olistudent
IPPF-Urgestein
- Mitglied seit
- 19 Okt 2004
- Beiträge
- 14,787
- Punkte für Reaktionen
- 13
- Punkte
- 38
make[2]: Entering directory `/home/common/downloads/ds-0.2.9_26-5/source/mc-4.5.0/po'
make[2]: *** Keine Regel vorhanden, um das Target »../gnome/achown.c«,
benötigt von »mc.pot«, zu erstellen. Schluss.
collect2: ld returned 1 exit status
make[3]: *** [faked] Fehler 1
make[3]: Leaving directory `/home/lars/ds-0.2.9_26-5/source/fakeroot-1.5.8'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/home/lars/ds-0.2.9_26-5/source/fakeroot-1.5.8'
make[1]: *** [all] Fehler 2
make[1]: Leaving directory `/home/lars/ds-0.2.9_26-5/source/fakeroot-1.5.8'
make: *** [source/fakeroot-1.5.8/faked] Fehler 2
m0rph schrieb:Code:collect2: ld returned 1 exit status
make -C source/fakeroot-1.5.8
make[1]: Entering directory `/home/lars/ds-0.2.9_26-5/source/fakeroot-1.5.8'
make all-recursive
make[2]: Entering directory `/home/lars/ds-0.2.9_26-5/source/fakeroot-1.5.8'
Making all in scripts
make[3]: Entering directory `/home/lars/ds-0.2.9_26-5/source/fakeroot-1.5.8/scripts'
make[3]: Für das Ziel »all« ist nichts zu tun.
make[3]: Leaving directory `/home/lars/ds-0.2.9_26-5/source/fakeroot-1.5.8/scripts'
Making all in test
make[3]: Entering directory `/home/lars/ds-0.2.9_26-5/source/fakeroot-1.5.8/test'
make[3]: Leaving directory `/home/lars/ds-0.2.9_26-5/source/fakeroot-1.5.8/test'
make[3]: Entering directory `/home/lars/ds-0.2.9_26-5/source/fakeroot-1.5.8'
CONFIG_FILES= CONFIG_HEADERS= /bin/sh ./config.status
config.status: executing depfiles commands
config.status: executing libtool commands
/bin/sh ./libtool --tag=CC --mode=link gcc -O3 -Wall -o faked faked.o libcommunicate.la -ldl
libtool: link: gcc -O3 -Wall -o faked faked.o ./.libs/libcommunicate.a -ldl
/usr/lib/libc_nonshared.a(elf-init.oS)(.text.__i686.get_pc_thunk.bx+0x0): In function `__i686.get_pc_thunk.bx':
: multiple definition of `__i686.get_pc_thunk.bx'
./.libs/libcommunicate.a(communicate.o)(.gnu.linkonce.t.__i686.get_pc_thunk.bx+0x0): first defined here
Bei mir genau umgekehrt.m0rph schrieb:so ziemlich alles im menuconf deaktiviert
kernel image size: 7546880 (max: 7798784)
--15:15:15-- http://www.eiband.info/dsmod/mc-4.5.0-dsmod-0.2.tar.bz2
=> `dl/mc-4.5.0-dsmod-0.2.tar.bz2'
Auflösen des Rechnernamens 'www.eiband.info'.... 82.165.86.215
Verbindungsaufbau mit www.eiband.info[82.165.86.215]:80... verbunden.
HTTP-Anfrage gesendet, warte auf Antwort... 200 OK
Länge: 331.893 (324K) [application/x-tar]
100%[================================================================================>] 331.893 121.30K/s
15:15:19 (120.89 KB/s) - 'dl/mc-4.5.0-dsmod-0.2.tar.bz2' gespeichert [331893/331893]
/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section=.comment --remove-section=.note source/mc-4.5.0/src/mc
/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section=.comment --remove-section=.note source/mc-4.5.0/src/cons.saver
cp source/mc-4.5.0/src/mc packages/mc-4.5.0/root/usr/bin/mc.bin
cp source/mc-4.5.0/src/cons.saver packages/mc-4.5.0/root/usr/bin/cons.saver
/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section=.comment --remove-section=.note source/openvpn-2.1_beta14/openvpn
cp source/openvpn-2.1_beta14/openvpn packages/openvpn-lzo-2.1_beta14/root/usr/sbin/
/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section=.comment --remove-section=.note source/samba-2.0.10/source/bin/*
cp source/samba-2.0.10/source/bin/smbd packages/samba-2.0.10/root/usr/sbin/
cp source/samba-2.0.10/source/bin/nmbd packages/samba-2.0.10/root/usr/sbin/
/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section=.comment --remove-section=.note source/screen-4.0.2/screen
cp source/screen-4.0.2/screen packages/screen-4.0.2/root/usr/bin/screen.bin
PATH=/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin \
CPPFLAGS="-I/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin/../usr/include" \
make CC="/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin/mipsel-linux-uclibc-gcc" \
EXTRA_CFLAGS="-Os -Wa,--trap -pipe -mips2 -Wall -W" \
EXTRA_LDFLAGS="-L/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin/../lib -L/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin/../usr/lib -static-libgcc" \
-C source/vpnc-0.3.3
make[1]: Entering directory `/home/common/downloads/ds-0.2.9_26-5/source/vpnc-0.3.3'
make[1]: »vpnc« ist bereits aktualisiert.
make[1]: Leaving directory `/home/common/downloads/ds-0.2.9_26-5/source/vpnc-0.3.3'
/home/common/downloads/ds-0.2.9_26-5/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section=.comment --remove-section=.note source/vpnc-0.3.3/vpnc
cp source/vpnc-0.3.3/vpnc packages/vpnc-0.3.3/root/sbin/
/var/tmp # find / -name "*.log"
find: unable to open `/proc/7/fd': No such file or directory
/var/log/mod.log
/var/log/mod_net.log
/var/log/mod_load.log
/var/tmp #
