Using username "root".
[email protected]'s password:
BusyBox v1.18.5 (2011-09-10 16:36:14 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
ATTITUDE ADJUSTMENT (bleeding edge, r28252) ----------
* 1/4 oz Vodka Pour all ingredients into mixing
* 1/4 oz Gin tin with ice, strain into glass.
* 1/4 oz Amaretto
* 1/4 oz Triple sec
* 1/4 oz Peach schnapps
* 1/4 oz Sour mix
* 1 splash Cranberry juice
root@OpenWrt:~# dmesg
Linux version 2.6.39.4 (fritz@fritz-desktop) (gcc version 4.5.4 20110808 (prerelease) (Linaro GCC 4.5-2011.08) ) #34 Sat Sep 17 18:50:18 CEST 2011
KERNEL supported cpus:
AMD AuthenticAMD
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000010000000 (usable)
BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
Notice: NX (Execute Disable) protection missing in CPU!
e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
last_pfn = 0x10000 max_arch_pfn = 0x100000
initial memory mapped : 0 - 01800000
Base memory trampoline at [c009e000] 9e000 size 4096
init_memory_mapping: 0000000000000000-0000000010000000
0000000000 - 0000400000 page 4k
0000400000 - 0010000000 page 2M
kernel direct mapping tables up to 10000000 @ 17fc000-1800000
256MB LOWMEM available.
mapped low ram: 0 - 10000000
Zone PFN ranges:
DMA 0x00000010 -> 0x00001000
Normal 0x00001000 -> 0x00010000
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
0: 0x00000010 -> 0x000000a0
0: 0x00000100 -> 0x00010000
On node 0 totalpages: 65424
free_area_init_node: node 0, pgdat c124fe20, node_mem_map cfe00200
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 3952 pages, LIFO batch:0
Normal zone: 480 pages used for memmap
Normal zone: 60960 pages, LIFO batch:15
Using APIC driver default
No local APIC present or hardware disabled
APIC: disable apic facility
APIC: switched to apic NOOP
nr_irqs_gsi: 16
Allocating PCI resources starting at 10000000 (gap: 10000000:eff00000)
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64912
Kernel command line: block2mtd.block2mtd=/dev/sda2,65536,rootfs root=/dev/mtdblock0 rootfstype=jffs2 rootwait console=tty0 console=ttyS0,115200n8 noinitrd reboot=bios
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Initializing CPU#0
Memory: 256684k/262144k available (1841k kernel code, 5012k reserved, 539k data, 192k init, 0k highmem)
virtual kernel memory layout:
fixmap : 0xfffa4000 - 0xfffff000 ( 364 kB)
vmalloc : 0xd0800000 - 0xfffa2000 ( 759 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
.init : 0xc1254000 - 0xc1284000 ( 192 kB)
.data : 0xc11cc757 - 0xc1253380 ( 539 kB)
.text : 0xc1000000 - 0xc11cc757 (1841 kB)
Checking if this processor honours the WP bit even in supervisor mode...Ok.
SLUB: Genslabs=15, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:288
CPU 0 irqstacks, hard=cf80c000 soft=cf80e000
console [ttyS0] enabled
Fast TSC calibration using PIT
Detected 498.047 MHz processor.
Calibrating delay loop (skipped), value calculated using timer frequency.. 996.09 BogoMIPS (lpj=4980470)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Geode(TM) Integrated Processor by AMD PCS stepping 02
Performance Events: no PMU driver, software events only.
