Wed Mar 21 15:07:48 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Mar 21 15:07:48 2012 Diffie-Hellman initialized with 1024 bit key
Wed Mar 21 15:07:48 2012 WARNING: file '/tmp/flash/openvpn/box.key' is group or others accessible
Wed Mar 21 15:07:48 2012 WARNING: file '/tmp/flash/openvpn/static.key' is group or others accessible
Wed Mar 21 15:07:48 2012 Control Channel Authentication: using '/tmp/flash/openvpn/static.key' as a OpenVPN static key file
Wed Mar 21 15:07:48 2012 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Mar 21 15:07:48 2012 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Mar 21 15:07:48 2012 TLS-Auth MTU parms [ L:1590 D:166 EF:66 EB:0 ET:0 EL:0 ]
Wed Mar 21 15:07:48 2012 Socket Buffers: R=[108544->131072] S=[108544->131072]
Wed Mar 21 15:07:48 2012 OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig opti
Wed Mar 21 15:07:48 2012 OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.168.0
Wed Mar 21 15:07:48 2012 TUN/TAP device tap0 opened
Wed Mar 21 15:07:48 2012 TUN/TAP TX queue length set to 100
Wed Mar 21 15:07:48 2012 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Wed Mar 21 15:07:48 2012 /sbin/ifconfig tap0 192.168.168.1 netmask 255.255.255.0 mtu 1500 broadcast 192.168.168.255
Wed Mar 21 15:07:48 2012 Data Channel MTU parms [ L:1590 D:1450 EF:58 EB:135 ET:32 EL:0 AF:3/1 ]
Wed Mar 21 15:07:48 2012 chroot to '/tmp/openvpn' and cd to '/' succeeded
Wed Mar 21 15:07:48 2012 GID set to openvpn
Wed Mar 21 15:07:48 2012 UID set to openvpn
Wed Mar 21 15:07:48 2012 UDPv4 link local (bound): [undef]
Wed Mar 21 15:07:48 2012 UDPv4 link remote: [undef]
Wed Mar 21 15:07:48 2012 MULTI: multi_init called, r=256 v=256
Wed Mar 21 15:07:48 2012 IFCONFIG POOL: base=192.168.168.201 size=20, ipv6=0
Wed Mar 21 15:07:48 2012 Initialization Sequence Completed
Wed Mar 21 15:08:11 2012 MULTI: multi_create_instance called
Wed Mar 21 15:08:11 2012 79.230.1.236:50555 Re-using SSL/TLS context
Wed Mar 21 15:08:11 2012 79.230.1.236:50555 LZO compression initialized
Wed Mar 21 15:08:11 2012 79.230.1.236:50555 Control Channel MTU parms [ L:1590 D:166 EF:66 EB:0 ET:0 EL:0 ]
Wed Mar 21 15:08:11 2012 79.230.1.236:50555 Data Channel MTU parms [ L:1590 D:1450 EF:58 EB:135 ET:32 EL:0 AF:3/1 ]
Wed Mar 21 15:08:11 2012 79.230.1.236:50555 TLS: Initial packet from [AF_INET]79.230.1.236:50555, sid=72367019 030b90b4
Wed Mar 21 15:08:17 2012 79.230.1.236:50555 VERIFY OK: depth=1, /C=GE/ST=Bxxx/L=xxx/O=AW-OpenVPN/OU=changeme/CN=mein.homeserver/name=AW/emailAddress=armin.xxx
Wed Mar 21 15:08:17 2012 79.230.1.236:50555 VERIFY OK: depth=0, /C=GE/ST=Bxxx/L=xxx/O=AW-OpenVPN/OU=changeme/CN=armin2/name=changeme/emailAddress=armin.xxx
Wed Mar 21 15:08:18 2012 79.230.1.236:50555 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Wed Mar 21 15:08:18 2012 79.230.1.236:50555 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Mar 21 15:08:18 2012 79.230.1.236:50555 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Wed Mar 21 15:08:18 2012 79.230.1.236:50555 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Mar 21 15:08:18 2012 79.230.1.236:50555 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Mar 21 15:08:18 2012 79.230.1.236:50555 [armin2] Peer Connection Initiated with [AF_INET]79.230.1.236:50555
Wed Mar 21 15:08:18 2012 armin2/79.230.1.236:50555 MULTI_sva: pool returned IPv4=192.168.168.201, IPv6=b40b:4100:d8c4:5500:30fc:4100:50c4:5500
Wed Mar 21 15:08:20 2012 armin2/79.230.1.236:50555 PUSH: Received control message: 'PUSH_REQUEST'
Wed Mar 21 15:08:20 2012 armin2/79.230.1.236:50555 send_push_reply(): safe_cap=960
Wed Mar 21 15:08:20 2012 armin2/79.230.1.236:50555 SENT CONTROL [armin2]: 'PUSH_REPLY,route-gateway 192.168.168.1,route 192.168.168.1,ping 10,ping-restart 120,ifconfig
Wed Mar 21 15:08:20 2012 armin2/79.230.1.236:50555 MULTI: Learn: 00:ff:9b:40:1e:e2 -> armin2/79.230.1.236:50555
