Boblight for Fritzbox?
the config file I´m using works on Ubuntu.. any ideas?
could it have to do with
[global]
interface 127.0.0.1
port 19333
that´s from the wiki:
A [global] section has two settings: interface and port.
You can specify as many global settings as you want, although there's no point in having more than one.
Interface specifies where to bind the listening tcp socket, if interface is not specified boblightd will bind to all interfaces (INADDR_ANY) by default, for safety reasons you should bind to interface 127.0.0.1 if you don't plan to use boblight over a network.
Port specifies to which port the tcp socket will bind (who would have guessed), if no port is specified boblightd will bind to port 19333 by default.
should i remove the interface line or change it to the network ip`?
EDIT: didn´t help, tried both. :(
here is my boblight.conf
http://www.gtwf-koeln.de/boblight.conf
it´s saved in ANSI with UNIX format. so that should be correct.
Christinakathy
