Converting a German targeted Fritz!Box Fon Wlan to an International version
... want to have annex b (yes, b) on english.
Use FTP as explained bei schlagerstar
The only command you need is "quote SETENV firmware_version avme"
Than run the recovery "english-annexB" without reboot, as desribed
That's all - good luck
thanks, but does not help....tried to ftp 1000 times..
Connection closed by remote host.
ftp> open 192.168.178.1
Connected to 192.168.178.1.
ftp>
ftp access is available only in the first 3-5 seconds after power on to the FRITZ!!
But, how to connect it, since win xp client that I am using to connect after I unpug the power on 7170 realizes eth connection down after 3-5 seconds and after it boots XP needs like 10 seconds to have eth connection up ?
It *does* work, believe me. As described in my other post, this sometimes helps:
Sometimes it can help to open ftp first by simply typing 'ftp' and then initiate the connection by typing 'open 192.168.178.1', followed by ENTER as soon as you unplug/plug in the Box. If connection fails, simply press ↑ (open 192.168.178.1 will reappear) and ENTER quickly, after 2 or 3 attempts you should be in.
I hope this is comprehensible ....
The "Recover"-firmware you need later:
http://download.avm.de/fritz.box/fr...n_WLAN_7170.AnnexB.en.04.78.recover-image.exe
It seems it does work ;)
I did not follow your directions 100%...now I do not know how it did not work at the beginning but...1st I used fixed IP addr 192.168.178.25 (after I switched do .2)....I do not know how this might work, but anyway..
Then to get this ftp working in time-frame of 3-5 seconds I disabled WLAN card, so I would get quicker LAN connection when powering on 7170..
I must say that I was attempted to disconnect power, after I realized that I changed env variable through quote SETENV..., since webserver did not respond...then I realized that recover image is .exe and that needs to run through winshell....
Recover program worked just fine, it 1st disabled MediaSense, reboot my computer and flashed ROM image...
Thanks guys...
You're welcome :)
Now leave the Fritzbox alone and start partying :rock: :saufen2: :ziggi: :kotz:
I'm off .... Happy 2010 to everyone!
Hello again
I want you to inform, that my fritz! 7170 was converted from annex B to annex A by a hardware modification. Now it connect by a poor line to my dslam in 2 km distance very well. Firmware version 58.04.78, DSL 1.35.62.10. If you want some more info mail me :)
... my fritz! 7170 was converted ... by a hardware modification
Hardware modification? This seems to be a completely new approach!
Before asking via e-mail: Please give some more information here in this thread.
@bratmat:
The spectrum looks excellent! Congratulations!
But I don't see the difference in HW between "before" and "after". What was modified? Who did it?
If you see the yellow box(some kind of capacitor i think) near the dsl filter,in annex B is small but in annex A is very big and has number 105J100. Maybe other changes was made but i didn't saw it.
changes was made by my fritz seller. All the operation cost me 20 euro with shipment cost.
@bratmat:
Yes, I see the 105J100. I don't think it's a capacitor, but I'm not a HW specialist.
Seems, your dealer did a good job, which is worth 20 EUR!
How was the spectrum before the HW mod, when using DSL driver 1.35.62.10? Did the 7170 synchronize at annex A?
It would be very interesting if you find out what changes have been done. They seem to be only minor. Probably such mod is possible in other box types, too.
Thus, you should create your own thread titled "HW modification for Annex A" or so. And then you should advise the HW specialist here in the forum - this seems to be very interesting!
There was no any spectrum, becouse my fritz was no connect to dslam. Now i am very happy becouse my fritz do everything i need, without help of other dsl modem.
@bratmat:
Ok, I have read again your posts dated from november 22. Even with firm 58.04.78 (DSL 1.35.62.10) the 7170 wasn't able to synchronize at annex A.
Thus, the HW mod is a great improvement. Congratulations!
Which dealers make hardware changes?
Are other models from Fritz able to be modded?
Kondensator wurde gewechselt auf 1uF =105 = 0.0000001 F
Ob das wirklich so eine Rolle spielt, ist eigentlich fraglich da ja bereits ein relativ großer Kondensator an der selben Stelle sitzt.
Aber man kann das ja einmal ausprobieren, der vorhandene Kondensator muss ja nicht einmal ausgelötet werden, zum Test kann an den selben Anschlüssen auf der Rückseite eine zweiter Kondensator dazu gelötet werden.
Any TV service technician would be able to change this Condenser, should be also a similar type to make sure the Condenser has the same high frequency characteristics.
I am surprised if this change relay make a difference, because at the same position there is already a rather big Capacitor.
Still one could see what happens if one changes this Part.
... zum Test kann an den selben Anschlüssen auf der Rückseite eine zweiter Kondensator dazu gelötet werden.
Vielen Dank, Johann. Genau so sehe ich das auch.
Es gibt jetzt einen [post=1466285]eigenen Thread[/post] zu diesem viel versprechenden Thema !
Bitte dort weiter machen. Danke.
Please continue the discussion in this [post=1466285]specific thread[/post]! Thank you.
Keine Mitglieder online.
ChTh
