigns auch selber machen mit speed-to-fritz.
Bei den Optionen kdiff3 anklicken und beim Harware Type Any AVM Custom Modell --> 7270
Mehr ist nicht auszuwählen da die beiden Firmwares voreingestellt sind.
Siehe auch:
http://www.ip-phone-forum.de/showpost.php?p=1354460&postcount=52
Guter Hinweis - Danke!
Fehlt mir aber leider die Zeit für -Unistress.
Die Plugin-Variante ist allerdings die beste Erklärung - passt auch zu den voluminösen Labor-Firmwares im Vergleich zu den Release-Versionen.
Hat schon jemand die v3 bezüglich DECT getestet ? Insbesonderen das zusammenspiel mit MT-D.
Servus
Servus
geht ohne Probleme!
Das einzige Problem was ich momentan noch habe ist der Fax-Empfang...
Das will irgendwie nicht so recht. Für ein und die selbe Festnetznummer sind 3 Sachen geschaltet: AB nach 20 sek, normales Festnetz und Fax mit Faxerkennung. Leider erkennt es irgendwie ankommende Fax-Signale nicht :(
Achja und FritzVox will mit der 7270v3 bei mir auch nicht laufen aber ich lass mir die Texte nun immer per Mail schicken als wave-file...
ok, "optimiertes" Hardware-Layout aber was bringts genau für den Kunden? Bessere WLAN Reichweite? Weniger Energieaufnahme? Also welchen Vorteil hat eine v2 zu v3?
Aktuell sieht es so aus, als ob beide Versionen vergleichbar sind.
AVM hatte die v3 wohl schon lange geplant, weil die zugehörige HWRevision-Nr. 145 (mit Bezeichnung FBF7270 !) gibt es schon seit ca. 1 Jahr.
Ich hatte immer gerätselt, für welche Variante der 7270 die HWR 145 gedacht ist.
Erst dachte ich an den Wechsel von 8MB auf 16MB Flash, aber das war von 122 auf 139.
Dann dachte ich, es sei die MultiLanguage mit AnnexA/B, aber da blieb HWR auf 139.
Erst jetzt wurde die Zuordnung der HWR 145 klar: es ist die FB 7270v3
Funktionell scheinen sich 7270v2 und 7270v3 nicht voneinander zu unterscheiden.
Ein möglicher Vorteil der FB 7270v3: Sie ist neuer als die FB 7270v2.
Könnte sein, dass AVM bei zukünfigen updates vermehrt auf die v3 setzt, aber garantieren kann ich das nicht.
Ich denke das die v2 in der Produktion einfach ausläuft.
Kostengründe sind es kaum eher schon die Verfügbarkeit der altern Chips wird halt nicht mehr gegeben sein. Wenn die neuen Chips auch noch günstiger sind dann sollte AVM das an den Markt weitergeben der Konsument wird sich freuen.
Ob nun Labor firmwares in Zukunft auch für die v3 angeboten werden wird sich zeigen, ich vermute dass eine gewisse Zeit zumindest sowohl für v2 und v3 Laborfirmware angeboten wird.
Abkehr von den plugins, war wohl doch nicht die beste Lösung zumindest nicht für multilingual Firmware.
Für den Verbraucher könnten Verbesserungen bezüglich LAN Ports und DECT absehbar sein, derzeit ist da aber kaum ein Unterschied.
Und da es derzeit keine LABOR Firmware für den v3 gibt müßte man per Skript die die LABOR Firmware für den v3 anpassen. HAbe ich aber nicht im Sinn da ich doch erwarte, dass AVM bald LABOR Firmwares für den v3 rausbringt.
Upgrade from FRITZ.Box_Fon_WLAN_7270.Labor.54.04.99-14000.image to FRITZ.Box_Fon_WLAN_7270.54.04.76.image problem.
I try
1) make export from older version (with and without pass)
2) upgrade firmware (flash) to latest (posible only with resetting password
3) edit saved export and change string to FirmwareVersion=54.04.76
4) fix chksum in FBEditor 0.5.1
5) load "fixed" export into
latest FRITZ.Box_Fon_WLAN_7270.54.04.76.image
but NOT WORK! If i try with export with password, i get different message than if i try import export without pass, see attach.
