Converting a German targeted Fritz!Box Fon Wlan to an International version
if I use
"quote SETENV Annex A" getting "501 environment variable not set"
if I use "quote SETENV Annex,A" getting "501 Syntax error: Invalid number of parameters"
similar with the other variables - apart from setting quote SETENV firmware_version avme, which works??
if I use
"GET ENV" - I get unknown Mediatype ?? a file gets created but with zero KB
I can get the currently set variables by querying them one by one
quote GETENV annex
returns annex B
and the others:
HWRevision 95.1.0.0
ProductID Fritz_Box_7140
firmware_info 30.04.12
juk11 schrieb:
if I use
Are you sure you are using the boot loader? Or maybe TI changed the boot loader ftp syntax (which I doubt).
If it doesn't work at all, can you telnet to the box? Can you post what you get?
What do you get if you enter ENV ???
What do you get if you enter SET ???
What do you get if you enter cat environment ???
And then enter cat /etc/init.d/rc.init and post the output.
at FTP at bootup (that looks to me like it is the adam2 bootloader):
220 ADAM2 FTP Server ready
User (192.168.178.1: (none)): adam2
331 Password required for adam2
Password:
230 User adam2 successfully logged in
ftp> get env
551 unknown Mediatype
ftp>
Telnet:
# env
DISABLE_WLAN=0
ANNEX_TEST=0
CONFIG_WLAN=y
CONFIG_USB_HOST_AVM=y
CONFIG_AB_COUNT=2
CONFIG_I2C=n
CONFIG_JFFS2=n
CONFIG_CAPI_NT=n
USER=root
CONFIG_STOREUSRCFG=y
CONFIG_NFS=n
USB_HOST_TEST=0
CONFIG_UBIK2=n
CONFIG_CAPI_XILINX=y
prevlevel=N
CONFIG_USB=n
OLDPWD=/
HOME=/
WLAN_TEST=0
OEM=avm
CONFIG_PRODUKT_NAME=FRITZ!Box Fon WLAN 7140
CONFIG_VDSL=n
wlan_cal=03EF,03F3,0016,00E6,010A,00E8,010A,032C,0328
CONFIG_ENVIRONMENT_PATH=/proc/sys/dev/adam2
CONFIG_USB_HOST_TI=n
CONFIG_LED_NO_DSL_LED=y
CONFIG_ASSIST=y
CONFIG_USB_STORAGE=y
CONFIG_CAPI_POTS=y
CONFIG_SUBVERSION=
CONFIG_VERSION=04.12
HWRevision_ATA=1
runlevel=S
WLAN_CAL=0
CONFIG_BLUETOOTH_CTP=n
CONFIG_SERVICEPORTAL_URL=http://www.avm.de/fritzbox-service-portal.php?hardware=
95&oem=avm&language=de&country=&version=30.04.12&subversion=
CONFIG_ROMSIZE=8
CONFIG_FIRMWARE_URL=http://www.avm.de/fritzbox-firmware-update.php?hardware=95&o
CONFIG_PRODUKT=Fritz_Box_7140
HWRevision=95
HWRevision_BitFileCount=
ANNEX=B
CONFIG_XILINX=y