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xfced9, last bus=0
PCI: Using configuration type 1 for base access
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
pci 0000:00:01.0: [1022:2080] type 0 class 0x000600
pci 0000:00:01.0: reg 10: [io 0xac1c-0xac1f]
pci 0000:00:01.2: [1022:2082] type 0 class 0x001010
pci 0000:00:01.2: reg 10: [mem 0xefff4000-0xefff7fff]
pci 0000:00:09.0: [1106:3053] type 0 class 0x000200
pci 0000:00:09.0: reg 10: [io 0x1000-0x10ff]
pci 0000:00:09.0: reg 14: [mem 0xe0000000-0xe00000ff]
pci 0000:00:09.0: supports D1 D2
pci 0000:00:09.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:09.0: PME# disabled
pci 0000:00:0f.0: [1022:2090] type 0 class 0x000601
pci 0000:00:0f.0: reg 10: [io 0x6000-0x6007]
pci 0000:00:0f.0: reg 14: [io 0x6100-0x61ff]
pci 0000:00:0f.0: reg 18: [io 0x6200-0x623f]
pci 0000:00:0f.0: reg 20: [io 0x9d00-0x9d7f]
pci 0000:00:0f.0: reg 24: [io 0x9c00-0x9c3f]
pci 0000:00:0f.2: [1022:209a] type 0 class 0x000101
pci 0000:00:0f.2: reg 20: [io 0xff00-0xff0f]
pci 0000:00:0f.4: [1022:2094] type 0 class 0x000c03
pci 0000:00:0f.4: reg 10: [mem 0xefffe000-0xefffefff]
pci 0000:00:0f.4: PME# supported from D0 D3hot D3cold
pci 0000:00:0f.4: PME# disabled
pci 0000:00:0f.5: [1022:2095] type 0 class 0x000c03
pci 0000:00:0f.5: reg 10: [mem 0xefffd000-0xefffdfff]
pci 0000:00:0f.5: PME# supported from D0 D3hot D3cold
pci 0000:00:0f.5: PME# disabled
PCI: pci_cache_line_size set to 32 bytes
Switching to clocksource pit
pci_bus 0000:00: resource 0 [io 0x0000-0xffff]
pci_bus 0000:00: resource 1 [mem 0x00000000-0xffffffff]
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
PCI: CLS 32 bytes, default 32
platform rtc_cmos: registered platform RTC device (no PNP device found)
alix: system is recognized as "PC Engines ALIX.3 v0.99h"
squashfs: version 4.0 (2009/01/31) Phillip Lougher
JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
msgmni has been set to 501
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a NS16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a NS16550A
Real Time Clock Driver v1.12b
Non-volatile memory driver v1.3
AMD Geode RNG detected
scsi0 : pata_cs5536
scsi1 : pata_cs5536
ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xff00 irq 14
ata2: DUMMY
ata1.00: ATA-0: , 20071116, max MWDMA2
ata1.00: 3964464 sectors, multi 0: LBA
ata1.00: configured for MWDMA2
scsi 0:0:0:0: Direct-Access ATA 2007 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 3964464 512-byte logical blocks: (2.02 GB/1.88 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1 sda2
sd 0:0:0:0: [sda] Attached SCSI disk
Creating 1 MTD partitions on "rootfs":
0x000000000000-0x000003030000 : "rootfs"
split_squashfs: no squashfs found in "rootfs"
block2mtd: mtd0: [rootfs] erase_size = 64KiB [65536]
cpuidle: using governor ladder
TCP westwood registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
All bugs added by David S. Miller <[email protected]>
Using IPI Shortcut mode
Switching to clocksource tsc
JFFS2 notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
VFS: Mounted root (jffs2 filesystem) readonly on device 31:0.
Freeing unused kernel memory: 192k freed
NET: Registered protocol family 10
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Button Hotplug driver version 0.4.1
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
nsc_gpio initializing
ip_tables: (C) 2000-2006 Netfilter Core Team
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:0f.5: setting latency timer to 64
ehci_hcd 0000:00:0f.5: EHCI Host Controller
ehci_hcd 0000:00:0f.5: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:0f.5: irq 12, io mem 0xefffd000
ehci_hcd 0000:00:0f.5: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 4 ports detected
nf_conntrack version 0.5.0 (4013 buckets, 16052 max)
cs5535-mfd 0000:00:0f.0: 5 devices registered.
cs5535-mfgpt cs5535-mfgpt: reserved resource region [io 0x6200-0x623f]
cs5535-mfgpt cs5535-mfgpt: 8 MFGPT timers available
usb 1-1: new high speed USB device number 2 using ehci_hcd
cs5535-mfgpt cs5535-mfgpt: registered timer 0
cs5535-clockevt: Registering MFGPT timer as a clock event, using IRQ 7
cs5535-gpio cs5535-gpio: reserved resource region [io 0x6100-0x61ff]
cs5535-gpio cs5535-gpio: GPIO support successfully loaded.
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci_hcd 0000:00:0f.4: setting latency timer to 64
ohci_hcd 0000:00:0f.4: OHCI Host Controller
ohci_hcd 0000:00:0f.4: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:0f.4: irq 12, io mem 0xefffe000
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 7 ports detected
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 4 ports detected
uhci_hcd: USB Universal Host Controller Interface driver
via-rhine.c:v1.10-LK1.5.0 2010-10-09 Written by Donald Becker
via-rhine 0000:00:09.0: setting latency timer to 64
eth0: VIA Rhine III (Management Adapter) at 0xe0000000, 00:0d:ef:1a:bc:de, IRQ 10.
eth0: MII PHY found at address 1, status 0x786d advertising 05e1 Link 4de1.
