Connecting to c2a2b2.com (92.51.130.126:80)
cfg_asterisk16 100% |**************************************************************************************************************************************************************| 24215 --:--:-- ETA
# chmod +x ./cfg_asterisk16
# ./cfg_asterisk16 -v usb_install
cfg.common 100% |**************************************************************************************************************************************************************| 46767 --:--:-- ETA
INFORMATION: cfg.common: current v2.352 >= required v2.352 -> OK
INFORMATION: asterisk16 Version: 1.6.0.1
INFORMATION: Install-Script Version: 1.241
EXECUTING: _fct cfgctl@cfg_asterisk16:check:app_status
total used free shared buffers
Mem: 30260 29164 1096 0 1036
Swap: 0 0 0
Total: 30260 29164 1096
EXECUTING: _fct instdir@/var/media/ftp:addons/asterisk16:inst_dir:inst_fs_type
INFORMATION: Installing asterisk16 ([url]http://c2a2b2.com/fbox/0.9.29/26[/url]) to /var/media/ftp/SanDisk-CruzerMini-01/addons ...
EXECUTING: _fct mkdr@/var:log:run:spool:log/asterisk:spool/asterisk
EXECUTING: _fct [email]wgetx@http://c2a2b2.com/fbox/0.9.29/26:/var/media/ftp/SanDisk-CruzerMini-01/addons:freeramdisk:rd.ko[/email]
freeramdisk 100% |**************************************************************************************************************************************************************| 13515 --:--:-- ETA
rd.ko 100% |**************************************************************************************************************************************************************| 9287 --:--:-- ETA
EXECUTING: _fct [email]wgetx@http://c2a2b2.com/fbox/0.9.29:/var/media/ftp/SanDisk-CruzerMini-01/addons:cfg.cust[/email]omize
cfg.customize 100% |**************************************************************************************************************************************************************| 1386 --:--:-- ETA
EXECUTING: _fct rdsk@start
EXECUTING: _fct rdsk@new:ramdev
asterisk16.sqf -> /var/ram0:
EXECUTING: _fct [email]wgetx@http://c2a2b2.com/fbox/0.9.29/26:/var/ram0:asterisk16.sqf[/email]
ram0 100% |**************************************************************************************************************************************************************| 1760k 00:00:00 ETA
INFORMATION: Installing asterisk16 on usb device (SanDisk-CruzerMini-01)
Start extracting files ... please wait!
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/bin/rasterisk': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/usr/lib/asterisk/sounds/de/digits/minutes.gsm': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/usr/lib/asterisk/sounds/digits/minutes.gsm': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/usr/lib/libgcc_s.so': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/usr/lib/libncurses.so': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/usr/lib/libncurses.so.5': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/usr/lib/libresolv.so': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/usr/lib/libresolv.so.0': Operation not permitted
EXECUTING: _fct rdsk@free:/var/ram0:/var/media/ftp/SanDisk-CruzerMini-01/addons
EXECUTING: _fct lnsf@/var/log/asterisk:/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/log/asterisk
EXECUTING: _fct lnsf@/var/spool/asterisk:/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/spool/asterisk
COMPLETED: asterisk16 has been successfully installed to usb device SanDisk-CruzerMini-01
Performing root install ... This may take a couple minutes.
Aborting during this period will render your system inoperable!!!
EXECUTING: _fct cfgctl@cfg_asterisk16:disable:SILENT
INFORMATION: asterisk16 start disabled during ROOT overlaying phase ...
EXECUTING: _fct ovrly@RO,USB:/bin:/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/bin
-> /bin - ADDED SOFTLINKS: 44
-> /bin/cp NOT REPLACED with SYMLINK to file /var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/bin/cp, as RO parm was set.
-> /bin - ADDED SOFTLINKS: 18
INFORMATION: _fct ovrly@RO,USB:/bin:/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/bin: Total 62 softlinks added to /bin/...
EXECUTING: _fct ovrly@RO,USB:/etc:/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/etc
-> /etc - ADDED SOFTLINKS: 29
-> /etc - ADDED SOFTLINKS: 3
INFORMATION: _fct ovrly@RO,USB:/etc:/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/etc: Total 32 softlinks added to /etc/...
EXECUTING: _fct ovrly@RO,USB:/usr:/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/usr
-> /usr - ADDED SOFTLINKS: 4
-> /usr - ADDED SOFTLINKS: 1
INFORMATION: _fct ovrly@RO,USB:/usr:/var/media/ftp/SanDisk-CruzerMini-01/addons/asterisk16/usr: Total 5 softlinks added to /usr/...
EXECUTING: _fct mntif@-o:bind:/var/_RO_/usr/www:/usr/www
EXECUTING: _fct mntif@-o:bind:/var:/var/_RO_/var
EXECUTING: _fct cfgctl@cfg_asterisk16:enable:SILENT
INFORMATION: ROOT overlaying phase finished. asterisk16 starting enabled!
