Firmware not found
That's sounds good.
Have fun with your new Image
Thanks.
The samba is verry good, i like it and the transmission is great too!
I will buy a WR703N router front of freetz because i need to use client mode (i can't use WDS, not supported on the base)
link
What do you think about this?
Merry Cristmas!
This looks like your usb device was removed. Sometimes this happens accidently without user interaction. Some users solved this problems by using another power supply or an active hub...
Regards
Oliver
Actually i used my pendrive after shut down the fritz, i copied some files and after blug in back in fritzbox and turn on, is it matter that the free space changed?
Input/Output-Error occurs if you unplug the device without stopping transmission and removing the device "safely".
But at the starting again i checked the files in transmission.
Is it possible that if i turn on the wlan connection on fritz (push the wlan button, or call #96*1*) and i use from laptop or use voip and after wne i am not use 10min the wlan automatically turn off?
Is it normal, that my freetz use the transmission and samba and when i downloading 5-600kb/s with transmission i cant read the transmission gui from web or from remote gui, but this pendrive can copy with 10mb/s, what is wrong, it's so slow, and at this time my fritzbox can't show anithing on webinterface.
I am using swapfile it's 120mb.
Check the output of "top" to find out what your box is actually doing.
Regards
Oliver
Hi!
I need a little help.
My modem is sometimes restarting and the fritzbox cant connect againt, i have to run the "Check Internet Connection" in web and it can fix it. How can i do it automacly checking the connection?
I found some information but i am not sure that is that solution to my problem. here is the site
Can you help me please?
soundworx
