Hallo Folk's,
Why another call monitor ... well, simply because I love to make tiny software, it's just for fun. Besides that, it does exactly what I need, nothing more, perhaps it will be the case for someone else.
Basically, it's a little program that monitors incoming and outgoing calls, with caller ID & name, possibility to monitors multiple calls simultaneously, missed calls counter & log, big alert box with all the informations available, possibility to add unknown numbers directly, trayicon with 4 status (online with no active call, offline or disconnected, call active, and call connected) - so you can see what happens with your lines at any time. It features also slient auto-reconnect upon non-desired disconnection, tray icon hint displays active in & out call counter.
I think I will add a dialer functionality soon, for example you would be able to call back someone by double-clicking his name on the missed call log. I will also add external program execution on special defined conditions (especially missed calls).
It works only with the integrated call monitor of the fritz!box fon on TCP port 1012, so you must have a recent firmware and enable it with #96*5*
I have attached some screenshots and the program itself, I hope it will be accessible, it's the first time I post something here. It has no documentation for the moment, but I think it's not a big deal
Any comments and suggestions are welcome !
PS: you can also add names manually by creating or modifying the phonebook .. the filename is "CallMonitor.adr" and it is a simple text file. Format :
"NAME 1","0123456789"
"NAME xxx","000xxx"
The settings are stored in a small binary file "CallMonitor.ini", it will be created the first time you launch the soft. The registry is never used.
:idea: UPDATE 28.03.2006
new build : 1.0.0.13
-play sound on incoming calls, custom wave file, and possiblity to loop while the phone is ringing
-corrected bug with the reset missed calls counter, now confirmation dialog "yes" or "no" is visible, on top
-added FON3 extension in the options (I can't test this, because I have the ATA model, with 2 phone ports)
-now the dialogs boxes (yes no confirm cancel, etc...) are also in english ( no more french ) and I envisage to translate the full program with the help of a good soul
-settings are now better checked against bad characters input
I have also added a small "ring" wave file, simply modified with a 2 sec pause a the end (if you use the loop, it's better ...)
If you replace the executable with the new one, it will say that the setting's file is corrupted, it's a normal behavior, it will reload new default settings
"NAME xxx","000xxx"
