12:29:30.755 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_CONNECT
12:29:30.755 capi_events.c (IND, CTRL 3, PLCI: 3843) - Called-Party: unknown, Calling-Party: anonymous, Acc-ID: 1, INCOMING
12:29:30.758 conference.c Port 2 (capi port [0]) transmitting to port 1 (null port)
12:29:30.758 conference.c Port 1 (null port) transmitting to port 2 (capi port [0])
12:29:30.759 voip_registrar Make VoIP call by client (<sip:[email protected]:5060> -> <sip:[email protected]:5060>)...
12:29:30.760 voip_funcs.c Initialize outgoing call from '<sip:[email protected]:5060>' to '<sip:[email protected]:5060>'
12:29:30.761 voip_funcs.c Create SDP...
12:29:30.763 voip_funcs.c Create invite session...
12:29:30.767 voip_events.c Call state changed to CALLING [port=1]
12:29:30.768 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0x0018) - CHANNEL IDENTIFICATION (0x03)
12:29:30.769 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0xc000) - UNKNOWN INFO
12:29:30.770 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0x800d) - SETUP ACK
12:29:30.771 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0x001e) - PROGRESS INDICATOR (0x02)
12:29:30.773 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0xc000) - UNKNOWN INFO
12:29:30.772 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:30.775 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:30.777 capi_ctrl.c (CNF, CTRL 3, PLCI: 3843) - CAPI_ALERT
12:29:30.778 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0x8001) - ALERTING
12:29:30.779 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0x001e) - PROGRESS INDICATOR (0x02)
12:29:30.780 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0xc000) - UNKNOWN INFO
12:29:30.792 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:30.797 script_funcs.c RUN SCRIPT: "/var/dtmfbox/script/userscript.sh" "CONNECT" "USER" "INCOMING" "1" "0" "unknown" "[email protected]:5060" "2" ""
12:29:30.814 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:30.832 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:30.852 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:30.869 plugins.c [plugin.menu] (#2): action > script:action_cbct
12:29:30.872 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:30.880 plugins.c [plugin.menu] (#2): script: /var/dtmfbox/script/action_cbct.sh(/var/dtmfbox/script/action_cbct.sh, "CONNECT", "USER", "INCOMING", "1", "0", "unknown", "[email protected]:5060", "2", "")
12:29:30.904 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:30.908 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:30.909 capi_events.c (IND, CTRL 5, PLCI: 4357) - CAPI_CONNECT
12:29:31.042 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.044 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.043 capi_events.c (IND, CTRL 5, PLCI: 4357) - Called-Party: unknown, Calling-Party: 3#49180524235135115, Acc-ID: 1, INCOMING
12:29:31.049 conference.c Port 3 (capi port [2]) transmitting to port 1 (null port)
12:29:31.050 conference.c Port 1 (null port) transmitting to port 3 (capi port [2])
12:29:31.051 voip_registrar Make VoIP call by client (<sip:3#[email protected]:5060> -> <sip:[email protected]:5060>)...
12:29:31.052 voip_funcs.c Initialize outgoing call from '<sip:3#[email protected]:5060>' to '<sip:[email protected]:5060>'
12:29:31.053 voip_funcs.c Create SDP...
12:29:31.054 voip_funcs.c Create invite session...
12:29:31.058 voip_events.c Call state changed to CALLING [port=3]
12:29:31.059 capi_events.c (IND, CTRL 5, PLCI: 4357) - CAPI_INFO (0x0018) - CHANNEL IDENTIFICATION (0x03)
12:29:31.060 capi_events.c (IND, CTRL 5, PLCI: 4357) - CAPI_INFO (0xc000) - UNKNOWN INFO
12:29:31.063 capi_ctrl.c (CNF, CTRL 5, PLCI: 4357) - CAPI_ALERT
12:29:31.072 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:30.933 plugins.c [plugin.menu] (#2): action > script:action_am
12:29:31.087 plugins.c [plugin.menu] (#2): script: /var/dtmfbox/script/action_am.sh(/var/dtmfbox/script/action_am.sh, "CONNECT", "USER", "INCOMING", "1", "0", "unknown", "[email protected]:5060", "2", "")
12:29:31.095 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.112 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.132 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.149 script_funcs.c RUN SCRIPT: "/var/dtmfbox/script/userscript.sh" "CONNECT" "CAPI" "INCOMING" "0" "1" "unknown" "anonymous" "2" ""
12:29:31.155 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.172 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.192 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.212 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.232 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.241 plugins.c [plugin.menu] (#2): action > script:action_cbct
