change 'mtd0' to 0x900C0000,0x903C0000
stefanoIT
11 Jul 2007
Hello.
I'm connected to my ATA using serial.
This is what I got
DAM2 Revision TI:0.18.01 AVM: Version:98
(C) Copyright 1996-2003 Texas Instruments Inc. All Rights Reserved.
(C) Copyright 2003 Telogy Networks, Inc.
(C) Copyright 2003-2004 AVM
change 'mtd1' to 0x90010000,0x900C0000
change 'mtd2' to 0x90000000,0x90010000
change 'mtd3' to 0x903C0000,0x903E0000
change 'mtd4' to 0x903E0000,0x90400000
The ATA seems to be dead. Lost mtd2?
Any ideas on what I can do?
Thanks.
Stefano
You have to recover your box with an ejtag cable.
Greets Oliver
Hello. I have a serial cable. I need also jtag? what is a ejtag cable?
thanks
stefano
your environment is corrupted, the bootloader works well. you just have to restore the environment using E-JTag.
best regards
- Feadi
Hi Feadi.
I have an mtd2 from a working ATA. where is the environment?
# cat /proc/mtd
dev: size erasesize name
mtd0: 00300000 00010000 "mtd0"
mtd1: 000b0000 00010000 "mtd1"
mtd2: 00010000 00010000 "mtd2"
mtd3: 00020000 00010000 "mtd3"
mtd4: 00020000 00010000 "mtd4"
mtd5: 00022f00 00010000 "mtd5"
mtd6: 00322f00 00010000 "mtd6"
environment
HWRevision 71
ProductID Fritz_Box_FON_ATA
SerialNumber 0000000000000000
annex B
autoload yes
bootloaderVersion 0.18.01
bootserport tty0
bluetooth 00:04:0E:FF:FF:07
cpufrequency 150000000
firstfreeaddress 0x94730258
firmware_version avme
firmware_info 11.04.01
flashsize 0x00400000
maca 00:15:0C:0D:8B:A2
macb 00:15:0C:0D:8B:A3
macwlan 00:15:0C:0D:8B:A4
macdsl 00:15:0C:0D:8B:A5
memsize 0x01000000
modetty0 38400,n,8,1,hw
modetty1 38400,n,8,1,hw
mtd0 0x900C0000,0x903C0000
mtd1 0x90010000,0x900C0000
mtd2 0x90000000,0x90010000
mtd3 0x903C0000,0x903E0000
mtd4 0x903E0000,0x90400000
my_ipaddress 192.168.178.2
prompt AVM_Ar7
ptest
reserved 00:04:0E:FF:FF:00
req_fullrate_freq 125000000
sysfrequency 125000000
urlader-version 98
usb_board_mac 00:15:0C:0D:8B:A6
usb_rndis_mac 00:15:0C:0D:8B:A7
usb_device_id 0x4701
usb_revision_id 0x0100
usb_device_name USB DSL Device
usb_manufacturer_name AVM
thanks
stefano
Sorry.
I don't understand how I can put the environment in using EJTAG.
I know only how putting bootloader in mtd2. No other things.
Could you explaing me in few words?
I use mktffs.pl to put environment in mtd3 and mtd4 then...
mtd3 -> wrt54g.exe -flash:custom /skipdetect /instrlen:5 /window:90000000 /start:903C0000 /length:20000
mtd4 -> wrt54g.exe -flash:custom /skipdetect /instrlen:5 /window:90000000 /start:903E0000 /length:20000
Is it right?
Thanks a lot.
stefano
