14:06:14.648 capi_events.c (IND, CTRL 3, PLCI: 771) - CAPI_CONNECT (Acc#: 720XXX(0), Target#: unknown)
14:06:14.650 conference.c Port 2 (capi port [0]) transmitting to port 1 (null port)
14:06:14.650 conference.c Port 1 (null port) transmitting to port 2 (capi port [0])
14:06:14.652 script_funcs.c RUN SCRIPT: "./script/script_main.sh" "CONNECT" "CAPI" "INCOMING" "0" "-1" "unknown" "720XXXX" "1" ""
14:06:14.828 funcs.c Set high priority 14:06:15.831 capi_events.c (IND, CTRL 3, PLCI: 771) - CAPI_INFO (0x0018) - CHA
NNEL IDENTIFICATION (0x03)
14:06:15.832 capi_events.c (IND, CTRL 3, PLCI: 771) - CAPI_INFO (0xc000) - UNKNOWN INFO
14:06:15.832 capi_ctrl.c (CNF, CTRL 3, PLCI: 771) - CAPI_ALERTtelefon: '/var/calllog' script not found!
telefon: '/var/flash/calllog' script not found!
14:06:19.926 script_funcs.c [0] (SCRIPT) - Queue: 0, Pending: 0
14:06:19.927 script_funcs.c [0] (SCRIPT) - change scriptfile to "/var/dtmfbox/tmp/callback_0.sh"
14:06:19.927 script_funcs.c [0] (SCRIPT) - change delimiter to ""
14:06:27.978 capi_events.c (IND, CTRL 3, PLCI: 771) - CAPI_DISCONNECT
14:06:27.979 capi_funcs.c CAPI 0x3490 - Normal call clearing
14:06:27.980 script_funcs.c RUN SCRIPT: "/var/dtmfbox/tmp/callback_0.sh" "DISCONNECT" "CAPI" "INCOMING" "0" "-1" "unknown" "720XXXX" "1" ""
14:06:28.292 conference.c Port 2 (capi port [0]) stop transmitting to port 1(null port)
14:06:28.293 conference.c Port 1 (null port) stop transmitting to port 2 (capi port [0])
14:06:28.305 funcs.c Set low priority
14:06:34.576 script_funcs.c [-1] (SCRIPT) - Queue: 1, Pending: 0
14:06:34.578 conference.c Port 2 (capi port [0]) transmitting to port 1 (null port)
14:06:34.579 conference.c Port 1 (null port) transmitting to port 2 (capi port [0])
14:06:34.581 capi_funcs.c (CTRL 3, SRC: voip, DST: 0049XXXX720XXXXX) - CONNECT_REQ
14:06:34.583 capi_ctrl.c (CNF, CTRL 3, PLCI: 1027) - CAPI_CONNECT
14:06:34.584 script_funcs.c RUN SCRIPT: "none" "CONNECT" "CAPI" "OUTGOING" "0""-1" "voip" "0049XXX720XXXX" "-1" ""
14:06:34.596 script_funcs.c [-1] (SCRIPT) - CALL - CAPI - voip -> 0049XXXX720XXXXX [3]
14:06:34.927 funcs.c Set high priority
14:06:34.939 capi_events.c (IND, CTRL 3, PLCI: 1027) - CAPI_INFO (0x800d) - SETUP ACK
14:06:34.940 capi_events.c (IND, CTRL 3, PLCI: 1027) - CAPI_INFO (0x001e) - PROGRESS INDICATOR (0x02)
14:06:34.941 capi_events.c (IND, CTRL 3, PLCI: 1027) - CAPI_INFO (0x0018) - CHANNEL IDENTIFICATION (0x03)
14:06:34.942 capi_events.c (IND, CTRL 3, PLCI: 1027) - CAPI_INFO (0xc000) - UNKNOWN INFO
14:06:35.775 script_funcs.c [0] (SCRIPT) - Queue: 2, Pending: 0
14:06:35.776 script_funcs.c [0] (SCRIPT) - wait for event (2)
head: ./tmp/0.waitevent-file: No such file or directory
14:06:37.986 script_funcs.c [0] (SCRIPT) - Queue: 3, Pending: 1
14:06:37.987 capi_funcs.c Send Display-Message: "Hauptmenue"
14:06:38.033 capi_ctrl.c (CNF, CTRL 3, PLCI: 1027) - CAPI_INFO
14:06:38.086 script_funcs.c [0] (SCRIPT) - Queue: 4, Pending: 0
14:06:38.087 script_funcs.c [0] (SCRIPT) - [play_id: -1] - playing stopped!
