Cisco 7940 / 7960 Einstieg
so der tftp server läuft aber das klappt irgendwie nicht die dateien die ich habe heissen P0S3-8-12-00 loads,sb2,bin,sbn sowie meine sipdefault,sip[Mac des Telefon´s]
hier das lor von tftpd32:
Connection received from 192.168.2.2 on port 50464 [31/08 16:05:07.913]
Read request for file <MGC001646C7357E.cnf>. Mode octet [31/08 16:05:07.929]
File <MGC001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:07.929]
Connection received from 192.168.2.2 on port 50465 [31/08 16:05:07.944]
Read request for file <XMLDefault.cnf.xml>. Mode octet [31/08 16:05:07.960]
Using local port 52686 [31/08 16:05:07.960]
<XMLDefault.cnf.xml>: sent 2 blks, 550 bytes in 0 s. 0 blk resent [31/08 16:05:07.960]
Connection received from 192.168.2.2 on port 50466 [31/08 16:05:07.991]
Read request for file <P0S3-8-12-00.loads>. Mode octet [31/08 16:05:08.007]
File <P0S3-8-12-00.loads> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:08.007]
Connection received from 192.168.2.2 on port 50467 [31/08 16:05:08.022]
Read request for file <P0S3-8-12-00.sbn>. Mode octet [31/08 16:05:08.022]
File <P0S3-8-12-00.sbn> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:08.022]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac F4:6D:04:A3:D1:DF [31/08 16:05:30.161]
Previously allocated address 192.168.2.3 acked [31/08 16:05:30.176]
5684 Request 2 not processed [31/08 16:05:30.208]
Connection received from 192.168.2.2 on port 50468 [31/08 16:05:34.217]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:05:34.217]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:34.217]
Connection received from 192.168.2.2 on port 50469 [31/08 16:05:38.214]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:05:38.214]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:38.214]
Connection received from 192.168.2.2 on port 50469 [31/08 16:05:39.213]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:05:39.228]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:39.260]
Connection received from 192.168.2.2 on port 50469 [31/08 16:05:43.226]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:05:43.226]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:43.226]
Connection received from 192.168.2.2 on port 50470 [31/08 16:05:43.257]
Read request for file <SEP001646C7357E.cnf.xml>. Mode octet [31/08 16:05:43.257]
File <SEP001646C7357E.cnf.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:43.257]
Connection received from 192.168.2.2 on port 50471 [31/08 16:05:43.289]
Read request for file <SIP001646C7357E.cnf>. Mode octet [31/08 16:05:43.289]
File <SIP001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:43.289]
Connection received from 192.168.2.2 on port 50472 [31/08 16:05:43.304]
Read request for file <MGC001646C7357E.cnf>. Mode octet [31/08 16:05:43.304]
File <MGC001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:43.304]
Connection received from 192.168.2.2 on port 50473 [31/08 16:05:43.335]
Read request for file <XMLDefault.cnf.xml>. Mode octet [31/08 16:05:43.335]
Using local port 53629 [31/08 16:05:43.335]
<XMLDefault.cnf.xml>: sent 2 blks, 550 bytes in 0 s. 0 blk resent [31/08 16:05:43.351]
Connection received from 192.168.2.2 on port 50474 [31/08 16:05:43.382]
Read request for file <P0S3-8-12-00.loads>. Mode octet [31/08 16:05:43.382]
File <P0S3-8-12-00.loads> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:43.382]
Connection received from 192.168.2.2 on port 50475 [31/08 16:05:43.398]
Read request for file <P0S3-8-12-00.sbn>. Mode octet [31/08 16:05:43.413]
File <P0S3-8-12-00.sbn> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:05:43.413]
Connection received from 192.168.2.2 on port 50476 [31/08 16:06:15.947]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:06:15.947]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:15.947]
Connection received from 192.168.2.2 on port 50477 [31/08 16:06:15.979]
Read request for file <SEP001646C7357E.cnf.xml>. Mode octet [31/08 16:06:15.979]
File <SEP001646C7357E.cnf.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:15.979]
Connection received from 192.168.2.2 on port 50478 [31/08 16:06:15.994]