CONFIG_VERSION_MAJOR=30
CONFIG_BUTTON=y
CONFIG_USB_PRINT_SERV=y
CONFIG_VPN=n
CONFIG_ETH_COUNT=4
CONFIG_UPNP=y
CONFIG_CAPI=y
TERM=vt102
CONFIG_MAILER=y
CONFIG_TR069=n
CONFIG_CDROM_FALLBACK=n
CONFIG_DECT=n
CONFIG_WLAN_WDS=y
PATH=/bin:/usr/bin:/sbin:/usr/sbin
CONFIG_INSTALL_TYPE=ar7_8MB_xilinx_4eth_2ab_isdn_te_pots_wlan_usb_host_62068
CONFIG_NAND=n
CONFIG_WLAN_1130TNET=n
CONFIG_CAPI_UBIK=n
reset_status=0
PTEST_SERVER=192.168.178.20
enable_ata=1
annex=A
CONFIG_MEDIASRV=n
CONFIG_OEM_DEFAULT=avm
ANNEX_PTEST_HOST=192.168.178.20
CAPISERV_TEST=0
CONFIG_AUDIO=n
CONFIG_ATA=y
CONFIG_HOMEI2C=n
AB_TEST=0
CONFIG_VLYNQ=y
CONFIG_WLAN_1350TNET=y
CONFIG_VLYNQ_PARAMS=vlynq_reset_bit_0=17
SHELL=/bin/sh
CONFIG_MEDIACLI=n
CONFIG_USB_WLAN_AUTH=y
CONFIG_HOSTNAME=fritz.fonwlan.box
CONFIG_CDROM=n
CONFIG_AURA=n
ETC_CONFIG_PATH=/etc/init.d/rc.init
Language=de
CONFIG_CAPI_TE=y
CONFIG_ANNEX=B
PWD=/
ANNEX_PTEST_FILE=ptest-results-0
Country=049
CONFIG_VLYNQ0=3
CONFIG_TAM_MODE=0
CONFIG_WLAN_GREEN=n
TZ=CET-1CEST,M3.5.0,M10.5.0
CONFIG_VLYNQ1=0
CONFIG_CAPI_MIPS=n
OEM_DEFAULT_INDEX=
CONFIG_BLUETOOTH=n
CONFIG_TAM=n
CONFIG_ATA_FULL=n
CONFIG_RAMSIZE=32
CONFIG_DSL=y
CONFIG_FON=y
# cat /etc/init.d/rc.init
HW=all OEM=all I2C=n HOMEI2C=n
HW=all OEM=all CAPI=n CAPI_UBIK=n CAPI_MIPS=n CAPI_XILINX=n CAPI_TE=n CAPI_NT=n
CAPI_POTS=n
HW=all OEM=all FON=n
HW=all OEM=all WLAN=n WLAN_1130TNET=n WLAN_1350TNET=n
HW=all OEM=all WLAN_WDS=n
HW=all OEM=all WLAN_GREEN=n
HW=all OEM=all DSL=y
HW=all OEM=all VDSL=n
HW=all OEM=all ATA=n ATA_FULL=n
HW=all OEM=all NFS=n
HW=all OEM=all NAND=n
HW=all OEM=all DECT=n
HW=all OEM=all TAM=n TAM_MODE=0
HW=all OEM=all JFFS2=n
HW=all OEM=all VPN=n
HW=all OEM=all TR069=n
HW=all OEM=all UPNP=y
HW=all OEM=all MAILER=n
HW=all OEM=all BUTTON=n
HW=all OEM=all UBIK2=n
HW=all OEM=all VLYNQ=n
HW=all OEM=all VLYNQ0=0
HW=all OEM=all VLYNQ1=0
HW=all OEM=all ANNEX=B
HW=all OEM=all ASSIST=n
HW=all OEM=all STOREUSRCFG=n
HW=all OEM=all PRODUKT=Fritz_Box_2MB
HW=all OEM=all _PRODUKT_NAME=Boot#Error:#running#as#FRITZ!Box#SL
HW=all OEM=all OEM_DEFAULT=avm
HW=all OEM=all INSTALL_TYPE=ar7_2MB_1eth_oem_AOL_32711
HW=all OEM=all VERSION_MAJOR=10
HW=all OEM=all ETH_COUNT=1
HW=all OEM=all CDROM=n CDROM_FALLBACK=y
HW=all OEM=all FIRMWARE_URL=http://www.avm.de/Download
