dsmod-0.2.9 mit 06.04.27, 08.04.27, 23.04.27, 25.04.27, 43.04.27, 12.04.26, 14.04.26
Tut mir leid, zu so später Stunde noch zu stören, aber leider habe ich immer noch Fehler :/
STEP 2: MODIFY
applying patches
  applying patches (300ip_as_fon-de)
    patching file etc/profile
    patching file usr/bin/system_status
    patching file etc/init.d/rc.net
    patching file etc/init.d/rc.voip
    patching file etc/init.d/rc.S
    patching file usr/www/all/html/de/first/first_Sip_3.frm
    patching file usr/www/all/html/de/first/first_Sip_3.js
    Hunk #1 succeeded at 246 (offset 23 lines).
    patching file usr/www/all/html/de/first/first_Sip_free.frm
    Hunk #1 succeeded at 20 with fuzz 1.
    patching file usr/www/all/html/de/first/first_Sip_free.js
    Hunk #1 succeeded at 115 with fuzz 2 (offset 34 lines).
    patching file usr/www/all/html/de/fon/dial.js
    Hunk #1 succeeded at 20 (offset 1 line).
    patching file usr/www/all/html/de/fon/fonbuch.js
    Hunk #1 succeeded at 149 (offset 3 lines).
    patching file usr/www/all/html/de/fon/foncalls.js
    Hunk #1 succeeded at 96 (offset 5 lines).
    patching file usr/www/all/html/de/fon/fonlist.html
    patching file usr/www/all/html/de/fon/rulall1.frm
    patching file usr/www/all/html/de/fon/rulall1.js
    patching file usr/www/all/html/de/fon/rulall.frm
    patching file usr/www/all/html/de/fon/rulall.html
    patching file usr/www/all/html/de/fon/rulall.js
    patching file usr/www/all/html/de/fon/rul.frm
    patching file usr/www/all/html/de/fon/rul.html
    patching file usr/www/all/html/de/fon/rul.js
    patching file usr/www/all/html/de/fon/sip1.frm
    Hunk #1 succeeded at 59 with fuzz 2 (offset 2 lines).
    patching file usr/www/all/html/de/fon/sip1.js
    Hunk #1 succeeded at 825 (offset 62 lines).
    patching file usr/www/all/html/de/fon/wecker.js
    patching file usr/www/all/html/de/system/nacht.frm
    patching file usr/www/all/html/de/system/nacht.js
    patching file usr/www/all/html/de/menus/menu2_fon.html
    Hunk #1 succeeded at 60 (offset -9 lines).
    patching file usr/www/all/html/de/menus/menu2_homehome.html
    patching file usr/www/all/html/de/menus/menu2.inc
    Hunk #1 FAILED at 7.
    1 out of 1 hunk FAILED -- saving rejects to file usr/www/all/html/de/menus/menu2.inc.rej
    patching file usr/www/all/html/de/menus/menu2_internet.html
    patching file usr/www/all/html/de/menus/menu2_system.html
make: *** [firmware] Fehler 2
Ich habe den original ds-0.2.9 mit dem p4 gepatcht...
Hi Oliver,
für die Eumex:
in cond ist die install-300ip-as-fon.patch zu ändern
die Datei 190-webmenu.patch hab ich vergessen gehabt (in 300ip_as_fon/de)
lg.
Robert
Edit: @morpho27 in post #17 hab ich die Dateien die zu ändern sind angehängt, die Dateien findest du in patches/300ip_as_fon, in patches/300ip_as_fon/de und in patches/cond
Hi und danke...habs grad zufällig selbst schon entdeckt ;) Großes Danke!
Es lief durch :)
Kann sein das ich blind bin, aber ich seh keinen Anhang.
Du bist nicht blind. Schau nochmal nach. ;-)
MfG Oliver
Alles klar, vielen Dank.
Soll ich mit dem aufspielen besser noch warten oder ist der Patch schon ausgereift? (Soll für ne Fritz!Box Fon WLAN sein)
@ Olistudent: i've used p2 too, and it works...:(
Thanks
Tk
@bartimes
Es sollten keine Probleme auftreten. Ich hab es zwar noch nicht selbst getestet, aber da ich im Patch nur ein paar Kleinigkeiten geändert hab, dass der dsmod wieder durchläuft, sollte da nix schief gehen.
MfG Oliver
Ok, i've tried the patch p3 too, and after some question it seems to be gone...but after make menuconfig and make, this is the result:
STEP 2: MODIFY
applying patches
applying patches (fon-de)
can't find file to patch at input line 4
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff -burN ds-0.2.9.orig/Config.in ds-0.2.9/Config.in
|--- ds-0.2.9.orig/Config.in 2007-01-27 15:40:30.000000000 +0100
|+++ ds-0.2.9/Config.in 2007-01-27 15:38:25.000000000 +0100
File to patch:
Skip this patch? [y]
Skipping patch.
2 out of 2 hunks ignored
can't find file to patch at input line 31
|diff -burN ds-0.2.9.orig/patches/fon/de/190-webmenu.patch ds-0.2.9/patches/
|--- ds-0.2.9.orig/patches/fon/de/190-webmenu.patch 2006-07-24 02:38:59.0000
00000 +0200
|+++ ds-0.2.9/patches/fon/de/190-webmenu.patch 2007-01-27 15:30:26.0000
00000 +0100
File to patch:
Skipping patch.
1 out of 1 hunk ignored
can't find file to patch at input line 51
|diff -burN ds-0.2.9.orig/patches/fon_wlan/de/190-webmenu.patch ds-0.2.9/pat
|--- ds-0.2.9.orig/patches/fon_wlan/de/190-webmenu.patch 2006-07-24 02:46
:58.000000000 +0200
|+++ ds-0.2.9/patches/fon_wlan/de/190-webmenu.patch 2007-01-27 15:23:11.0000
00000 +0100
File to patch:
Skipping patch.
make: *** [firmware] Error 2
So, if i reinstall all ds_mod, may this solve the problem?