Read request for file <SIP001646C7357E.cnf>. Mode octet [31/08 16:06:15.994]
File <SIP001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:15.994]
Connection received from 192.168.2.2 on port 50479 [31/08 16:06:16.025]
Read request for file <MGC001646C7357E.cnf>. Mode octet [31/08 16:06:16.025]
File <MGC001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:16.025]
Connection received from 192.168.2.2 on port 50480 [31/08 16:06:16.057]
Read request for file <XMLDefault.cnf.xml>. Mode octet [31/08 16:06:16.057]
Using local port 52579 [31/08 16:06:16.057]
<XMLDefault.cnf.xml>: sent 2 blks, 550 bytes in 0 s. 0 blk resent [31/08 16:06:16.072]
Connection received from 192.168.2.2 on port 50481 [31/08 16:06:16.103]
Read request for file <P0S3-8-12-00.loads>. Mode octet [31/08 16:06:16.119]
File <P0S3-8-12-00.loads> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:16.119]
Connection received from 192.168.2.2 on port 50482 [31/08 16:06:16.135]
Read request for file <P0S3-8-12-00.sbn>. Mode octet [31/08 16:06:16.135]
File <P0S3-8-12-00.sbn> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:16.135]
Connection received from 192.168.2.2 on port 50483 [31/08 16:06:41.410]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:06:41.410]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:41.410]
Connection received from 192.168.2.2 on port 50484 [31/08 16:06:41.426]
Read request for file <SEP001646C7357E.cnf.xml>. Mode octet [31/08 16:06:41.441]
File <SEP001646C7357E.cnf.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:41.441]
Connection received from 192.168.2.2 on port 50485 [31/08 16:06:41.457]
Read request for file <SIP001646C7357E.cnf>. Mode octet [31/08 16:06:41.473]
File <SIP001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:41.473]
Connection received from 192.168.2.2 on port 50486 [31/08 16:06:41.488]
Read request for file <MGC001646C7357E.cnf>. Mode octet [31/08 16:06:41.488]
File <MGC001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:41.488]
Connection received from 192.168.2.2 on port 50487 [31/08 16:06:41.520]
Read request for file <XMLDefault.cnf.xml>. Mode octet [31/08 16:06:41.520]
Using local port 60549 [31/08 16:06:41.520]
<XMLDefault.cnf.xml>: sent 2 blks, 550 bytes in 0 s. 0 blk resent [31/08 16:06:41.535]
Connection received from 192.168.2.2 on port 50488 [31/08 16:06:41.582]
Read request for file <P0S3-8-12-00.loads>. Mode octet [31/08 16:06:41.582]
File <P0S3-8-12-00.loads> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:41.582]
Connection received from 192.168.2.2 on port 50489 [31/08 16:06:41.598]
Read request for file <P0S3-8-12-00.sbn>. Mode octet [31/08 16:06:41.598]
File <P0S3-8-12-00.sbn> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:06:41.613]
Connection received from 192.168.2.2 on port 50490 [31/08 16:07:12.316]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:07:12.316]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:12.316]
Connection received from 192.168.2.2 on port 50491 [31/08 16:07:12.347]
Read request for file <SEP001646C7357E.cnf.xml>. Mode octet [31/08 16:07:12.347]
File <SEP001646C7357E.cnf.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:12.363]
Connection received from 192.168.2.2 on port 50492 [31/08 16:07:12.379]
Read request for file <SIP001646C7357E.cnf>. Mode octet [31/08 16:07:12.379]
File <SIP001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:12.379]
Connection received from 192.168.2.2 on port 50493 [31/08 16:07:12.410]
Read request for file <MGC001646C7357E.cnf>. Mode octet [31/08 16:07:12.410]
File <MGC001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:12.410]
Connection received from 192.168.2.2 on port 50494 [31/08 16:07:12.425]
Read request for file <XMLDefault.cnf.xml>. Mode octet [31/08 16:07:12.425]
Using local port 56885 [31/08 16:07:12.425]
<XMLDefault.cnf.xml>: sent 2 blks, 550 bytes in 0 s. 0 blk resent [31/08 16:07:12.441]
Connection received from 192.168.2.2 on port 50495 [31/08 16:07:12.488]
Read request for file <P0S3-8-12-00.loads>. Mode octet [31/08 16:07:12.488]
File <P0S3-8-12-00.loads> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:12.488]