HW=all OEM=all HOSTNAME=fritz.box
HW=all OEM=all AB_COUNT=0
HW=all OEM=all XILINX=n
HW=all OEM=all BLUETOOTH=n BLUETOOTH_CTP=n
HW=all OEM=all AUDIO=n
HW=all OEM=all USB=y USB_HOST_TI=n USB_HOST_AVM=n USB_STORAGE=n USB_WLAN_AUTH=n
USB_PRINT_SERV=n
HW=all OEM=all MEDIASRV=n
HW=all OEM=all MEDIACLI=n
HW=all OEM=all AURA=n
HW=all OEM=all LED_NO_DSL_LED=n
HW=95 OEM=all ANNEX=B
HW=95 OEM=all INSTALL_TYPE=ar7_8MB_xilinx_4eth_2ab_isdn_te_pots_wlan_usb_host_62
068
HW=95 OEM=all VERSION_MAJOR=30
HW=95 OEM=all ROMSIZE=8
HW=95 OEM=all RAMSIZE=32
HW=95 OEM=all CAPI=y CAPI_UBIK=n CAPI_MIPS=n CAPI_XILINX=y CAPI_TE=y CAPI_NT=n C
API_POTS=y
HW=95 OEM=all FON=y
HW=95 OEM=all WLAN=y WLAN_1130TNET=n WLAN_1350TNET=y
HW=95 OEM=all WLAN_WDS=y
HW=95 OEM=all WLAN_GREEN=n
HW=95 OEM=all DSL=y
HW=95 OEM=all VDSL=n
HW=95 OEM=all ATA=y ATA_FULL=n
HW=95 OEM=all NFS=n
HW=95 OEM=all TR069=n
HW=95 OEM=all UPNP=y
HW=95 OEM=all MAILER=y
HW=95 OEM=all DECT=n
HW=95 OEM=all TAM=n TAM_MODE=0
HW=95 OEM=all JFFS2=n
HW=95 OEM=all BUTTON=y
HW=95 OEM=all UBIK2=n
HW=95 OEM=all VLYNQ=y
HW=95 OEM=all VLYNQ0=3
HW=95 OEM=all VLYNQ1=0
HW=95 OEM=all _VLYNQ_PARAMS=vlynq_reset_bit_0=17
HW=95 OEM=all ASSIST=y
HW=95 OEM=all STOREUSRCFG=y
HW=95 OEM=all PRODUKT=Fritz_Box_7140
HW=95 OEM=all _PRODUKT_NAME=FRITZ!Box#Fon#WLAN#7140
HW=95 OEM=all OEM_DEFAULT=avm
HW=95 OEM=all ETH_COUNT=4
HW=95 OEM=all CDROM=n CDROM_FALLBACK=n
HW=95 OEM=all FIRMWARE_URL=
HW=95 OEM=all HOSTNAME=fritz.fonwlan.box
HW=95 OEM=all AB_COUNT=2
HW=95 OEM=all USB=n USB_HOST_TI=n USB_HOST_AVM=y USB_STORAGE=y USB_WLAN_AUTH=y U
SB_PRINT_SERV=y
HW=95 OEM=all BLUETOOTH=n BLUETOOTH_CTP=n
HW=95 OEM=all AUDIO=n
HW=95 OEM=all XILINX=y
HW=95 OEM=all LED_NO_DSL_LED=y
HW=95 OEM=aol _PRODUKT_NAME=FRITZ!Box#Fon#WLAN#7140#(AOL)
# set
AB_TEST='0'
ANNEX='B'
ANNEX_PTEST_FILE='ptest-results-0'
ANNEX_PTEST_HOST='192.168.178.20'
ANNEX_TEST='0'
CAPISERV_TEST='0'
CONFIG_AB_COUNT='2'
CONFIG_ANNEX='B'
CONFIG_ASSIST='y'
CONFIG_ATA='y'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_AURA='n'
CONFIG_BLUETOOTH='n'
CONFIG_BLUETOOTH_CTP='n'
CONFIG_BUTTON='y'
CONFIG_CAPI='y'
CONFIG_CAPI_MIPS='n'
CONFIG_CAPI_NT='n'
CONFIG_CAPI_POTS='y'
CONFIG_CAPI_TE='y'
CONFIG_CAPI_UBIK='n'
CONFIG_CAPI_XILINX='y'
CONFIG_CDROM='n'
