Auch nach Umstellung des Interfaces auf die lokale IP der Fritzbox ändert sich nicht viel. Ich habe nochmal den Log angehängt. Es gibt diesen Fehler: Call DISCONNECTED [port=0, reason=408 (Request Timeout)]
@bodega du hast Post
13:37:21.357 voip_funcs.c Initialize outgoing call from 'sip:[email protected]' to 'sip:[email protected]'
13:37:21.358 icstr0x54f438 ICE session created, comp_cnt=2, role is Controlling agent
13:37:21.359 icstr0x54f438 Candidate 0 added: comp_id=1, type=Host, foundation=Ha9fe0201, addr=169.254.2.1:30000, base=169.254.2.1:30000, prio=0x64ffffff (1694498815)
13:37:21.359 icstr0x54f438 Candidate 1 added: comp_id=1, type=Server Reflexive, foundation=Sa9fe0201, addr=84.174.26.216:30000, base=169.254.2.1:30000, prio=0x7effffff (2130706431)
13:37:21.361 icstr0x54f438 Candidate 2 added: comp_id=2, type=Host, foundation=Ha9fe0201, addr=169.254.2.1:30001, base=169.254.2.1:30001, prio=0x64fffffe (1694498814)
13:37:21.362 icstr0x54f438 Candidate 3 added: comp_id=2, type=Server Reflexive, foundation=Sa9fe0201, addr=84.174.26.216:30001, base=169.254.2.1:30001, prio=0x7efffffe (2130706430)
13:37:21.362 voip_funcs.c Create SDP...
13:37:21.366 voip_funcs.c Create invite session...
13:37:21.372 voip_events.c Call state changed to CALLING [port=0]
13:37:21.375 script_funcs.c RUN SCRIPT: "/var/dtmfbox/script/script_main.sh" "CONNECT" "VOIP" "OUTGOING" "0" "-1" "496xxxxxxxxxx" "[email protected]" "1" ""
13:37:21.411 voip_events.c Call state changed to CALLING [port=0]
13:37:21.416 script_funcs.c [-1] (SCRIPT) - CALL - VOIP - sip:[email protected] -> sip:[email protected]
13:37:21.435 funcs.c Set high priority
13:37:21.474 sip_endpoint.c Error processing packet from 212.227.15.231:5060: Unknown pjsip error 171050 To [code 171050]:
SIP/2.0 500 I'm terribly sorry, server error occurred (1/SL)
Via: SIP/2.0/UDP 84.174.26.216:5061;rport=5061;branch=z9hG4bKPj09d10000000f67458b6b
Call-ID: 09d10000000d67458b6b
CSeq: 2541 INVITE
Server: OpenSer (1.2.0-dev15-notls (i386/linux))
Content-Length: 0
-- end of packet.
13:37:21.605 sip_endpoint.c Error processing packet from 212.227.15.231:5060: Unknown pjsip error 171050 To [code 171050]:
CSeq: 2541 INVITE
Content-Length: 0
-- end of packet.
13:37:56.747 voip_events.c Call DISCONNECTED [port=0, reason=408 (Request Timeout)]
13:37:56.748 script_funcs.c RUN SCRIPT: "/var/dtmfbox/script/script_main.sh" "DISCONNECT" "VOIP" "OUTGOING" "0" "-1" "496xxxxxxxxxx" "[email protected]" "1" ""
13:37:56.917 icstr0x54f438 Destroying ICE session
13:37:56.918 voip_events.c Hangup [0]
13:37:56.933 funcs.c Set low priority