Connection received from 192.168.2.2 on port 50496 [31/08 16:07:12.503]
Read request for file <P0S3-8-12-00.sbn>. Mode octet [31/08 16:07:12.503]
File <P0S3-8-12-00.sbn> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:12.503]
Connection received from 192.168.2.2 on port 50497 [31/08 16:07:34.125]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:07:34.125]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:34.125]
Connection received from 192.168.2.2 on port 50498 [31/08 16:07:34.156]
Read request for file <SEP001646C7357E.cnf.xml>. Mode octet [31/08 16:07:34.156]
File <SEP001646C7357E.cnf.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:34.156]
Connection received from 192.168.2.2 on port 50499 [31/08 16:07:34.172]
Read request for file <SIP001646C7357E.cnf>. Mode octet [31/08 16:07:34.172]
File <SIP001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:34.172]
Connection received from 192.168.2.2 on port 50500 [31/08 16:07:34.203]
Read request for file <MGC001646C7357E.cnf>. Mode octet [31/08 16:07:34.203]
File <MGC001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:34.203]
Connection received from 192.168.2.2 on port 50501 [31/08 16:07:34.219]
Read request for file <XMLDefault.cnf.xml>. Mode octet [31/08 16:07:34.219]
Using local port 62181 [31/08 16:07:34.219]
<XMLDefault.cnf.xml>: sent 2 blks, 550 bytes in 0 s. 0 blk resent [31/08 16:07:34.234]
Connection received from 192.168.2.2 on port 50502 [31/08 16:07:34.281]
Read request for file <P0S3-8-12-00.loads>. Mode octet [31/08 16:07:34.281]
File <P0S3-8-12-00.loads> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:34.281]
Connection received from 192.168.2.2 on port 50503 [31/08 16:07:34.297]
Read request for file <P0S3-8-12-00.sbn>. Mode octet [31/08 16:07:34.297]
File <P0S3-8-12-00.sbn> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:34.297]
Connection received from 192.168.2.2 on port 50504 [31/08 16:07:57.676]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:07:57.676]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:57.678]
Connection received from 192.168.2.2 on port 50505 [31/08 16:07:57.693]
Read request for file <SEP001646C7357E.cnf.xml>. Mode octet [31/08 16:07:57.693]
File <SEP001646C7357E.cnf.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:57.693]
Connection received from 192.168.2.2 on port 50506 [31/08 16:07:57.725]
Read request for file <SIP001646C7357E.cnf>. Mode octet [31/08 16:07:57.725]
File <SIP001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:57.725]
Connection received from 192.168.2.2 on port 50507 [31/08 16:07:57.756]
Read request for file <MGC001646C7357E.cnf>. Mode octet [31/08 16:07:57.756]
File <MGC001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:57.756]
Connection received from 192.168.2.2 on port 50508 [31/08 16:07:57.771]
Read request for file <XMLDefault.cnf.xml>. Mode octet [31/08 16:07:57.771]
Using local port 58591 [31/08 16:07:57.787]
<XMLDefault.cnf.xml>: sent 2 blks, 550 bytes in 0 s. 0 blk resent [31/08 16:07:57.787]
Connection received from 192.168.2.2 on port 50509 [31/08 16:07:57.818]
Read request for file <P0S3-8-12-00.loads>. Mode octet [31/08 16:07:57.834]
File <P0S3-8-12-00.loads> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:57.834]
Connection received from 192.168.2.2 on port 50510 [31/08 16:07:57.865]
Read request for file <P0S3-8-12-00.sbn>. Mode octet [31/08 16:07:57.865]
File <P0S3-8-12-00.sbn> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:07:57.865]
Connection received from 192.168.2.2 on port 50511 [31/08 16:08:24.783]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:08:24.783]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:24.783]
Connection received from 192.168.2.2 on port 50512 [31/08 16:08:24.799]
Read request for file <SEP001646C7357E.cnf.xml>. Mode octet [31/08 16:08:24.799]
File <SEP001646C7357E.cnf.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:24.799]
Connection received from 192.168.2.2 on port 50513 [31/08 16:08:24.830]
Read request for file <SIP001646C7357E.cnf>. Mode octet [31/08 16:08:24.830]
File <SIP001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:24.830]