Again thanks for your patience:oops:
Mfg
Tokka
Today it seems not a good day for this job :(
I don't know what you are doing there. Can you please post what you are typing. From tar xzf dsmod-... until patch -p0 < ds-0.2.9.p5.patch.
Do you know what to do with this Patch-file. I think you don't.
Greets, Oliver
Super Arbeit Oliver ! Das Erstellen des Images mit dem p5 klappt für die 5050 ...
Was die 7050 angeht, denke ich dass du wohl recht haben wirst, habe es selber nicht genau untersucht - dachte nur, dass du das vielleicht schon wüsstest. Schade, dass man quasi weniger "freien" Flash-Speicher auf der 7050 hat. Denke mal, dass der ganze WLAN Teil halt mehr braucht.
Insgesamt habe ich als Pakete ausgewählt:
- callmonitor
- dropbear
- stunnel
- syslogd-cgi
- wol-cgi
... sehr schade, wenn das die Kapazitäten der 7050 schon überschreitet :(
Ok, thank Oli, i try to explain myself at my best...
My ds_mod version is 0.2.9 with p2 patch, i would try to put on the p3 (or p3.1) patch for work with fbf fw 06.04.27...
These are my steps:
downladed p3.1 patch (needed for peoples that have p2 patch installed), after this:
User@user ~
$ bunzip2 ds-0.2.9-p3.1.patch.bz2
User@user ~
$ patch -p0 < ds-0.2.9-p3.1.patch
patching file ds-0.2.9/Config.in
Reversed (or previously applied) patch detected!  Assume -R? [n] n
Apply anyway? [n] y
Hunk #1 FAILED at 671.
Hunk #2 FAILED at 683.
2 out of 2 hunks FAILED -- saving rejects to file ds-0.2.9/Config.in.rej
patching file ds-0.2.9/patches/fon/de/190-webmenu.patch
Apply anyway? [n] y
Hunk #1 FAILED at 21.
1 out of 1 hunk FAILED -- saving rejects to file ds-0.2.9/patches/fon/de/190-web
menu.patch.rej
patching file ds-0.2.9/patches/fon_wlan/de/190-webmenu.patch
Apply anyway? [n] y
1 out of 1 hunk FAILED -- saving rejects to file ds-0.2.9/patches/fon_wlan/de/19
0-webmenu.patch.rej
User@user ~
I've also tried to answer yes at "assume - R" question, but no better result obtained...
I understand that i have some trouble with the showed files, but i don't know i can solve this problem...i've tried also with p3-patch, but different errors don't change the final situation...
I also know that i am hard like a donkey, so...be patience, i'm doing my best...
Vielen Dank
Tokka
@Oliver: Dank deines p5 funktioniert die Image Erstellung für die 5050 jetzt. Hut ab vor dir!:-o
Image aufspielen muss ich erst noch testen. Aber vielen Dank schonmal
Grüsse Mig
@Tokka
Perhaps you have patched the files correctly. It should work like you are doing. Unfortunately I can't see if you are in the right directory. But I think you are because with -p2 you got it running.
I can post you the files you need. And then you can copy them in your dsmod.
MfG Oliver
Many thanks, i'm broking my head cause i don't understand what's wrong...this morning i've updated the busybox too, and i have to test after this update if it works...
So, i send you my mail address in pm.
Vielen Dank
MfG
And all the possible way to thank you:groesste: :bier:
Tokka
Ich versuche in der 190-webmenu.patch noch einen Button in der Weboberfläche einzufügen. Aber irgendwie funzt es nicht.
Ich poste mal die ersten 11 Zeilen des Patches:
diff -ruN usr/www/all/html/de/menus/menu2_fon.html.orig usr/www/all/html/de/menus/menu2_fon.html
--- usr/www/all/html/de/menus/menu2_fon.html.orig	2006-02-22 20:13:43.000000000 +0100
+++ usr/www/all/html/de/menus/menu2_fon.html	2006-03-20 00:31:34.468344704 +0100
@@ -69,5 +69,6 @@
 <? if eq $var:isWizz 1 `
 	<li class="LMenuitem" style="margin-top:24px"><img src="<? echo '$var:pfeil' ?>"> <a href="javascript:jslGoTo('first','direkt')">$var:menuAssistent</a></li>
+	<li class="LMenuitem" style="margin-top:24px"><img src="<? echo $var:pfeil ?>"> <a href="/cgi-bin/dsmod_status" target="_blank"><? echo $var:menuDSMOD ?></a></li>
+	<li class="LMenuitem"><img src="<? echo $var:pfeil ?>"> <a href="/tsb.htm" target="_blank"><? echo $var:menuLCR ?></a></li>
 	<li class="LMenubottom"></li>
 </ul>
Der Fehler passiert in Step2: Modify
patch: **** malformed patch at line 11: </ul>
Woran liegts? Kann mir das jemand erklären?
schön für dich, bzw. dein pech.
in wie weit meinst du, dass dein posting tatsächlich in diesen beitrag passt?
Weil es sich um das backen eines Fonimages handelt!??
ich halte es eher für ein seperates problem, für dass du einen eigenen thread hättest eröffnen sollen.
jedenfalls ist es keinefalls spezifisch für "dsmod-0.2.9 mit 06.04.27, 08.04.27, 12.04.26 und 14.04.26" - und genau das ist der titel dieses thread.
schau mal in die forumsregeln...
OK, habs kappiert und mache brav nen neuen Thread auf!
jahel98