CONFIG_CDROM_FALLBACK='n'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_ENVIRONMENT_PATH='/proc/sys/dev/adam2'
CONFIG_ETH_COUNT='4'
CONFIG_FIRMWARE_URL='http://www.avm.de/fritzbox-firmware-update.php?hardware=9
oem=avm&language=de&country='
CONFIG_FON='y'
CONFIG_HOMEI2C='n'
CONFIG_HOSTNAME='fritz.fonwlan.box'
CONFIG_I2C='n'
CONFIG_INSTALL_TYPE='ar7_8MB_xilinx_4eth_2ab_isdn_te_pots_wlan_usb_host_62068'
CONFIG_JFFS2='n'
CONFIG_LED_NO_DSL_LED='y'
CONFIG_MAILER='y'
CONFIG_MEDIACLI='n'
CONFIG_MEDIASRV='n'
CONFIG_NAND='n'
CONFIG_NFS='n'
CONFIG_OEM_DEFAULT='avm'
CONFIG_PRODUKT='Fritz_Box_7140'
CONFIG_PRODUKT_NAME='FRITZ!Box Fon WLAN 7140'
CONFIG_RAMSIZE='32'
CONFIG_ROMSIZE='8'
CONFIG_SERVICEPORTAL_URL='http://www.avm.de/fritzbox-service-portal.php?hardwa
=95&oem=avm&language=de&country=&version=30.04.12&subversion='
CONFIG_STOREUSRCFG='y'
CONFIG_SUBVERSION=''
CONFIG_TAM='n'
CONFIG_TAM_MODE='0'
CONFIG_TR069='n'
CONFIG_UBIK2='n'
CONFIG_UPNP='y'
CONFIG_USB='n'
CONFIG_USB_HOST_AVM='y'
CONFIG_USB_HOST_TI='n'
CONFIG_USB_PRINT_SERV='y'
CONFIG_USB_STORAGE='y'
CONFIG_USB_WLAN_AUTH='y'
CONFIG_VDSL='n'
CONFIG_VERSION='04.12'
CONFIG_VERSION_MAJOR='30'
CONFIG_VLYNQ='y'
CONFIG_VLYNQ0='3'
CONFIG_VLYNQ1='0'
CONFIG_VLYNQ_PARAMS='vlynq_reset_bit_0=17'
CONFIG_VPN='n'
CONFIG_WLAN='y'
CONFIG_WLAN_1130TNET='n'
CONFIG_WLAN_1350TNET='y'
CONFIG_WLAN_GREEN='n'
CONFIG_WLAN_WDS='y'
CONFIG_XILINX='y'
Country='049'
DISABLE_WLAN='0'
ETC_CONFIG_PATH='/etc/init.d/rc.init'
HOME='/'
HWRevision='95'
HWRevision_ATA='1'
HWRevision_BitFileCount=''
HWRevision_Reserved1='0'
IFS='
Language='de'
MANUAL_TZ_ENABLED='no'
OEM='avm'
OEM_DEFAULT_INDEX=''
OEM_tmp='avm'
OLDPWD='/'
PATH='/bin:/usr/bin:/sbin:/usr/sbin'
PPID='589'
PS1='# '
PS2='> '
PS4='+ '
PTEST_SERVER='192.168.178.20'
PWD='/'
SHELL='/bin/sh'
TERM='vt102'
TZ='CET-1CEST,M3.5.0,M10.5.0'
USB_HOST_TEST='0'
USER='root'
VERBOSE_RC_CONF='n'
WLAN_CAL='0'
WLAN_TEST='0'
_='set'
annex='A'
conf_exec_str='export CONFIG_LED_NO_DSL_LED=y'
enable_ata='1'
i='0'
i_parse='LED_NO_DSL_LED=y'
item_count='5'
parse_hw_revision='95[a-zA-Z]*'
parse_language='de'
parse_line=''
parse_oem='avm'
prevlevel='N'
reset_status='0'
runlevel='S'
tty='/dev/pts/0'
wlan_cal='03EF,03F3,0016,00E6,010A,00E8,010A,032C,0328'
Hi telefonicus!