Connection received from 192.168.2.2 on port 50514 [31/08 16:08:24.861]
Read request for file <MGC001646C7357E.cnf>. Mode octet [31/08 16:08:24.861]
File <MGC001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:24.861]
Connection received from 192.168.2.2 on port 50515 [31/08 16:08:24.877]
Read request for file <XMLDefault.cnf.xml>. Mode octet [31/08 16:08:24.892]
Using local port 49987 [31/08 16:08:24.892]
<XMLDefault.cnf.xml>: sent 2 blks, 550 bytes in 0 s. 0 blk resent [31/08 16:08:24.892]
Connection received from 192.168.2.2 on port 50516 [31/08 16:08:24.939]
Read request for file <P0S3-8-12-00.loads>. Mode octet [31/08 16:08:24.939]
File <P0S3-8-12-00.loads> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:24.939]
Connection received from 192.168.2.2 on port 50517 [31/08 16:08:24.970]
Read request for file <P0S3-8-12-00.sbn>. Mode octet [31/08 16:08:24.970]
File <P0S3-8-12-00.sbn> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:24.970]
Connection received from 192.168.2.2 on port 50518 [31/08 16:08:58.982]
Read request for file <CTLSEP001646C7357E.tlv>. Mode octet [31/08 16:08:58.997]
File <CTLSEP001646C7357E.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:58.997]
Connection received from 192.168.2.2 on port 50519 [31/08 16:08:59.013]
Read request for file <SEP001646C7357E.cnf.xml>. Mode octet [31/08 16:08:59.013]
File <SEP001646C7357E.cnf.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:59.013]
Connection received from 192.168.2.2 on port 50520 [31/08 16:08:59.044]
Read request for file <SIP001646C7357E.cnf>. Mode octet [31/08 16:08:59.060]
File <SIP001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:59.060]
Connection received from 192.168.2.2 on port 50521 [31/08 16:08:59.075]
Read request for file <MGC001646C7357E.cnf>. Mode octet [31/08 16:08:59.075]
File <MGC001646C7357E.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:59.075]
Connection received from 192.168.2.2 on port 50522 [31/08 16:08:59.106]
Read request for file <XMLDefault.cnf.xml>. Mode octet [31/08 16:08:59.106]
Using local port 65300 [31/08 16:08:59.106]
<XMLDefault.cnf.xml>: sent 2 blks, 550 bytes in 0 s. 0 blk resent [31/08 16:08:59.122]
Connection received from 192.168.2.2 on port 50523 [31/08 16:08:59.169]
Read request for file <P0S3-8-12-00.loads>. Mode octet [31/08 16:08:59.169]
File <P0S3-8-12-00.loads> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:59.169]
Connection received from 192.168.2.2 on port 50524 [31/08 16:08:59.184]
Read request for file <P0S3-8-12-00.sbn>. Mode octet [31/08 16:08:59.184]
File <P0S3-8-12-00.sbn> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [31/08 16:08:59.184]
Habe es hinbekommen sehr hilfreich war dieser Thread
http://www.ip-phone-forum.de/showthread.php?t=103106
http://www.ip-phone-forum.de/showthread.php?t=244979&highlight=7940
http://www.ip-phone-forum.de/showthread.php?t=250979&highlight=7940
Hilfe! Meine Einstellungstaste funktioniert nicht!
Hallo Leute,
ich habe mich mal hier im Forum (...und auch sonst überall im Netz...) intensiv umgeschaut - aber leider keine Hilfe zu meinem Grundsatzproblem finden können. Vielleicht könnt ihr mir ja helfen:
Ich legte mir also ein Cisco 7960 zu (aus der Bucht). Wenn ich das Gerät an den Strom und auch ans Netzwerk (über Fritz!Box 7390) hänge , bootet das Telefon wie erwartet hoch: Configuring VLAN...Configuring IP...Requesting Configuration...TFTP timeout.
Soweit, so gut - hab ich auch nicht anders erwartet. Wie soll das Gerät auch wissen, unter welcher IP der TFTP-Server zu finden ist. Der DHCP der Fritz!Box hat dem Cisco auch eine IP zugewiesen - auch gut. So, jetzt möchte ich gerne über die Einstellungstaste (Taste mit den zwei Quadraten und dem Häkchen) entsprechende Änderung vornehmen. Ich drücke ... und drücke ... nix passiert! Taste defekt? Nein ... * + 6 + Einstellungstaste für ein Reset funktioniert! Werks-Reset gemacht - hilft auch nicht! Ich komme einfach nicht in diese verflixten Einstellungen! Hab's auch schon mit Telnet u.Ä. versucht - keine Chance! Bevor ich nun meinen Kopf immer wieder gegen die Wand schlage - kann mir da ggf. jemand den erlösenden Tipp geben, warum diese Einstellungstaste nicht funzt?