I must roll back to FRITZ.Box_Fon_WLAN_7270.Labor.54.04.99-14000.image (i not want set up all again :-(
Please tell me, where is problem? FBEditor 0.5.1 not calculate good checksum?
Thanx!
54.04.99 is considered "higher" than 04.76. So: must go back to 54.04.70 (recovery) - after that upgrade to 54.04.76 and import your data again - no other way
ich befinde mich jetzt hier im argen Zwiespalt. Ich habe von 1und1 eine 7270 v3 als Austauschgerät gesendet bekommen. Bei meiner 7270 v2 mit 16 MB Flash hatte das Netzteil gefipst. Nun wollte ich eigentlich nur ein neues Netzteil. Der Gute Mann aus der techn. Hotline bei 1und1 konnte mir aber nur eine komplett neue schicken. Ich solle einfach die alte eintüten und zurück senden. Es wäre kein Problem aufgrund eines defekten Netzteils die komplette 7270 zu tauschen meint er. Es würde mich auch nichts kosten, sofern in die alte Hardware innerhalb 30 Tagen zurück sende. Er meinte auch, ich könnte auch einfach "nur" das Netzteil tauschen, was ich nun gemacht habe. Das "Fipsen" ist jetzt weg. Einige meinten hier schon, dass durch das defekte Netzteil auch die FritzBox hätte beschädigt werden können. Was meint ihr dazu?
Sollte ich die V2 behalten oder doch eher die V3? Soweit ich das bisher lesen kann, ist keinem so richtig der Untschied der Boxen bekannt, freetz weis ich nicht ob wirklich mit NFS etc. was ich alles brauche läuft. Jetzt habe ich schon von Problemen mit Fritz-Fax in der Box gehört und bin mir daher noch mehr unsicher was ich machen soll.
Die Box habe ich nun 3 Tage und möchte so bald wie möglich eine Entscheidung treffen. Ist denn die V3 schneller als die V2? Hat die V3 auch 16 MB Speicher oder gibts da schon absehbare Nachteile?
Wäre für jede Beratung sehr dankbar.
Meinen Kenntnisstand findest Du [post=1355508]hier[/post]
Übrigens: Sowohl die v2 als auch die v3 haben 16MB Flash Speicher
Ich würd die v3 behalten.
Laut Aussage von AVM nimmt auch diese Serie künftig an den Laborversionen teil.
Leistungstechnisch scheint es bei der v3 Optimierungen im Bereich DECT gegeben zu haben - die sind nicht spürbar, gehen aber der Featurebezeichnung in den Supportdaten hervor.
Mit der 7270v3 solltest du also besser dran sein.
i not have export for 54.04.70 !! only for labor dsl 4.99
...... only for labor dsl 4.99
YOUR data are not bound to any specific firmware! To be short: you cannot upload 54.04.76 DIRECTLY on 04.99! This is the negative aspect of all so called dsl labor firmwares: they have higher version numbers than the finals and so you can't go back the simple way to a final. No other way than upload (or even recover) to 54.04.70 - only then you can upload 54.04.76 and register your PERSONAL data again - or you can export them first and after doing all the firmware uploads import them again!
Sorry, I can only say: take it or leave it! Believe and understand what I'm explaining - or don't do it and you will not solve your problem
Etwas mehr bezüglich Software Unterschiede.
Xilinx bitfile.bit unterscheidet sich und auch die entsprechenden Einträge in der rc.S
Das bereits erwähnte:
Keine Plugins
Media wird direkt gestartet per rc.S
Multiannex Multilingual im Ansatz, aber nur deutsche Datenbank eingepackt.
Ansonsten sind eindeutig keine weiteren Unterschiede in der Software
Es gibt derzeit keine LABOR Firmware für die v3 wird sich aber sicher ändern.
Ein patch für die Adaption von v2 Firmware ist möglich.
hstoff