Many thanks for Adam2, your post #167 (and 307 is also useful) - for 7050, it WORKS!
I have one question:
Is Adam2 method for Fritz!Box Fon ATA possible? (I mean special instructions "quote SETENV...") - do you know? I tried searching at the forum and failed :-(
Best regards, Janeo
The forum search engine is poor. Try Google instead and include the term ip-phone-forum in your search string.
Yes, the ATA box has the Adam2 bootloader like almost all Fritzbox routers.
You'll need to enter quote SETENV firmware_version,avme but you can aso use fritz_als_avme_new.tar.
Then recover with
ftp://ftp.avm.de/fritz.box/fritzbox.../fritz.box_fon_ata.en.04.01.recover-image.exe
Good luck!
juk11 schrieb:
Telnet:
What do you read when you start the telnet session? Please post in a code box. If possible edit your above post to make the long listings appear in a code box too.
I was too busy last week I've only found the most obvious differences between the two versions, e.g.:
A:
CONFIG_ANNEX=A
PWD=/proc/sys/dev/adam2
B:
CONFIG_ANNEX=B
PWD=/
B:
A:
CONFIG_VERSION='04.20'
CONFIG_VERSION_MAJOR='39'
B:
Language='de'
OEM='avm'
OEM_tmp='avm'
OLDPWD='/'
PPID='589'
PS1='# '
PS2='> '
PS4='+ '
PWD='/'
A:
Language='en'
OEM='avme'
OEM_tmp='avme'
OLDPWD='/proc/sys/dev'
PPID='1474'
PS1='# '
PS2='> '
PS4='+ '
PWD='/proc/sys/dev/adam2'
B:
Language='de'
OEM='avm'
OEM_tmp='avm'
OLDPWD='/'
PPID='589'
A:
Language='en'
OEM='avme'
OEM_tmp='avme'
PPID='1474'
B:
_='set'
A:
_='GETENV'
You can find the listings from the 7140 Annex A model here: http://www.vocesuip.com/2-vt3812.html?start=15#_Single_Post_View
Another way to kill the box :-(
I read through almost this entire post before starting to try to change the box from German to English (A WLAN 7050 product #2000 2306). I followed very carefully the instructions in post #307. When I got to the part running the recover system, it said:
Searching FRITZ!BOX Fon WLAN 7050 (AnnexB) at:
192.168.178.1
One System Found! Detecting Current Version.
Could not determine the version!
Now what I get is the Power LED flashing and the box does not seem to respond to anything. It does not respond to Telnet, FTP, or Ping (at addresses 1,2,254)
It has been a bit hard to "guess" when to start the FTP because when I apply the power, the connection is established. Then it is cut (ever so briefly) then reestablished. Then a few seconds later (seems quite long but probably about 10 sec) it cuts again (briefly) then reestablishes.
After this failure, I tried to recover using the German version recovery (fritz.box_fon_wlan_7050.04.15.recover-image.exe) and it cannot find the Fritzbox.
Is there anyway to recover from this?
192.168.178.1
I had the exact same problem (Post 291 and before). Please follow the post below exactly. Important things to check are IP address of PC (make sure it is 192.168.178.10 or above i.e. <=10), set NIC to 10 Mbps and half duplex, and use red cable provided by AVM, re-try the recover-image.exe, up to 10 times.
Also, AVM recommends to enter the arp -d command in the command console. It clears the memorized MAC addresses.
http://www.ip-phone-forum.de/showpost.php?p=690127&postcount=167
Only? What about:
quote SETENV HWRevision,???
quote SETENV ProductID,Fritz_Box_???
quote SETENV firmware_info,???
B.regards, Janeo
I think these variables should remain unchanged since the box is the same product for both languages. No modem, no annex.
You could, however, lower the firmware_info if you have a higher version in German (I haven't seen one yet).
quote SETENV firmware_info,11.04.01 (or set to 00.00.00)
rondunaway schrieb:
... re-try the recover-image.exe, up to 10 times.