Hallo Anawratha,
dein telefon kann ohne tftp server, von dem es sich die config+firmware holt, nicht arbeiten.
daher musst du dem phone per dhcp die ipadresse des tftp servers bekanntgeben. Da aber deine fritzbox dies nicht kann, bleibt dir nichts anderes übrig, als tftpd32 zu installieren.
Eine recht vernünfige Anleitung: http://www.adrianandgenese.com/blog...940-7960-794x-796x-797x-phone-to-sip-or-sccp/
Nicht vergessen den dhcp deiner fritzbox zu deaktivieren.
Und bitte einen neuen Thread aufmachen, dieser hier wird sonst unendlich und keiner findet etwas wieder
Die Telefone sind u.a. deswegen so günstig weil sie so schwierig einzustellen sind, weil die SIP Firmware nicht frei verfügbar ist und weil die SIP Implementierung sich nicht immer an Standards hält und schlecht dokumentiert ist.
Bei einer Fritzbox wirst du schon das Problem haben das du im DHCP Server nicht die Option 150 für TFTP einstellen kannst.
@xrated
es gibt keinen SIP Standard. Und ja, die SIP Firmware ist für die Phones auch nicht optimal daher besser skinny verwenden.
Wie ich auch schon oben geschrieben muss er tftpd32 verwenden.
Naja, wenn man sich hier durch die Beiträge liest und auch Googel nutzt ist es garnicht so schwer. Verstehe auch nicht wieso sich die Leute die Telefone holen ohne sich mal mit der Materie vorab zu beschäftigen.
Das denken aber die meisten, und selbst Grundlegende Netzwerkkentnisse fehlen. Ich denke man sollte den Thread hier mal aufräumen und dann zu machen. Steht ja schon alles soweit drinne das man mit den Infos ein 40/60 zum laufen bekommt.
@xrated
ganau, und RFC2543, RFC3265, RFC5727 ....
Wie Du schon geschrieben hast gibt es Standards
vielen Dank für Eure Hinweise!
Zwischenzeitlich habe ich das 7960 ans Laufen gebracht (...nur noch nicht die Konfiguration/Aktivierung des Expansion Modules 7914...)! Hierbei war die wichtigste Info, dass der DHCP-Server (=> DHCP in Fritz aus, DHCP in TFTPD64 konfiguriert und eingeschaltet) mit Optionen versehen werden muss (speziell 150 mit der Adresse zum TFTP-Server). Anschliessend war eine Konfiguration über die Config-Dateien problemlos möglich...
Das 7914 hat kein SIP Support, geht also nicht, nur via SCCP
Meine Erfahrungen mit Cisco 7940G und FB 6360
Anbei meine Erfahrungen
Zuerst habe ich das Fon in der Fritz unter IP-Telefon zwei mal angemeldet, damit ich zwei Leitungen bzw. zwei unterschiedliche Abgangsnummer zuweisen kann.
Hat bei mir am besten mit einem alten XP-Rechner geklappt der Stand alone ist.
auf diesen Rechner habe das Programm tftpd32 installiert und folgende Einstellung getätigt.
Netzwerkkarte PC feste IP zugewiesen (192.168.178.1)
TFTP32 gestartet folgnde Einstellungen im Programm getätigt.
Über Settings die Konfig Register geöffnet.
Regiter Global: nur TFTP Server und DHCP Server anhaken.
Register TFTP: unter Base Directory den Pfad anwählen wo die Dateien für das Telefon abgelegt sind z.B. "C:\temp\cisco_Konfig" in diesem Ordner sollten folgende Dateien vorhanden sein:
OS79XX.TXT
POS3-8-12.00.loads
POS3-8-12.00.sb2
PO03-8-12.00.bin
PO03-8-12.00.sbn
SEP[MAC_Adresse_Telefon].cnf.xml
SIP[MAC_Adresse_Telefon].cnf
SIPDefault.cnf
XMLDefault.cnf.xml
außerdem sollte in diesem Register TFTP Secrity auf "None" einstellt werden.