12:29:31.252 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.255 plugins.c [plugin.menu] (#2): script: /var/dtmfbox/script/action_cbct.sh(/var/dtmfbox/script/action_cbct.sh, "CONNECT", "CAPI", "INCOMING", "0", "1", "unknown", "anonymous", "2", "")
12:29:31.275 scombdb-up Underflow, buf_cnt=0, will generate 1 frame
12:29:31.334 plugins.c [plugin.menu] (#2): action > script:action_am
12:29:31.370 plugins.c [plugin.menu] (#2): script: /var/dtmfbox/script/action_am.sh(/var/dtmfbox/script/action_am.sh, "CONNECT", "CAPI", "INCOMING", "0", "1", "unknown", "anonymous", "2", "")
12:29:31.439 funcs.c Set high priority
12:29:31.463 script_funcs.c RUN SCRIPT: "/var/dtmfbox/script/userscript.sh" "CONNECT" "USER" "INCOMING" "3" "2" "unknown" "[email protected]:5060" "2" ""
12:29:31.779 plugins.c [plugin.menu] (#2): action > script:action_cbct
12:29:31.788 plugins.c [plugin.menu] (#2): script: /var/dtmfbox/script/action_cbct.sh(/var/dtmfbox/script/action_cbct.sh, "CONNECT", "USER", "INCOMING", "3", "2", "unknown", "[email protected]:5060", "2", "")
12:29:31.938 plugins.c [plugin.menu] (#2): action > script:action_am
12:29:31.945 plugins.c [plugin.menu] (#2): script: /var/dtmfbox/script/action_am.sh(/var/dtmfbox/script/action_am.sh, "CONNECT", "USER", "INCOMING", "3", "2", "unknown", "[email protected]:5060", "2", "")
12:29:31.973 script_funcs.c RUN SCRIPT: "/var/dtmfbox/script/userscript.sh" "CONNECT" "CAPI" "INCOMING" "2" "3" "unknown" "3#49180524235135115" "2" ""
12:29:32.190 plugins.c [plugin.menu] (#2): action > script:action_cbct
12:29:32.199 plugins.c [plugin.menu] (#2): script: /var/dtmfbox/script/action_cbct.sh(/var/dtmfbox/script/action_cbct.sh, "CONNECT", "CAPI", "INCOMING", "2", "3", "unknown", "3#49180524235135115", "2", "")
12:29:32.438 voip_events.c Call EARLY [port=1, reason=0 (Default status message)]
12:29:32.484 voip_events.c Call DISCONNECTED [port=3, reason=486 (Busy Here)]
12:29:32.486 voip_registrar CAPI client disconnected [2]
12:29:32.487 voip_events.c Hangup [3]
12:29:32.489 voip_events.c Call EARLY [port=1, reason=0 (Default status message)]
12:29:32.491 voip_events.c Call EARLY [port=1, reason=0 (Default status message)]
12:29:32.498 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0x8003) - PROGRESS
12:29:32.500 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0xc000) - UNKNOWN INFO
12:29:32.512 capi_events.c (IND, CTRL 5, PLCI: 4357) - CAPI_DISCONNECT
12:29:32.513 capi_funcs.c CAPI 0x3490 - Normal call clearing
12:29:32.514 conference.c Port 3 (capi port [2]) stop transmitting to port 1 (null port)
12:29:32.514 conference.c Port 1 (null port) stop transmitting to port 3 (capi port [2])
12:29:32.591 plugins.c [plugin.menu] (#2): action > script:action_am
12:29:32.600 plugins.c [plugin.menu] (#2): script: /var/dtmfbox/script/action_am.sh(/var/dtmfbox/script/action_am.sh, "CONNECT", "CAPI", "INCOMING", "2", "3", "unknown", "3#49180524235135115", "2", "")
12:29:32.653 script_funcs.c RUN SCRIPT: "/var/dtmfbox/script/userscript.sh" "DISCONNECT" "USER" "INCOMING" "3" "-1" "unknown" "[email protected]:5060" "2" "486"
12:29:32.662 voip_events.c Call EARLY [port=1, reason=0 (Default status message)]
12:29:32.809 script_funcs.c RUN SCRIPT: "/var/dtmfbox/script/userscript.sh" "DISCONNECT" "CAPI" "INCOMING" "2" "-1" "unknown" "3#49180524235135115" "2" "13456"
12:29:33.665 voip_events.c Call EARLY [port=1, reason=0 (Default status message)]
12:29:35.672 voip_events.c Call EARLY [port=1, reason=0 (Default status message)]
12:29:35.774 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0x8045) - DISCONNECT
12:29:35.775 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0x0008) - CAUSE (0x00)
12:29:35.776 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_INFO (0xc000) - UNKNOWN INFO
12:29:35.836 capi_events.c (IND, CTRL 3, PLCI: 3843) - CAPI_DISCONNECT
12:29:35.839 voip_registrar VoIP client disconnected [1]
12:29:35.840 conference.c Port 2 (capi port [0]) stop transmitting to port 1 (null port)
12:29:35.841 conference.c Port 1 (null port) stop transmitting to port 2 (capi port [0])
12:29:35.852 script_funcs.c RUN SCRIPT: "/var/dtmfbox/script/userscript.sh" "DISCONNECT" "CAPI" "INCOMING" "0" "1" "unknown" "anonymous" "2" "0"
12:29:35.880 script_funcs.c RUN SCRIPT: "/var/dtmfbox/script/userscript.sh" "DISCONNECT" "USER" "INCOMING" "1" "-1" "unknown" "[email protected]:5060" "2" "0"
12:29:36.702 voip_events.c Call DISCONNECTED [port=1, reason=487 (Request Terminated)]
12:29:36.712 funcs.c Set low priority