Yes, that's what I'd recommend too. Apply all the tricks and then try again and again :)
BTW what was your goal again, Annex A English? Once you have changed the environment variables you cannot recover with the opposite firmware. Use fritz.box_fon_wlan_7050.annexa.en.04.26.recover-image.exe
Thanks rondunaway. It FINALLY worked. It did take quite a few trys. I eventually hooked it up to a new system that doesn't have much other stuff on it. I then followed everything carefully (even more so than before). It still took a few tries. I had a couple of other problems along the way. One was a message "could not recover mtd1" followed by a line that read "WinError 10060". The recover stopped at that point.
I tried again and the recover got a bit further. A few more times and it finally completed.
As you say, just keep at it.
Cheers & Thanks again
A:
CONFIG_ANNEX=A
B:
CONFIG_ANNEX=B
PWD=/
B:
A:
B:
Language='de'
OEM='avm'
OEM_tmp='avm'
OLDPWD='/'
PPID='589'
PS1='# '
PS2='> '
PS4='+ '
PWD='/'
A:
Language='en'
OEM='avme'
OEM_tmp='avme'
PPID='1474'
PS1='# '
PS2='> '
PS4='+ '
B:
Language='de'
OEM='avm'
OEM_tmp='avm'
OLDPWD='/'
PPID='589'
A:
Language='en'
OEM='avme'
OEM_tmp='avme'
PPID='1474'
B:
_='set'
A:
_='GETENV'
this is the Telnet output:
BusyBox v1.00-pre3 (2006.03.24-08:21+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
HWRevision='95'
HWRevision_ATA='1'
ANNEX='B'
ANNEX_TEST='0'
OEM='avm'
OEM_tmp='avm'
Language='de'
Country='049'
CONFIG_AB_COUNT='2'
CONFIG_ANNEX='B'
CONFIG_ASSIST='y'
CONFIG_ATA='y'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_AURA='n'
CONFIG_BUTTON='y'
CONFIG_CAPI='y'
CONFIG_CAPI_NT='n'
CONFIG_CAPI_TE='y'
CONFIG_CDROM='n'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_FON='y'
CONFIG_HOMEI2C='n'
CONFIG_I2C='n'
CONFIG_JFFS2='n'
CONFIG_MAILER='y'
CONFIG_MEDIACLI='n'
CONFIG_MEDIASRV='n'
CONFIG_NAND='n'
CONFIG_NFS='n'
CONFIG_RAMSIZE='32'
CONFIG_ROMSIZE='8'
CONFIG_TAM='n'
CONFIG_TAM_MODE='0'
CONFIG_TR069='n'
CONFIG_UBIK2='n'
CONFIG_UPNP='y'
CONFIG_USB='n'
CONFIG_VDSL='n'
CONFIG_VLYNQ='y'
CONFIG_VLYNQ0='3'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='y'
CONFIG_WLAN_WDS='y'
CONFIG_XILINX='y'
ermittle die aktuelle TTY
tty is "/dev/pts/0"
I don't understand the last bit of your entry
B:
_='set'
A:
_='GETENV'
I have tried again to modify the ENV file but this time through telnet.
I modified the 4 variables (HWRevision, firmware_info, Annex and firmware_version) and checked the ENV file with cat to make sure they were changed.... then I tried to do a recovery but the recovery exe still detected the "old" variables and and refuses to update when I checked the file again all of them were written back to the original value apart from firmware_version (which then prevents you vom getting to WEB interface until you change back to AVM)
Then I tried to change the variables again but this time use the WEB interface
to upload a new firmware version but that fails as well.....
any ideas ?
I have a german 7050 also from 1und1 but I do not connect to it via LAN but with WLAN. I have convert it to annex A and now I want to convert it to english. Can you please gve me exact info on how to do it as I am a bit confused with what I have read on the forum. Will your solution work with Wlan connection for example or it is necessary to connect via LAN to convert it?