Mem: 30260 27492 2768 0 396
Swap: 0 0 0
Total: 30260 27492 2768
to use asterisk16 type ./cfg_asterisk16 start
(or /var/media/ftp/SanDisk-CruzerMini-01/addons/cfg_asterisk16 start)
After a reboot you may reinstall asterisk16 from usb with
/var/media/ftp/SanDisk-CruzerMini-01/addons/cfg_asterisk16 usb_install
Found addons customization script cfg.customize in /var/media/ftp/SanDisk-CruzerMini-01/addons. Will check & run customizations for asterisk16 now.
# ./cfg_asterisk16 -v start
asterisk: can't load library 'libncurses.so.5'
asterisk daemon has been started (to open a console use: cfg_asterisk16 start r)
# wget [url]http://c2a2b2.com/fbox/0.9.29/cfg_dropbear[/url]
cfg_dropbear 100% |**************************************************************************************************************************************************************| 13702 --:--:-- ETA
# chmod +x ./cfg_dropbear
# ./cfg_dropbear -v usb_install
cfg.common: current v2.352 >= required v2.351 -> OK
EXECUTING: _fct cfgctl@cfg_dropbear:check:app_status
Mem: 30260 28644 1616 0 620
Swap: 0 0 0
Total: 30260 28644 1616
EXECUTING: _fct instdir@/var/media/ftp:addons/dropbear:inst_dir:inst_fs_type
INFORMATION: Installing dropbear ([url]http://c2a2b2.com/fbox/0.9.29/26[/url]) to /var/media/ftp/SanDisk-CruzerMini-01/addons ...
dropbear.sqf -> /var/ram0:
EXECUTING: _fct [email]wgetx@http://c2a2b2.com/fbox/0.9.29/26:/var/ram0:dropbear.sqf[/email]
ram0 100% |**************************************************************************************************************************************************************| 108k --:--:-- ETA
INFORMATION: Installing dropbear on usb device (SanDisk-CruzerMini-01)
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/bin/dbclient': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/bin/dropbear': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/bin/dropbearconvert': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/bin/dropbearkey': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/bin/scp': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/bin/ssh': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/usr/lib/libutil.so.0': Operation not permitted
EXECUTING: _fct lnsf@/var/log/dropbear:/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/log/dropbear
EXECUTING: _fct lnsf@/var/spool/dropbear:/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/spool/dropbear
dropbear has been successfully installed to usb device SanDisk-CruzerMini-01
EXECUTING: _fct cfgctl@cfg_dropbear:disable:SILENT
INFORMATION: dropbear start disabled during ROOT overlaying phase ...
EXECUTING: _fct ovrly@RO,USB:/bin:/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/bin
-> /bin - ADDED SOFTLINKS: 2
INFORMATION: _fct ovrly@RO,USB:/bin:/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/bin: Total 2 softlinks added to /bin/...
EXECUTING: _fct ovrly@RO,USB:/etc:/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/etc
-> /etc - ADDED SOFTLINKS: 1
INFORMATION: _fct ovrly@RO,USB:/etc:/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/etc: Total 1 softlinks added to /etc/...
EXECUTING: _fct ovrly@RO,USB:/usr:/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/usr
-> /usr/lib - ADDED SOFTLINKS: 4
-> /usr/lib - ADDED SOFTLINKS: 1
-> /usr - ADDED SOFTLINKS: 0
INFORMATION: _fct ovrly@RO,USB:/usr:/var/media/ftp/SanDisk-CruzerMini-01/addons/dropbear/usr: Total 5 softlinks added to /usr/...
EXECUTING: _fct cfgctl@cfg_dropbear:enable:SILENT
INFORMATION: ROOT overlaying phase finished. dropbear starting enabled!
EXECUTING: _fct ovrly@NL,USB:/dev/pts
INFORMATION: _fct ovrly@NL,USB:/dev/pts: Total 0 softlinks added to /dev/pts/...
EXECUTING: _fct lnsf2@/bin:dropbear:dbclient:dropbearconvert:dropbearkey:scp:ssh:dropbearmulti
Mem: 30260 28968 1292 0 684
Swap: 0 0 0
Total: 30260 28968 1292
to use dropbear type ./cfg_dropbear start
(or /var/media/ftp/SanDisk-CruzerMini-01/addons/cfg_dropbear start)
After a reboot you may reinstall dropbear from usb with
/var/media/ftp/SanDisk-CruzerMini-01/addons/cfg_dropbear usb_install
Found addons customization script cfg.customize in /var/media/ftp/SanDisk-CruzerMini-01/addons. Will check & run customizations for dropbear now.
# ./cfg_dropbear -v start
/bin/dropbear: can't load library 'libutil.so.0'