14:06:41.866 script_funcs.c [0] (SCRIPT) - Queue: 5, Pending: 0
14:06:43.314 script_funcs.c [0] (SCRIPT) - Queue: 6, Pending: 0
14:06:45.013 capi_events.c (IND, CTRL 3, PLCI: 1027) - CAPI_INFO (0x8001) - ALERTING
14:06:45.019 capi_events.c (IND, CTRL 3, PLCI: 1027) - CAPI_INFO (0x001e) - PROGRESS INDICATOR (0x02)
14:06:45.020 capi_events.c (IND, CTRL 3, PLCI: 1027) - CAPI_INFO (0x0070) - UNKNOWN INFO
14:06:45.188 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (0) (15)
14:06:45.189 capi_funcs.c [0] RECV DTMF: 0
14:06:45.190 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (0) (15)
14:06:45.190 capi_funcs.c [0] RECV DTMF: 0
14:06:45.191 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (4) (15)
14:06:45.191 capi_funcs.c [0] RECV DTMF: 4
14:06:45.192 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (9) (15)
14:06:45.192 capi_funcs.c [0] RECV DTMF: 9
14:06:45.193 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (3) (15)
14:06:45.193 capi_funcs.c [0] RECV DTMF: 3
14:06:45.194 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (0) (15)
14:06:45.196 capi_funcs.c [0] RECV DTMF: 0
14:06:45.197 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (7) (15)
14:06:45.197 capi_funcs.c [0] RECV DTMF: 7
14:06:45.198 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (2) (15)
14:06:45.198 capi_funcs.c [0] RECV DTMF: 2
14:06:45.199 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (0) (15)
14:06:45.200 capi_funcs.c [0] RECV DTMF: 0
14:06:45.200 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (1) (15)
14:06:45.201 capi_funcs.c [0] RECV DTMF: 1
14:06:45.201 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (1) (15)
14:06:45.202 capi_funcs.c [0] RECV DTMF: 1
14:06:45.202 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (9) (15)
14:06:45.203 capi_funcs.c [0] RECV DTMF: 9
14:06:45.203 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (7) (15)
14:06:45.204 capi_funcs.c [0] RECV DTMF: 7
14:06:45.208 capi_events.c (IND, CTRL 3, PLCI: 1027) - DIALED (8) (15)
14:06:45.208 capi_funcs.c [0] RECV DTMF: 8
14:06:45.210 capi_events.c (IND, CTRL 3, PLCI: 1027) - CAPI_INFO (0x0018) - CHANNEL IDENTIFICATION (0x03)
14:06:45.211 capi_events.c (IND, CTRL 3, PLCI: 1027) - CAPI_INFO (0xc000) - UNKNOWN INFO
14:06:50.322 script_funcs.c [0] (SCRIPT) - Queue: 7, Pending: 0
14:06:50.323 script_funcs.c [0] (SCRIPT) - tone generator stopped!
14:06:50.579 capi_events.c (IND, CTRL 3, PLCI: 1027) - CAPI_CONNECT_ACTIVE
14:06:50.582 capi_ctrl.c (CNF, CTRL 3, PLCI: 1027, NCCI: 66563) - CAPI_CONNECT_B3
14:06:50.583 capi_events.c (IND, CTRL 3, PLCI: 1027, NCCI: 66563) - CAPI_CONNECT_B3_ACTIVE
14:06:50.587 capi_funcs.c Enable DTMF for NCCI 66563
14:06:50.590 capi_ctrl.c (CNF, CTRL 3, PLCI: 1027, NCCI: 66563) - CAPI_FACILITY
14:07:16.042 capi_events.c (IND, CTRL 4, PLCI: 1540) - CAPI_CONNECT (Acc#: 0#720XXXX (0), Target#: unknown)
14:07:16.046 conference.c Port 4 (capi port [1]) transmitting to port 1 (null port)
14:07:16.047 conference.c Port 1 (null port) transmitting to port 4 (capi port [1])
14:07:16.048 script_funcs.c RUN SCRIPT: "./script/script_main.sh" "CONNECT" "CAPI" "INCOMING" "1" "-1" "unknown" "0#720XXXX" "1" ""
14:07:25.643 capi_events.c (IND, CTRL 4, PLCI: 1540) - CAPI_INFO (0x0018) - CHANNEL IDENTIFICATION (0x03)
14:07:25.647 capi_events.c (IND, CTRL 4, PLCI: 1540) - CAPI_INFO (0xc000) - UNKNOWN INFO
14:07:25.649 capi_ctrl.c (CNF, CTRL 4, PLCI: 1540) - CAPI_ALERT