cs5535-mfgpt cs5535-mfgpt: registered timer 1
i2c /dev entries driver
usb 1-1.1: new high speed USB device number 3 using ehci_hcd
cs5535-smb cs5535-smb: SCx200 device 'CS5535 ACB0' registered
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
hub 1-1.1:1.0: USB hub found
hub 1-1.1:1.0: 4 ports detected
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
via-rhine 0000:00:09.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
8021q: adding VLAN 0 to HW filter on device eth0
usb 1-1.1.1: new high speed USB device number 4 using ehci_hcd
option 1-1.1.1:1.0: GSM modem (1-port) converter detected
usb 1-1.1.1: GSM modem (1-port) converter now attached to ttyUSB0
option 1-1.1.1:1.1: GSM modem (1-port) converter detected
usb 1-1.1.1: GSM modem (1-port) converter now attached to ttyUSB1
option 1-1.1.1:1.2: GSM modem (1-port) converter detected
usb 1-1.1.1: GSM modem (1-port) converter now attached to ttyUSB2
usb 1-1.1.2: new high speed USB device number 5 using ehci_hcd
option 1-1.1.2:1.0: GSM modem (1-port) converter detected
usb 1-1.1.2: GSM modem (1-port) converter now attached to ttyUSB3
option 1-1.1.2:1.1: GSM modem (1-port) converter detected
usb 1-1.1.2: GSM modem (1-port) converter now attached to ttyUSB4
option 1-1.1.2:1.2: GSM modem (1-port) converter detected
usb 1-1.1.2: GSM modem (1-port) converter now attached to ttyUSB5
usb 1-1.1.3: new high speed USB device number 6 using ehci_hcd
option 1-1.1.3:1.0: GSM modem (1-port) converter detected
usb 1-1.1.3: GSM modem (1-port) converter now attached to ttyUSB6
option 1-1.1.3:1.1: GSM modem (1-port) converter detected
usb 1-1.1.3: GSM modem (1-port) converter now attached to ttyUSB7
option 1-1.1.3:1.2: GSM modem (1-port) converter detected
usb 1-1.1.3: GSM modem (1-port) converter now attached to ttyUSB8
usb 1-1.1.4: new high speed USB device number 7 using ehci_hcd
option 1-1.1.4:1.0: GSM modem (1-port) converter detected
usb 1-1.1.4: GSM modem (1-port) converter now attached to ttyUSB9
option 1-1.1.4:1.1: GSM modem (1-port) converter detected
usb 1-1.1.4: GSM modem (1-port) converter now attached to ttyUSB10
option 1-1.1.4:1.2: GSM modem (1-port) converter detected
usb 1-1.1.4: GSM modem (1-port) converter now attached to ttyUSB11
usb 1-2: new high speed USB device number 8 using ehci_hcd
option 1-2:1.0: GSM modem (1-port) converter detected
usb 1-2: GSM modem (1-port) converter now attached to ttyUSB12
option 1-2:1.1: GSM modem (1-port) converter detected
usb 1-2: GSM modem (1-port) converter now attached to ttyUSB13
option 1-2:1.2: GSM modem (1-port) converter detected
usb 1-2: GSM modem (1-port) converter now attached to ttyUSB14
usb 1-1.3: new high speed USB device number 9 using ehci_hcd
option 1-1.3:1.0: GSM modem (1-port) converter detected
usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB15
option 1-1.3:1.1: GSM modem (1-port) converter detected
usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB16
option 1-1.3:1.2: GSM modem (1-port) converter detected
usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB17
usb 1-1.5: new high speed USB device number 10 using ehci_hcd
option 1-1.5:1.0: GSM modem (1-port) converter detected
usb 1-1.5: GSM modem (1-port) converter now attached to ttyUSB18
option 1-1.5:1.1: GSM modem (1-port) converter detected
usb 1-1.5: GSM modem (1-port) converter now attached to ttyUSB19
option 1-1.5:1.2: GSM modem (1-port) converter detected
usb 1-1.5: GSM modem (1-port) converter now attached to ttyUSB20
usb 1-1.7: new high speed USB device number 11 using ehci_hcd
option 1-1.7:1.0: GSM modem (1-port) converter detected
usb 1-1.7: GSM modem (1-port) converter now attached to ttyUSB21
option 1-1.7:1.1: GSM modem (1-port) converter detected
usb 1-1.7: GSM modem (1-port) converter now attached to ttyUSB22
option 1-1.7:1.2: GSM modem (1-port) converter detected
usb 1-1.7: GSM modem (1-port) converter now attached to ttyUSB23
root@OpenWrt:~# uptime
19:45:26 up 6 days, 20:31, load average: 1.45, 1.28, 1.24
root@OpenWrt:~#
