; Static indications configuration files, used by
; the pbx_indications module.
; The "general" category is for certain variables. All other categories
; are interpreted as indication countries
; Please note that there are NOT spaces allowed in lists!
[general]
country=us
; [example]
; description = string
; The full name of your country, in English
; alias = iso[,iso]*
; List of other countries 2-letter iso codes, which have the same
; tone indications.
; ringcadance = num[,num]*
; List of durations the physical bell rings.
; dial = tonelist
; Set of tones to be played when one picks up the hook.
; busy = tonelist
; Set of tones played when the receiving end is busy.
; congestion = tonelist
; Set of tones played when the is some congestion (on the network?)
; callwaiting = tonelist
; Set of tones played when there is a callwaiting in the background.
; dialrecall = tonelist
; Set of tones played when there is somebody ???
; record = tonelist
; Set of tones played whenver we feel like it ???
; info = tonelist
; Set of tones played when information is to be transfered?
; every other variable will be available as a shortcut for the "PlayList" command
; but will not automaticly be used by Asterisk.
; The tonelist itself is defined by a sequence of elements, seperated by ,'s.
; Each element consist of a frequency (f) with a possible frequency attached
; (f1+f2) to it. Behind the frequency there is an optional duration, in
; milliseconds. If the element starts with a !, that element is NOT repeat,
; so only if all elements start with !, the tonelist is time-limited, all
; others will repeat indefinitly.
;In tech-talk
; tonelist = element[,element]*
; element = [!]freq[+freq2][/duration]
[us]
description = United States / North America
ringcadance = 2000,4000
dial = 350+440
busy = 480+620/500,0/500
ring = 440+480/2000,0/4000
congestion = 480+620/250,0/250
callwaiting = 440/300,0/10000
dialrecall = !350+440/100,!0/100,!350+440/100,!0/100,!350+440/100,!0/100,350+440
record = 1400/500,0/15000
info = !950/330,!1400/330,!1800/330,0
[au]
description = Australia
ringcadance = 400,200,400,2000
;XXX Dialtone
;Should be modulated, not added XXX
dial = 425+25
busy = 400/375,0/375
ring = 400+17/400,0/200,400+17/400,0/2000
;XXX Congestion
;Should reduce by 10 db every other cadence XXX
congestion = 400/375,0/375
callwaiting = 425/100,0/100,525/100,0/4700
dialrecall = !425+25/100!0/100,!425+25/100,!0/100,!425+25/100,!0/100,425+25
record = 1400/425,0/14525
info = 400/2500,0/500
[fr]
description = France
ringcadance = 1500,3500
; Dialtone can also be 440+330
dial = 440
busy = 440/500,0/500
ring = 440/1500,0/3500
; XXX I'm making up the congestion tone XXX
congestion = 440/250,0/250
; XXX I'm making up the call wait tone too XXX
callwait = 440/300,0/10000
; XXX I'm making up dial recall XXX
; XXX I'm making up the record tone XXX
[nl]
alias = de
description = Netherlands
ringcadance = 1000,4000
; Most of these 425's can also be 450's
dial = 425
busy = 425/500,0/500
ring = 425/1000,0/4000
congestion = 425/250,0/250
; XXX I'm making up the call wait tone XXX
; XXX Assuming this is "Special Dial Tone" XXX
dialrecall = 425/500,0/50
info = 950/330,1400/330,1800/330,0/1000
[uk]
description = United Kingdom
dial = 350+440
ring = 400+450/400,0/200,400+450/400,0/2000
congestion = 400/400,0/350,400/225,0/525
callwaiting = 440/100,0/4000
dialrecall = 350+440
; XXX Not sure about the RECORDTONE
record = 1400/500,0/10000
[fi]
description = Finland
dial = 425
busy = 425/300,0/300
congestion = 425/200,0/200
callwaiting = 425/150,0/150,425/150,0/8000
dialrecall = 425/650,0/25
info = 950/650,0/325,950/325,0/30,1400/1300,0/2600
[no]
description = Norway
ringcadence = 1000,4000
dial = 425
callwaiting = 425/200,0/600,425/200,0/10000
dialrecall = 470/400,425/400
record = 1400/400,0/15000
info = !950/330,!1400/330,!1800/330,!0/1000,!950/330,!1400/330,!1800/330,!0/1000,!950/330,!1400/330,!1800/330,!0/1000,0
[br]
description = Brazil
dial = 425
busy = 425/250,0/250
congestion = 425/250,0/250,425/750,0/250
callwaiting = 425/50,0/1000
; Dialrecall not used in Brazil standard (using UK standard)
; Record tone is not used in Brazil, use busy tone
record = 425/250,0/250
; Info not used in Brazil standard (using UK standard)