Register DHCP: DHCP Pool definition: IP pool start adress "192.168.178.1", Size of pool "100", DHCP Options: Def. router (Opt3) "192.168.178.1", Mask (Opt1) "255.255.255.0
alle restlichen Einstellungen in den Registern bleiben wie gehabt.
Mit OK die Einstellungen speichern, das Programm startet mit den neuen Einstellungen.
An den Fon habe ich zuerst ein Factory Reset durchgefüht,
das funz wie folgt Taste "#" drücken un gedrücht halten und dabei das Telefon mit der Spannungversorgung verbinden.
Nachdem die Tasten Headset, Micro, Lautsprecher durchgeblinkt haben folgende Tastenkombie drücken: 123456789*0# und mit "1" bestätigen. "http://www.wikihow.com/Reset-a-Cisco-CP-7940G-Phone-to-Factory-Default"
Anschließend Spannungsversorgung abgezogen.
Habe das Fon dann direkt mit dem LAN-Kabel am PC angeschlossen.
Achtung ich habe am Fon die RJ45 Buchse 10/100 PC genutzt.
Jetzt habe ich das Fon wieder mit seiner Spannungsversorgung angeschlossen damit es neu startet.
Nach dem booten des Fon wurden im Register "Log viewer" von TFTP32 dann das Hochladen aller Dateien angezeigt.
Anschließend habe ich das Fon wieder von der Spannungsversorgung getrennt, LAN Kabel an die Buchse 10/100 LAN angesteckt und das Fon am Netzwerk angeschlossen.
Telfon wieder mit der Spannungsversorgung verbunden den Bootvorgang abgewartet dauer ein wenig und siehe dan es funz wie ich es mir vorgestellt habe.
  • Cisco 7940 konfig mit AVM Fritz 6360.zip
  • tftpd32.452.zip
Hallöchen alle miteinander.
Ich lese hier nun schon ein paar Tage mit.
Inzwischen hab ich auch mein 7970G per Post bekommen und mein POE-Switch von H3C liegt hier auch.
Ich hab natürlich ein Telefon mit SCCP Firmware bekommen und dachte mit "ach das flashte mal eben noch um".......
Nunja also alles angestellt.
TFTP eingerichtet,
im Telefon die Netzwerkdaten angepasst.
Und gib ihm......
Naja irgendwas hat nicht geklappt.
Und nun die dümmste aller Fragen -> Brauche ich für das Umflashen ein externes Netzteil?
Mein Telefon geht nach dem boot und der "123456789*0#" eingabe her und spricht nur folgendes mit dem TFTP Server:
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:12:80:55:D0:97 [31/05 21:09:15.118]
DHCP: proposed address 192.168.1.71 [31/05 21:09:15.119]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:12:80:55:D0:97 [31/05 21:09:15.129]
Previously allocated address 192.168.1.71 acked [31/05 21:09:15.129]
Connection received from 192.168.1.71 on port 49152 [31/05 21:09:20.821]
Read request for file <term70.default.loads>. Mode octet [31/05 21:09:20.822]
Using local port 50522 [31/05 21:09:20.822]
<term70.default.loads>: sent 2 blks, 642 bytes in 0 s. 0 blk resent [31/05 21:09:20.824]
Danach ist Schluss und das Phone bootet neu und versucht es erneut.
DrPhreak
Welche SIP Version willst du zZ aufspielen?
Man kann glaube nicht direkt die 9.x aufspielen, sondern muss einen Zwischenschritt über die 8.5 oder so machen.
Außerdem der übliche Hinweis: Macht doch nicht immer gleich einen komplett Reset!
Du hast ja recht, ich war da ein wenig vorschnell.
Brauche ich denn das externe Netzteil ?
Nein PoE reicht aus
Nein PoE reicht aus
Die Cisco 7940 und 7960 Geräte unterstützen Poe nach Standard IEEE 802.3af noch nicht.
Um dennoch einen dementsprechenden PoE-Switch nutzen zu können muss die Belegung des LAN-Kabels geändert werden. Ich such die nachher mal raus, da ich den Link derzeit nicht finde.
Da sein Telefon ja bootet, scheint sein PoE Switch kompatibel zu sein.
Außerdem hat er ein 7970g, meint ihr wirklich er muss ein Kabel basteln???
Ne, das 70er ist POE Tauglich, war etwas schnell da es hier ja eigentlich um 40 und 60er geht...
AlexanderLorenz
