First I want to thank everyone who helped making or supporting Freetz. Both you and Freetz are great
Now here's my problem:
I have a printer and an external laptop disk, attached to a powered USB hub, connected to my 7170 running Freetz stable 2.0 (I have my .config attached). The disk has two ext3 partitions and a swap file. For some time, this ran without any problems, but now all of a sudden the disk will almost never mount at boot. I have not changed anything to the configuration, I only deattached the disk, attaching it to another computer and reading some data from it, then reattaching to the router. I always unmounted before deattaching.
mod_mount.log gives:
Modules are not the problem: lsmod|grep ext gives
When I try cat /dev/sda and expect garbled output, it just hangs for a while and gives "cat: read error: Input/output error" or "cat: can't open '/dev/sda': No such device or address".
The whole setup (disk and printer) mounts fine on my desktop computer. When I'm in luck, the disk does mount, but sooner or later the router will spontaneously reboot.
Attaching the disk directly to the router while still powering it externally seems to work more often, but I also want to be able to use the printer.
Changing USB hubs did seem to help for a few weeks, then the problem returned.
Is this a hardware issue? Am I asking too much of this poor old router?
Thanks in advance!
[INFO] Mounting device /dev/sda ...
[FAIL] Partition fb_10 (/dev/sda): Unsupported filesystem or wrong partition table (unknown)
ext3 106880 2
jbd 44704 1 ext3
ext2 48832 0
mbcache 5424 2 ext3,ext2
Thanks in advance!
