callomonitor
columbo1979
3 Apr 2006
ich bekomme immer den fehler :
Saving listeners...done.
1: Invalid event specification
event: ^01xxxxxx
source: ^SIP3
dest: /bin/ether-wake
action: -i lan xxxxxxxxxxxxxxxx
2: Invalid event specification
event: ^xxxxxxxxxxxxxxxx
source: ^SIP3
3: Invalid event specification
event: ^
source: ^
dest: yac
action: 192.168.0.2
4: Invalid event specification
event: ^
source: ^
dest: mail_missed_call
action: -s "Oh, oh ... ($SOURCE)"
Please correct the errors.
Wo kann da der fehler liegen ? danke !
Habe nun jeweils ein in:request gepackt. fehler weg. aber beim testanruf kommt dies :
including /usr/lib/callmonitor/actions.d/dboxlcd.sh
including /usr/lib/callmonitor/actions.d/dial.sh
including /usr/lib/callmonitor/actions.d/dropbear.sh
including /usr/lib/callmonitor/actions.d/mail.sh
including /usr/lib/callmonitor/actions.d/messages.sh
>>> in:request ID=1 TIMESTAMP=20.06.06 14:32 SOURCE=xxxxxxx DEST=xxxxEXT=4 DURATION=16
[0] EVENT=in:request SOURCE='xxxx' DEST='xxxx' SOURCE_NAME='' DEST_NAME='' ID=1 EXT=4 DURATION=16 TIMESTAMP='20.06.06 14:32'
[0:0] processing rule 'in:request' '^xxxxx' '^SIP3' '/bin/ether-wake -i lan xxxxxxxxxxxxx'
[0:0] event 'in:request' matches pattern 'in:request'
[0:0] parameter SOURCE='xxxx' matches pattern '^xxxx'
[0:0] parameter DEST='xxxx' does NOT match pattern '^SIP3'
[0:0] FAILED
[0:1] processing rule 'in:request' '^xxxx' '^SIP3' '/bin/ether-wake -i lan xxxxxxx'
[0:1] event 'in:request' matches pattern 'in:request'
[0:1] parameter SOURCE='xxxx' does NOT match pattern '^xxxxx'
[0:1] FAILED
[0:2] processing rule 'in:request' '^' '^' 'yac 192.168.0.2'
[0:3] processing rule 'in:request' '^' '^' 'mail_missed_call -s "Oh, oh ... ($SOURCE)"'
[0:2] event 'in:request' matches pattern 'in:request'
[0:2] parameter SOURCE='xxxx' matches pattern '^'
[0:2] parameter DEST='xxxx' matches pattern '^'
[0:2] SUCCEEDED: executing 'yac 192.168.0.2'
[0:3] event 'in:request' matches pattern 'in:request'
[0:3] parameter SOURCE='xxx' matches pattern '^'
[0:3] parameter DEST='xxxx' matches pattern '^'
[0:3] SUCCEEDED: executing 'mail_missed_call -s "Oh, oh ... ($SOURCE)"'
/usr/sbin/callmonitor-test: eval: 1: mail_missed_call: not found
[0:3] listener failed with an exit status of 127
nc: connect: Connection refused
[0:2] listener failed with an exit status of 1
Wobei die Regel stimmt. Woran kann dies liegen ? Danke !
Diese drei Meldungen sollten doch eigentlich Auskunft darüber geben, was genau schief läuft...
Gruß,
Wichard
