freetz auf 3270 Newbee
AHHHH
der config nach zu urteilen, kläd er das Image von der 7270 und ändert es auf die 3270 ab.
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_7270_04_67=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
# FREETZ_TYPE_FON_WLAN_7240 is not set
# FREETZ_TYPE_FON_WLAN_7270 is not set
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
FREETZ_TYPE_WLAN_3270=y
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_SPEEDPORT_W701V is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_AVM_VERSION_STRING="7270_04.67"
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_A_CH is not set
# FREETZ_TYPE_LANG_EN is not set
FREETZ_TYPE_LANG_STRING="de"
FREETZ_TYPE_STRING="3270"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
# FREETZ_REPLACE_KERNEL is not set
FREETZ_SHOW_ADVANCED=y
FREETZ_TARGET_REF="8mb_26"
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_KERNEL_MTD_SIZE=246
# FREETZ_HAS_PHONE is not set
FREETZ_HAS_WLAN=y
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_USB_HOST=y
# FREETZ_HAS_AVM_INETD is not set
# Mod ------------------------------------
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
# Patches
das kommt beim erstellen:
touch source/ref-8mb_26-7270_04.67/kernel/.depend_done
: command not found
: command not found
: command not found
: command not found
: command not found
: command not found
: command not found:
")syntax error: operand expected (error token is "
make: *** [dl/gcc-4.2.1-uclibc-0.9.29-freetz-0.6.tar.lzma] Fehler 1
slightly@StinkyLinux:~/freetz/freetz-stable$
Ab da ist dann mein Latein am Ende.
Sorry
