22:57:14.323 endpoint Request msg REGISTER/cseq=13392 (tdta0x553444) created.
22:57:14.325 tsx0x55444c Transaction created for Request msg REGISTER/cseq=13393 (tdta0x553444)
22:57:14.325 tsx0x55444c Sending Request msg REGISTER/cseq=13393 (tdta0x553444) in state Null
22:57:14.326 sip_resolve.c DNS resolver not available, target 'sip.1und1.de:0' type=Unspecified will be resolved with gethostbyname()
22:57:14.329 voip_ctrl.c Start VOIP listen loop...
22:57:14.331 sip_resolve.c Target 'sip.1und1.de:0' type=Unspecified resolved to '212.227.15.197:5060' type=UDP
22:57:14.333 tsx0x55444c State changed from Null to Calling, event=TX_MSG
22:57:14.333 voip_auth.c SIP (TX-REGISTER):
REGISTER sip:sip.1und1.de SIP/2.0
Via: SIP/2.0/UDP 87.163.57.33:64259;rport;branch=z9hG4bKPj03970000000375cb6c55
Max-Forwards: 70
From: "1&1 411XXXXX" <sip:[email protected]>;tag=03970000000275cb6c55
To: <sip:[email protected]>
Call-ID: 03970000000175cb6c55
CSeq: 13393 REGISTER
User-Agent: dtmfbox v0.3.9
Contact: <sip:[email protected]:64259>;expires=300
Expires: 300
Content-Length: 0
22:57:14.336 capi_ctrl.c (0xff) - Listen to CAPI incoming controller 1...
22:57:14.338 capi_ctrl.c (0xff) - Listen to CAPI outgoing controller 1...
22:57:14.339 capi_ctrl.c (0xff) - Listen to CAPI internal controller 3...
22:57:14.340 capi_ctrl.c (CNF, CTRL 1, PLCI: 0) - CAPI_LISTEN
22:57:14.341 capi_ctrl.c (CNF, CTRL 3, PLCI: 0) - CAPI_LISTEN
22:57:14.413 sip_endpoint.c Processing incoming message: Response msg 401/REGISTER/cseq=13393 (rdata0x507a94)
22:57:14.415 tsx0x55444c Incoming Response msg 401/REGISTER/cseq=13393 (rdata0x507a94) in state Calling
22:57:14.415 tsx0x55444c State changed from Calling to Completed, event=RX_MSG
22:57:14.416 sip_auth_clien Unable to set auth for tdta0x553444: can not find credential for 87.163.57.33/Digest
22:57:14.417 voip_auth.c SIP (RX-REGISTER):
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 87.163.57.33:64259;rport=64259;branch=z9hG4bKPj03970000000375cb6c55
To: <sip:[email protected]>;tag=329cfeaa6ded039da25ff8cbb8668bd2.c7b9
WWW-Authenticate: Digest realm="87.163.57.33", nonce="46c8afd6fe830ff5f76fb08febfab2409d879682"
Server: UI OpenSer
Content-Length: 0
22:57:14.418 voip_auth.c ERR: SIP registration error (sip.1und1.de), status=12!
22:57:14.418 voip_auth.c ERR: 401 - Unauthorized
22:57:19.422 tsx0x55444c Timeout timer event
22:57:19.422 tsx0x55444c State changed from Completed to Terminated, event=TIMER
22:57:19.432 tsx0x55444c Timeout timer event
22:57:19.432 tsx0x55444c State changed from Terminated to Destroyed, event=TIMER
22:57:19.433 tdta0x553444 Destroying txdata Request msg REGISTER/cseq=13393 (tdta0x553444)
22:57:19.433 tsx0x55444c Transaction destroyed!
23:00:14.360 endpoint Request msg ACK/cseq=100 (tdta0x553444) created.
23:00:14.361 sip_resolve.c DNS resolver not available, target 'sip.1und1.de:0' type=Unspecified will be resolved with gethostbyname()
23:00:14.415 sip_resolve.c Target 'sip.1und1.de:0' type=Unspecified resolved to '212.227.15.231:5060' type=UDP
23:00:14.416 tdta0x553444 Destroying txdata Request msg ACK/cseq=100 (tdta0x553444)
23:00:14.417 dtmfbox.c Successfully sent keep-alive (sip.1und1.de)
