Buildumgebung: freetz-linux
ich habe nach längerer Zeit mal wieder versucht, ein Freetz-Image zu bauen.
Dazu habe ich die letzten beiden Updates 1.7.1 und 1.7.2 getestet, bin aber dabei gescheitert.
Bei v1.7.1 lief zwar die VM, aber jeder Build-Versuch brach mit einen fakeroot-Problem ab.
../../libfakeroot.c: In function ‘removexattr’:
../../libfakeroot.c:99:40: error: ‘_STAT_VER’ undeclared (first use in this function)
   99 | #define INT_NEXT_STAT(a,b) NEXT_STAT64(_STAT_VER,a,b)
./fakerootconfig.h:9:43: note: in definition of macro ‘NEXT_STAT64’
    9 | #define NEXT_STAT64(a,b,c) next___xstat64(a,b,c)
../../libfakeroot.c:1853:5: note: in expansion of macro ‘INT_NEXT_STAT’
1853 |   r=INT_NEXT_STAT(path, &st);
../../libfakeroot.c: In function ‘lremovexattr’:
../../libfakeroot.c:100:42: error: ‘_STAT_VER’ undeclared (first use in this function)
  100 | #define INT_NEXT_LSTAT(a,b) NEXT_LSTAT64(_STAT_VER,a,b)
./fakerootconfig.h:13:45: note: in definition of macro ‘NEXT_LSTAT64’
   13 | #define NEXT_LSTAT64(a,b,c) next___lxstat64(a,b,c)
../../libfakeroot.c:1874:5: note: in expansion of macro ‘INT_NEXT_LSTAT’
1874 |   r=INT_NEXT_LSTAT(path, &st);
../../libfakeroot.c: In function ‘fremovexattr’:
../../libfakeroot.c:101:42: error: ‘_STAT_VER’ undeclared (first use in this function)
  101 | #define INT_NEXT_FSTAT(a,b) NEXT_FSTAT64(_STAT_VER,a,b)
./fakerootconfig.h:11:45: note: in definition of macro ‘NEXT_FSTAT64’
   11 | #define NEXT_FSTAT64(a,b,c) next___fxstat64(a,b,c)
../../libfakeroot.c:1895:5: note: in expansion of macro ‘INT_NEXT_FSTAT’
1895 |   r=INT_NEXT_FSTAT(fd, &st);
libtool: link: ar cru .libs/libmacosx.a .libs/libfakeroot_inode64.o .libs/libfakeroot_unix2003.o
ar: `u' modifier ignored since `D' is the default (see `U')
libtool: link: ranlib .libs/libmacosx.a
make[2]: *** [Makefile:648: libfakeroot.lo] Error 1
make[2]: *** Waiting for unfinished jobs....
libtool: link: ( cd ".libs" && rm -f "libmacosx.la" && ln -s "../libmacosx.la" "libmacosx.la" )
make[2]: Leaving directory '/home/freetz/freetz-devel/source/host-tools/fakeroot-1.23/build/arch'
make[1]: *** [Makefile:670: install-recursive] Error 1
make[1]: Leaving directory '/home/freetz/freetz-devel/source/host-tools/fakeroot-1.23/build/arch'
make: *** [tools/make/fakeroot/fakeroot.mk:47: /home/freetz/freetz-devel/tools/build/bin/fakeroot] Error 2
freetz@freetz:~/freetz-devel$
Bei v1.7.2 bekam ich die VM in VirtualBox nicht importiert, es erschien folgende Fehlermeldung:
Im VMWare-Player lief der Import, aber die VM brach beim Booten ab.
Habe ich etwas falsch gemacht?
Vielleicht kann mir ja jemand weiterhefen.
Vielen Dank!
[CODE] TAG [/CODE] gesetzt sowie Bild gemäß Boardregeln als Vorschaubild eingebunden by stoney
Hab mir gerade auch mal die VM vom Teamserver gezogen und versucht zu importieren. Die Fehlermeldung bekomme ich auch. Ich schau mal wo es klemmt.
Edit: Ich hab das Image (die ova-Datei) mal in mehrere kleine Zip-Pakete gepackt. Versuch mal den neuen Download und dann das entpacken der 5 Dateien auf dem PC.
Bei mir klappt der Import nun ohne Probleme. Bitte um Feedback wenn es noch Probleme gibt.
Hallo gismotro,
der Download hat funktioniert (hat er aber auch beim vorherigen Versuch), auch das Auspacken der *.ova war OK.
Beim Import kam dann (wie beim 1. Mal) die folgende Meldung:
ich habe fogende Version von Virtual Box:
Hast Du noch eine Idee, was hier schief läuft?
Bei mir läuft der Import 1A.
Hast du auch genug Platz auf der Platte wo deine VM hin geladen wird ?
Neues Update auf Freetz-Linux-2.0.0-Ubuntu 20.04.01 LTS (Focal Fossa) 64-Bit
Download: >> hier <<
Ich hab da mal die letzten Änderungen aus der Freetz-Linux-1.7.2 mit eingearbeitet.
Reaktionen: 2000gobi und prisrak1
Hallo
ich hab mit der 2.0.0 in putty das Menü Darstellungsproblem wie in Post #741
Hast du zufällig einen Tip? Die TERM Einstellungen wie in #750 greifen leider nicht
Ist aber nicht sooo wichtig ;)
Schöne Grüße!
Ja, kann am Putty liegen:
Stell den mal von UTF-8 auf ISO-8859-1:1998 (Latin-1, West Europe)
UTF-8:
ISO-8859-1:1998 (Latin-1, West Europe):
Hallo zusammen!
Ich versuche grade meine erste Freetz-NG Firmware zu erstellen...
Kurz vor Ende bricht das Ganze aber leider ab... Wie kann ich das Problem lösen?
Fehler:
STEP 1: UNPACK
source firmware file: dl/fw/FRITZ.Box_7560-07.29.image
checking signature: failed
OpenSSL: 4027CF18617F0000:error:02000068:rsa routines:eek:ssl_rsa_verify:bad signature:../crypto/rsa/rsa_sign.c:430:
4027CF18617F0000:error:1C880004:provider routines:rsa_verify:RSA lib:../providers/implementations/signature/rsa_sig.c:774:
Verification failure
ERROR: image could not be verified with public key
FINISHED
Hallo zusammen! Hab das jetzt hin bekommen ein Image zu generieren.
Glaube das Problem lag einfach daran, dass ich das Ganze mit Kali Linux kompilieren wollte...
Hab mir die virtuelle Umgebung "Freetz-Linux" runter geladen und diese in Virtual Box gestartet...
Musste daraufhin lediglich noch die beiden Pakete "libssl-dev" und "libgnutls28-dev" nachinstallieren und voila... mein Image war fertig...
Das 1und1 Branding hab ich auch schon entfernen können... und mit der Umgebung hab ich dann die Box auch noch gleich geflashed...
-> Als nächstes werde ich mal schaun, dass die Kiste ins Internet kommt und dann wird mal n bissl mit OpenVPN, Nagios und der Firewall rum gespielt!
Kann man mit diesem Image z.B. TVHeadend für eine Fritzbox kompilieren?
Update auf Freetz-Linux-2.1.0-Ubuntu 22.04. LTS (Jammy Jellyfish) 64-Bit
Habe da eine Frage.
Ist es eigentlich gefahrlos möglich
eine alte
Ubuntu 20.04.6 LTS (GNU/Linux 5.4.0-163-generic x86_64)
upzudaten eher upgraden?
New release '22.04.3 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
BerndBareth