7140
I too have a German Annex B WLAN 7140 that I would like to convert to English Annex A. I have only been able to implement the following commands:
quote SETENV kernel_args annex=A
quote SETENV firmware_info 39.04.26
I then run fritz.box_fon_wlan_7140.annex.a.en.04.26.recover-image.exe recovery software and receive the following message:
Searching FRITZ!Box Fon WLAN 7140 Annex A at: 192.168.178.1
One system found! - Detecting the current version.
Version successfully detected!
Hardware: FRITZ!Box Fon WLAN 7140
Bootstrap: 1136
Firmware: 39.04.26
FRITZ!Box Fon WLAN 7140 firmware is incompatible with the recovery firmware
Any ideas???
7140
The last thing I tried was to edit the install script in the "-annex a english-" firmware to accept annex B and AVM but that stops with an "unspecified error"...
I don't know what else to try.
It is possible to get the 7140 to work on annex A (german interface though) with firmware 30.04.02 - (maybe also the 30.04.12) using the annex_a tar files posted here somewhere, but you can't update the firmware any further because it will break the Annex A - or at least it wont start the DSL training anymore??
So you miss out on any new features ...
Anybody any other ideas or has actually managed to get the box converted to english - annex a with the newer firmware?
7140
The install script not only checks for english type but it checks the check sum against the checksum file that comes with the firmware (See code below from install script) It also checks for firmware version as seen by code below.
This is probably why you receive an error.
It may also do other checks that would prevent the install of the firmware. I will study the code further to see. My thoughts are possibly remove the checks from the install script.
******Checksum check****************
if [ -f /var/tmp/filesystem.image ] ; then
if ! /var/chksum /var/tmp/filesystem.image ; then
echo "chksum for file /var/tmp/filesystem.image failed."
echo "set INFO led to off (modul=7, state=1)"
echo 7,1>${LED_DEVICE}
exit $INSTALL_FILESYSTEM_CHECKSUM
fi
echo chksum for file /var/tmp/filesystem.image ok
fi
if [ -f /var/tmp/kernel.image ] ; then
if ! /var/chksum /var/tmp/kernel.image ; then
echo "chksum for file /var/tmp/kernel.image failed."
exit $INSTALL_KERNEL_CHECKSUM
fi
echo chksum for file /var/tmp/kernel.image ok
fi
********Firmware version check**********
if [ "$middle_newFWver" -lt "$middle_currFWver" ] ; then
echo "error: Firmware downgrade not allowed"
exit $INSTALL_FIRMWARE_VERSION
else
echo "DEBUG: $middle_newFWver >= $middle_currFWver"
fi
if [ "$middle_newFWver" -eq "$middle_currFWver" ] ; then
if [ "$minor_newFWver" -lt "$minor_currFWver" ] ; then
else
echo "DEBUG: $minor_newFWver >= $minor_currFWver"
fi
else
echo "DEBUG: $middle_newFWver > $middle_currFWver"
fi
echo "Accept Firmware Version: xx.${newFWver}"
Problems with a FritzBox 7050--All Lights Flashing
I followed Haveaniceday procedure to update an 7050 Annex B to Annex A with no problems as it was working. But after that I used the Avm firmware Annex A to update to the lattest version but the Box just went dead with all the lights flashing. it doens't give me any IP and even if I try to use a fixed IP it doenst work, the issue is the same both for LAN or USB. WLAN is not appearing also.
As I have no way to access the router is there any way to recover it?
Thanks alot and again sorry for the trouble
I have exactly the same problem. My box passed away doing exactly the same things as you did. HELP
Dead WLAN 7050
Please follow the instructions in the post (link) below which is a different way to convert from annex A to B or B to A in either language (you need to adjust the commands and download the proper files depending which direction you go). I have used the instruction to go B German to A English and the reverse (visa versa) for a wlan 7050. It will also worked for my dead WLAN 7050 which would do nothing, but power light blinked.
If you are successful in recovering you dead fb thank telefonicus for developing the procedure.
YPLCRP
