ds26-15.2 and 7140 -firmware 39.04.47
l i n u s
15 Aug 2006
Up to version 39.04.34 English, I managed to install the ds-mod, but with this new version, not compile:
ERROR: modpatch
Thanks for whoever would give me a solution.
Linus
Hi.
You will have to update the patches manually or wait for a new version of dsmod.
Greets Oliver
Olistudent thanks, I saw that for 7170
But what patches for 7140?
Vielen danken
Linus
As he said, *you* have to update the patches manually (that is, you have to modify the existing patches in dsmod/patches/7140 to match the current firmware).
I know that the paths of the patches are there, but I wanted to say how we should change these patches. If you edited manually, although some have put in?
Best Regards
Linus
Hi selbe prob. mit der FW 29.04.49ds26-15.2 7170
Hi da daussen an den Bildschirmen habe den gleichen fehler ! Ich bin der Meinung das ich alle patches eingespielt habe, die von kriegaex veröffentlicht wurden ! Welche sind den am wichtigsten damit es durchläuft ? Ich sehe bei olistudent laüft das ganze Fritz!Box Fon WLAN 7170 FW:29.04.49ds26-15.2
lg chris :)
@l i n u s
The easiest way would be to read the existing patches, find the parts that are to be changed in the new firmware version, apply the changes manually and afterwards create a new patchset from them. If you don't know how to do that, you'll have to read about the 'diff' and 'patch' commands in linux.
@xargs
Auch für Dich: Es wurde kein angepasstes Patchset für diese Version veröffentlicht. Du müsstest also selbst die Patches manuell anpassen (daher schauen was die alten Patches machen, Firmware-Dateien manuell anpassen, Patchset erstellen). Dazu solltest Du aber zumindest wissen, wie man die Befehle 'patch' und 'diff' benutzt.
marlborock on the italian forum made a patch for dsmod26-15.2 to make it do the dsmod on the new firmware, but something strange happened to me: having finished the dsmod26 successfully, and loading it into my 7140, i lost the web interface of fritz itself, checking on the services i saw that the httpd service is being launched with the folder of web pages to be /usr/www/all instead of /usr/www/avme/en
how is it possible to have an english firmware load pages from this root ?
i am preparing to return to the 39.04.34 firmware back again....
  • pre_tmp_patches_47_7140.zip
Maybe you want to wait for version 15.3 or access the soon-to-be public SVN repository (only a few more days at most). The firmware is already integrated into the current developer version. Watch the release thread for an announcement or the subforum for a new sticky thread during the upcoming week.
